GWR withdraw some 800's due to cracks (ORR Report now published)
GC class B1
19 Jun 2021
East midlands
It is interesting how history can tell us a lot.
I was also involved with the cracking and breaking of the production BT10 bogie axlebox castings. The prototype HSTs had performed well, However the production run of the Mk3a loco hauled coaching stock started to suffer from cracks in the axle box castings.
A weld repair was carried out which increased the amount of metal in the area where the cracks were found. This made the situation worse as they were then more prone to fatigue cracks and all suspect castings had to be identified and renewed.
The problem was found to be poor quality castings and the design was deemed to be satisfactory.
The prototype bogies had better quality castings and these were not subject to cracking.
Another similar quality problem affected the early production Sulzer engines built in England. The first engines built by Sulzer in Winterthur were fine but the early engines built in Britain suffered from fatigue cracks in poor quality welds and none compliant notches.
The lesson of these situations is that not only is it necessary to have a proven design, but of course the components must be manufactured to the specified design.
In both the instances I have described above the design had been proven to be satisfactory by developing prototypes but failures still occurred in service.
Irascible
21 Apr 2020
Dyfneint
Several test 80x trains with measuring equipment have been run acros the network over the past year, presumably to test this hypothesis. I don't think Hitachi were too happy at just accepting that the stock / build design is the only component.
Well, tough - provided there's no flaw in the NR data, in which case there's a problem from top to bottom because the NR data feeds back into sorting out the PW too. If the NR data is fine then sorry Hitachi.
As has been said, I hope they're measuring the entire vehicles & not just around the affected areas. Preaching to the choir at this point, but the whole vehicle has to be specced & built for all stresses, and if one part isn't up to it it's not guaranteed the whole entity is. If you can stick the bill on Hitachi then if it's only fixable by upgrading the PW, that's not a bad outcome :p
Towers
30 Aug 2021
Possibly caused by hitting vegetation.
It isn't vegetation related, you can see in the image that the metal underneath is undergoing some sort of reaction, causing the paint to bubble and then flake off. As well as the body ends as photographed, the same issue is occuring at various locations around the vehicles.
fgwrich
15 Apr 2009
Between Edinburgh and Exeter
Indeed - this seemed more than vegetation damage. The paint seemed to be flaking mostly around the car ends, doors and under some windows, and if you touched it you certainly got that dusty white powdery-ness you normally find with aluminium corrosion. Not at all what I'd expect to see on a 4 year old unit (particularly considering SWR's ally bodged 450s are still running around in 20 year old SWT paint!).
Irascible
21 Apr 2020
Dyfneint
General question - Is this showing up on units on other routes?
Irascible
21 Apr 2020
Dyfneint
Not sure - I'll keep an eye out next time I'm passing through Reading or Paddington. It's certainly going to be something else to add to Arlington / Hitachi's rectifying list!
Wondering about units of similar age like the LNER ones, although they go near the coast too, don't they?
hwl
5 Feb 2012
The gist of the report was that the forces acting on the bolster are greater than the model indicated when fed with the network data. However during the investigation real world measurements have been made with sensor equipped 80X trains. It is these true measurements that have informed the new design.
It remains an open question as to what was wrong in the first instance - the model or the network data. This is something that needs to be resolved.
There is also a risk that the sensors are only as good as where they have been located. The forces transmit through the structure and in layman’s language bend or twist it if it is not strong and rigid.
If you start strengthening corner joints etc, you can make these stronger than other parts, and if not careful you move the problem. I always remember this being illustrated with a kitchen sponge, if you twist it, it bends all the way along, but if you clamp the ends so they are rigid and do same, then the movement is concentrated on a smaller area so that is more likely to tear now. Obviously same will now happen to the metal frame of the trains, if you strengthen one area and same forces are applied then the remainder gets more flexing force (force is concentrated over smaller length)
So clearly if the other parts were not specified with a large margin then there is more risk on the remainder of the frame. But we now know there wasn’t sufficient margin and parts cracked, and if no one has used sensors on a selectively strengthened frame, how can anyone know how the real world forces act on the remainder, if certain parts that were absorbing some of the force are now rigid and unable to absorb any movement.
