GWR Strike Timetables
RPI
6 Dec 2010
From what I gather at work today, GWR running hourly Plymouth to Paddington via Bristol, other than a couple of castle cary specials thats it. No branches, nothing in Cornwall
Chingy
24 Jan 2020
Frome
Not surprised re Cornwall, what with the number of local, lever boxes down there still. Surprised there is nothing between Padd and South Wales though, if that's literally it.
RPI
6 Dec 2010
I'm not sure about south Wales actually, I'm not sure if what I was told was just what affects Exeter so wait for the official timetable.
uglymonkey
10 Aug 2018
Reads like a Beeching Mk2 map ! How are they going to run anything if the signalers and NR are on strike?
Chingy
24 Jan 2020
Frome
Would the B&H be closed due to no signaller availability or is it just a GWR decision?
As if it's a signaller issue, that'll essentially close down the Mendip quarry traffic on the affected days next week.
Otherwise, much the same as the other TOC's, ie a skeleton service on the core, city - city bit of their network.
55002
16 Aug 2019
Ldn
Not good for the Glastonbury traffic, although I suppose they can cram on anything via swindon
Nunners
19 Oct 2018
Mendip traffic can go via Melksham, which is still open
infobleep
27 Feb 2011
It seems to be as if GWR can run more of a service than SWR [South Western Railway] when you look at all the branches being served near London.
Is that due to the signalling set-up in those areas compared to SWR?
The signalling work required to run one train shuttles from Twyford to Henley and Slough to Windsor isn't especially complex. You will note that Maidenhead to Marlow is dependent on a guard being available. There are existing arrangements to stable units overnight on the routes.
HamworthyGoods
15 Jan 2019
Indeed, once you’ve got the panel open on Thames Valley Signalling Centre the actual operation of the branches are easy, and with the branches with the exception of Marlow being DOO you don’t need any ‘contingent guards’ to run the trains unlike SWR.
infobleep
27 Feb 2011
The SWR contingent strike service was wider and covered more lines than this strike service will. That didn't have signallers on strike of course but it did need guards.
So I'd have thought the biggest limiting factor is the signalling and less so the guards.
HamworthyGoods
15 Jan 2019
Covid (and it’s restrictions during the pandemic) has resulted in a vast reduction of contingent train operating staff
PTR 444
22 Aug 2019
Wimborne
Cant find any strike dates timetables on the GWR website, however looking at the map in post #6, is the plan to route London - Plymouth trains via Melksham rather than Bristol as originally speculated by the OP?
Also judging by open routes, will the Cardiff - Taunton run as usual and the Cardiff - Portsmouth run as far as Westbury?
Chingy
24 Jan 2020
Frome
Looking at the map in post #6, are GWR planning to route London - Plymouth trains via Melksham rather than Bristol as originally speculated by the OP?
I think the trains routed via Melksham will be Glastonbury specials to Castle Cary. The non festival trains are going Plymouth - Bristol - Swindon - Padd if I understand correctly.
PTR 444
22 Aug 2019
Wimborne
Ahh okay, but will the Castle Cary specials terminate there or continue to Taunton or beyond (as the line from there to Cogload Junction is open). Also seems a bit perverse to route London - Plymouth services via Bristol as the route via Melksham is quicker, and Bristol - Plymouth will be served by Cross Country anyway.
Horizon22
Jobs & Careers
8 Sep 2019
But Bristol to London wouldn't necessarily be. The idea of a Plymouth - London (via Bristol) train is that, whilst long, it serves two core GWR routes for those that must travel.
PTR 444
22 Aug 2019
Wimborne
I guess that makes sense from a supply point of view to make use of fewer resources while drivers and open lines are in short supply. Another question, but will these London > Bristol > Plymouth trains run via Bath or Bristol Parkway?
There is an abundance of available drivers. It is the guards who are on strike.
irish_rail
30 Oct 2013
Plymouth
Indeed not entirely sure where the drivers are all meant to go, there isn't going to be space in most messrooms! And covid hasn't gone away yet either!
Horizon22
Jobs & Careers
8 Sep 2019
Yes this is going to be weird with so many diagrams not required - only so many spares you need with 1/2 tph! Maybe you can all do a station stint each :D
Max
8 Jun 2005
Cambridge
I notice that the expected timetable publication for Tuesday has been postponed from today to tomorrow (Fri 17th).
