I thought it was a magic button to get a green, then a *wait*I’m reliably informed that over use of the “SG” button results in a slower journey.
Sooooo tempting....
However, If I press SG, get a pint of the usual, clear it.. What happens if I press SG again ? Does it send a second awaiting signal message ?
Thats pretty much it.I thought it was a magic button to get a green, then a *wait*
Thats actually interesting to know. I don't over use the SG. Have been tempted...Yup. If you press it too much it automatically regulates against you.
Thanks and apologies in advanceYes and yes and yes and so on
Our TOC’s instruction is to press it immediately if you come to a stand rather than waiting 2 minutes, however common sense usually prevails nonetheless.Crazes me that some of my colleagues press the button every time they stop regardless off common sense.
I'm also shocked I wrote 'off' instead of 'of' Grrrr!!Our TOC’s instruction is to press it immediately if you come to a stand rather than waiting 2 minutes, however common sense usually prevails nonetheless.
Our TOC’s instruction is to press it immediately if you come to a stand rather than waiting 2 minutes.
Likewise, but I will only press it once per signal and not repeatedly.
I have also been informed by a DTM that it helps with attributing delay, as Nitwit Rail will use the absence of an SG press as evidence that the delay was not due to their actions. I don’t know if that’s true or not, but it’s what I’ve been told.
Or "Stop Griping".That's what it stands for isn't it, Signal Green
I did try to get a TRTS (Train Ready To Start) button fitted at Newark Castle, when they got rid of us locals. However, the project management thought they knew best and didn't think it necessary.Conversely when we've been sat at Newark Castle for half an hour and the bobby has clearly forgotten the barriers, would skillfully timed use of the SG which instantly seems to activate the wig wags and thus avoids the bobby having an O code chucked at them result in a veritable raft of green signals and a freshly brewed coffee awaiting us at Derby? No criticism, I know they can be working on other things but I do try and prevail on the driver not to wait 2 minutes if the barriers don't drop to try and avoid the poor sod on the workstation picking up delay minutes.
In some cases, like a regulating point, it may be obvious. I usually give a driver a call if the wait may be longer than expected or where it may involve a delay to the train.It annoys me when it says wait and you do wait with no explanation. At least on a SPT you (hopefully) got an answer.
More of an old wives tail. The delay will be attributed to the original cause eventually.Likewise, but I will only press it once per signal and not repeatedly.
Or lost in an unrelated delay. Now that annoys me! Especially when signallers in the relevant area aren't asked about a delay. However, that's a different soapbox discussionMore of an old wives tail. The delay will be attributed to the original cause eventually.
High Dyke said:I did try to get a TRTS (Train Ready To Start) button fitted at Newark Castle, when they got rid of us locals. However, the project management thought they knew best and didn't think it necessary.
Good grief! Project managers can't have suggestions from people that actually know what they're talking about. Far too easy.You would have thought it a no brainer, especially with the turn back facility for the bang road move from the up platform as well but hey ho, what do we know.