This is a good point. Many years ago I was involved in investigating the reasons for a large number of broken springs on Vale Of Rheidol coaches when the line was owned by BR. The original springs were breaking and been replaced with new springs of a thicker section and instead of solving the problem the redesigned springs were also breaking. The reason for the failure of the redesign was that the springs had higher stresses as a result of the reduced movement allowed by the larger thickness. This had not been realised when the new springs were manufactured. The solution was to use a different steel to pretty much the original dimension.
Interesting thoughts. A case of moving the problem around and not addressing the basic cause. The least one can hope for is that the problem can be moved to components that are easily replaced. Now what would they be on a 80x ?.
Another twist. In this case could the stronger springs have pushed the problem onto less easily repaired/replaced components ?.
Of course, perish the thought, but maybe the permanent way needs to be kinder to the 80x ?. Are the culprits just a few rogue locations on the network ?. Not really the fault of the network of course and not a fault of the original spec it seems BUT maybe that is the cheaper solution overall ?.
Catching up with a few thoughts on this thread. [as an engineer not directly involved]. This is plenty in the public material when read carefully with an expert eye.
Problem stream A
1. At the design stage only new wheel sets were modelled with network rail data.
2. Recent on board measurement have shown new wheel set forces to be inline with modelling.
3. Worn (they don't directly specify just wear or potentially diameter reduction from wheel turning as well) reduced wheel sets were measured to exert higher forces than modelled. With the measured forces exceeding problematic levels in modelling.
4. NR track data realistic enough.
e.g. design/modelling fail
Problem stream B
5. Aim to standardise bogie designs across AT200 and AT300, including both low and high floor designs on the AT300.
6. Handle variation in floor height on AT300 using different damper brackets / suspension components with the unfortunate effect of increasing the loads in the problem areas on high floor vehicles (replacing the bogies on the high floor designs and having a lateral damper and anti roll bar mounting further above the ground level would help)
e.g. standardisation /cost reduction fail
Problem stream C
7. Choice of particular 7xxx series alloy
- Japanese developed alloy without a 7xxx ISO designation only manufactured in Japan, relatively new alloy only sold this century. Nearest ISO alloy is probably 7005 but still significant differences
- recent history of SCC issues and investigation research papers post 2016 on it (lots of Chinese authored papers) which suggests others are having issues.
- very little use out side Japanese specified products
- design choice optimisation of the alloy appeared to heavily focus on manufacturability over other parameters
8. Choice of T5 heat treatment regime
- makes manufacturing easier and substantially cheaper
- sub optimal choice for strength, fatigue, fracture toughness and SCC
- major questions over why not T6 with induction based solution heat treatment (else the same as T5)
- T5 is well known for increased SCC problems compared to alternatives
e.g. cost minimisation fail
Problem stream D
9. Mechanical design of bolster etc.
- includes several features with long history of enhancing fatigue issues (fix has learnt lesson here)
- failure to taper stiffness of structural elements in the design e.g. stiffness of solid bolster elements is much greater than largely hollow extrusions. Stiffness of "add on" elements needs to be tapered so there aren't large variation in stiffness at component extremities compared to bodyshell
10. Lack of attention to specifying fatigue reducing finishing in manufacturing.
Problem Stream E
11. Modern 2 pack paint systems can be very hard / stiff compared to traditional paint systems but many design engineers don't realise this. Work needs to be done to reach a sensible compromise on paint stiffness. This issue is also seen in composite structure so is not unique (see Airbus A350 issues).
12. Modern 2 pack paint systems need careful priming on aluminium which appear not to have happened
e.g. design fail
Problem Stream F (minor in comparisons to the others)
13. Not removing chlorine from problem areas regularly enough
e.g. maintenance regime (specification) failure
No single causes of problem but classic swiss cheese hole alignment
Peter Sarf
Croydon
Problem stream A
Problem stream B
Problem stream C
Problem stream D
Problem Stream E
e.g. design fail
Gosh @hwl, you have done your homework there. That has pulled a lot of issues together !. Thanks for a rather absorbing post.
