GWR operating short 'HSTGTi' sets (see diagrams section for workings)
Domh245
6 Apr 2013
nowhere
All well and good, but just because these trains are fairly competitive with other rail services doesn't mean people actually make those journeys..
Domh245
6 Apr 2013
nowhere
You could also spend 2½ hours travelling from Bedford to Brighton on a train without a toilet
You'd have to be pretty unlucky for all 3 toilets (or 5, if you're on a 12 car) on a 700 to be out of use
ijmad
7 Jan 2016
Apparently I was not awake enough to remember the difference between a 700 and 717.
Mitchell Hurd
28 Oct 2017
I read on here about Castle HST set GW13 - is this one of the few extra sets that the DfT wanted GWR to consider? It was something like that apparently.
43 302
25 Oct 2019
There are currently 11 sets with three more on the way. Three of the vehicles that will *presumably* become GW12 are currently spares.
DannyMich2018
19 Dec 2018
Yes there are 4 spare carriages with current 11 sets (two TGS and two TS) so it makes you wonder if one or two more spares will be converted then with 3 more sets to be done now-as as above if you use 3 out of 4 spares for GW12 this will only leave one spare (a TGS). Not so much of a problem now but next year could be.
MB162435
27 Aug 2017
Penryn
Where are the 3 extra sets destined for, Bristol to displace Turbos/158s, Devon/Cornwall to displace 150/158s, or for new services after Covid is over?
Rich McLean
6 Feb 2012
The Extra sets are likely to replace the current 3 158 diagrams on the Exeter-Penzance corridoor, with those 158 units available for Cornish branchline work, Devon Metro and Bristol area services in order for pacers to be retired. There will have to be some jiggery pokery with those diagrams, as currently, those 158 diagrams are all connected with eachother with attachments and detachments at various points in the day.
MB162435
27 Aug 2017
Penryn
Would make sense to try and make mainline duties Castle Set and IET worked as much as possible
Would also help to get rid of the 143s, but still maintain capacity on Devon Metro services
irish_rail
30 Oct 2013
Plymouth
Would be a good idea to rid plymouth westward of 158s. Virtually no one at plymouth signs them, and there have been occasions when sets have become stranded due to no drivers with traction knowledge. Also pretty sure not many at penzance sign them.
Use all the 158s on the devon metro, and the 2+4 for the mainline stuff.
29 Sep 2018
I believe the few extra castle sets will be enough to see off the 143s yes along with 1 or 2 3 car 165s moving West. I think the future plan for EXM<>PGN is to have 5 x double 150/2s and 2 x 16x workings. There are now 10 additional 150/2s staying with GWR which were originally due to leave to help support additional capacity.
MB162435
27 Aug 2017
Penryn
Thanks for the info, does sounds exciting and hopefully the plans will come to fruition without to much of a hitch that rolling stock plans often do!
43096
23 Nov 2015
43 302
25 Oct 2019
Apedlar12
13 Apr 2017
From what I have seen with the vehicle numbers on the current sets, is that GW93 (the 3 car set at present) only requires one more vehicle (48136) and then it will end up becoming GW12 which would mean that then GW13/14 will then only be the two more required:
GW0149101481014810248103
GW0249102481044810548106
GW0349103481074810848109
GW0449104481104811148112
GW0549105481134811448115
GW0649106481164811748118
GW0749107481194812048121
GW0849108481224812348124
GW0949109481254812648127
GW1049110481284812948130
GW1149111481314813248133
GW93491124813448135(48136)
banjo125
19 Jan 2018
Realistically a few spare carriages will be required (depending on the number of planned diagrams), GW08 is currently formed 49112 48135 48123 48124, presumably 49108 & 48122 are undergoing maintenance.
43096
23 Nov 2015
GW93 currently only has one vehicle in it (48134). 49112 is in GW08, as is 48135. Essentially, GW93 was a temporary set that no longer exists since the full fleet was formed up.
Apedlar12
13 Apr 2017
Ah, thanks for that information, very helpful :)
JKF
29 May 2019
That was 43156 + 43162, cancelled yesterday and running today.
Saw them come through Abbey Wood this afternoon, running a bit early and looking very tidy. This was more or less straight after a Cardiff-Taunton set and a cross country HST set had passed each other in the station, nice to see so many working in such a short spell.
Jamesrob637
12 Aug 2016
Same kind of scenario at Dawlish Warren today - they practically passed the Plymouth to Leeds HST!
43 302
25 Oct 2019
I was about a metre further down the line at Horfield Junction :D Three HSTs, all within a few minutes!
43 302
25 Oct 2019
GW08 is back in its correct formation: 48124 48123 48122 49108
43 302
25 Oct 2019
43172 ran solo from LA to PM this morning where it will join up with 43171 and head to Long Marston. There it will collect six Mk3s and head to Doncaster for conversion. No idea if it will keep it's livery before anyone asks.
MB162435
27 Aug 2017
Penryn
One of the Laira drivers said it was now nameless and being sent off lease