My first thoughts (sorry not carefully considered) -
1) It does remind an old soul like me that maybe we are trying too hard to reduce costs. Logically a gradual trend away from (alleged) Victorian over engineering (ignoring the Mk1 Tay Bridge) was always going to end in tears one day.
2) Of course a modern engineer might hope that software will some how overcome some of these problems. Well maybe automatically easing off the power and/or speed at tight spots on the network.
3) Tongue in cheek I could also blame the infrastructure for straying too close to the sea (Dawlish diversion anyone ?).
Hats off to you for an interesting post.
43096
23 Nov 2015
No doubt Hitachi/Agility were trying to reduce costs, but that wasn't passed on to the customer - the 800/801 fleets are the most expensive trains ever built for the UK, and are excessively so.
PG
Gone are the days of Gaffer tap
I'm just waiting now for someone to counter this, after all Formula 1 motor racing, at the cutting edge of technology isn't immune to the odd bit of Gaffer tape!
Doesn't exactly inspire confidence knowing it affects multiple locations...
Thanks for your expert eye explaining things to us here, very useful. Almost tempted to say forward onto Hitachi UK and Japan!
5ArchBridge
9 May 2021
Darlington
I firmly believe these will be withdrawn before they’ve had 10 years service.
Just wait until the next issue with them comes out…
CBlue
30 Mar 2020
East Angular
A shame lessons weren't learned from this, perhaps....however it does rather disprove the flannel posted on here on occasion that there were never any problems with the stock the 80x replced.
DanNCL
17 Jul 2017
County Durham
I’m not sure it’ll be that soon - the oldest have already had 5 years in service. However I agree it seems unlikely they’ll last their supposed design life.
Horizon22
Jobs & Careers
8 Sep 2019
No of course - if there's a flaw there's a flaw, but seems perfectly prudent to cover all bases first.
GC class B1
19 Jun 2021
East midlands
The finding that the measured forces on the bogies are higher with worn wheels is interesting. I have noticed that the ride is poor and the bogies are prone to hunting on the East Coast Main Line. I would expect that a poor ride quality resulting from bogie instability (especially hunting) would be associated with higher forces being exerted on the bogies as the dampers attempt to control the bogie movement, particularly the yaw dampers. Worn wheel profiles are a significant factor in bogie instability so I wonder if that is why the worn wheels resulted in higher bogie forces rather than a reduction in wheel diameter as it is hard to see how smaller wheels would significantly increase the forces on the bogies.
Irascible
21 Apr 2020
Dyfneint
Problem stream A
*facepalm*. Well I didn't consider that one but I've not been any form of engineer for a long time, but now you bring it up... how can anyone be that naive. Fixable with increased maintenance costs, at least.
fgwrich
15 Apr 2009
History is littered with examples...
But whose maintenance costs - NR's or Hitachi's?
Me wonders if Hitachi might be in the market for some extra wheelsets... Were they made in-house or by an external supplier?
Or the taxpayer if Hitachi are clever enough and have caught the DfT napping again… It’s not as if they’ve previously tried to pass the blame already.
Irascible
21 Apr 2020
Dyfneint
Smells of large legal battle, to be honest - is a train Hitachi supply from maintenance with worn wheels out of spec? does normal wear & tear count as staying in spec & does wheel wear count as "normal"? mind you the more I type this the more it's feeling like Hitachi... if they're contracted as I vaguely seem to remember to provide X trains fit for purpose then the DfT might have got away with this one.
I am very much not a lawyer & haven't seen the contract either, so that's just naive questioning.
MadMac
13 Jun 2008
Moorpark, CA
The MAN engines built under licence by NB Loco had numerous problems in no small part due to a somewhat liberal conversion from Metric to Imperial.
This might be one of those legal vs brute force arguments
Hitachi might want to avoid wheel wear, so are incentivised to use the hardest steel they can for the wheels, and Network Rail won’t be too keen if super hard wheels start wearing their expensive to maintain manganese steel crossings
But I have no idea what the contract specs say
GC class B1
19 Jun 2021
East midlands
Wheel wear is normal and a result of steel wheels running on steel rails and all steel wheels will wear. If bogie instability is part of the reason for the higher bogie forces with worn wheels then the long term solution is to modify the bogies and not to change the steel used for the wheels. In the short term regular wheel reprofiling may be necessary to improve the ride and hopefully reduce the forces on the bogies.
hwl
5 Feb 2012
1. They say "wheel wear" rather that "profile degradation" or "diameter reduction" which suggests they expect it is a bit of both...
2. Normally I'd go "profile degradation" being the main cause...
3. ...but worth bearing in mind that the rotational inertia of the wheelsets will be 10-12% lower on modern (small diameter) wheelsets after 4 trips through a wheel lathe which means the bogie will be more prone to moving around (and faster) in both planes (including hunting) when the diameter is getting near minimal. The lateral damper and anti-roll stiffness and speed of response may need to be tuned (optimised) for heavily worn or half worn diameters rather than half worn/new.
The bogie derailments in the Neville Hill incident suggests fairly high stiffness and slow speed of response. A fairly low stiffness, low displacement fast response element in addition might be useful.
Same wheelset supplier (and steel) as most other UK rolling stock, the problem is elsewhere...
dgl
5 Oct 2014
Of course the big point to note is that no other rolling stock built to the same standards as the 80x is having similar issues, to me that would clearly point to Hitachi being at fault, it's not like Hitachi have no experience with the UK rail network as we have the Javelins.
GC class B1
19 Jun 2021
East midlands
I generally agree with your assessment of the effect of wheel wear on the bogie input forces with the exception of the reduction in wheelset rotational inertia as a result of wheel diameter reduction with reprofiling. The wheelset will comprise the wheel centre, the axle, axle bearings, brake discs and the transmission on powered axles. To be specific of course only the rotating elements of the axle bearings and transmission add to the rotational inertia. Reprofiling the wheels will only reduce the mass of the wheel centres, the remainder of the wheelset mass will not change so I am not sure that your figure of 10-12% reduction in rotational inertia is correct.
Taunton
1 Aug 2013
There is of course a long history on new wonder-bogies turning out not quite right. The BR B1 of the early 1950s also was satisfactory when new, but deteriorated rapidly. The Mk 4 stock of 1990 on the ECML had new, Swiss-designed bogies to give perfection, but notably didn't. I've always felt that the key determinant is the overall weight of the vehicle, and we try and run at speed with lightweight vehicles - in the USA, where coaches of twice the UK weight are not uncommon, and the differential used to be even more, they seem to have readily overcome performance over indifferent track. We build with aluminium to give corrosion protection; the USA commonly uses expensive stainless steel, and sticks an extra locomotive on for the weight.
When it comes to bogies-versus-track, it's a good excuse for rolling stock designers that "the infrastructure isn't good enough", but they have to accept that the permanent way is what it is, and work with that. Likewise for my car, I can't stick the cost of any broken springs on an invoice to my highways department at the council, the road is as I find it, and if I live at the end of a rough farm track I have to either accept the car does get shaken apart, or buy a Land-Rover which is designed for it.
Trainbike46
18 Sep 2021
belfast
There are really good reasons not to copy the US approach here though:
-higher weight trains cause more wear on the infrastructure
-Not all bridges/other structures may be designed for the higher weight
-Heavier trains use more energy
-Heavier trains accelerate more slowly, and may not be able to keep to time
-In certain types of crashes, heavier trains are LESS safe
-As you already point out, heavier trains can be more expensive to build
I'm also not sure why you believe heavier trains would have helped with the 80x hairline cracks issue?
Overall I think it's good that we go for light-weight rolling stock here
Wolfie
17 Aug 2010
I agree. Can you imagine the same philosophy Taunton espouses being applied to aircraft?
