- Joined
- 15 Apr 2008
- Messages
- 16,130
Needs wholesale re-signalling to get rid of the block sections if you are going to do it properly.
Before rushing into stopping more trains, it might be wise to think about the reasons for this. For one, many of the HV stations don't have ticket machines, and coming back towards Sheffield from there it can actually be quite hard to buy a ticket even if you try, so some more ticket machines would help. Adding to this, Northern (despite the threatening notices on the trains) are quite happy to sell tickets on the trains, so most people will just chance it and pay if the guard reaches them (which they generally don't). Proper ticketing facilities coupled with a proper penalty fare scheme would go a long way to fixing this problem.
Whilst I don't imagine that it's a huge passenger flow, one would have to go via either Sheffield or Manchester Piccadilly most of the time. I personally hope that the 3rd Sheffield to Manchester fast would call at Sheffield and Chinley, perhaps even with peak time calls at Hope or Hathersage, but I may be dreaming here!
Indeed, even the old signal boxes are still going (or at least I think they are?). One wonders whether you could put a signal half-way down the tunnel, or are trains not allowed to stop in the tunnel? It's probably made worse by the stop at Grindleford which I think falls into that block as well.The sections through Totley and Cowburn tunnels, and probably most of the Hope Valley, seems to have remained virtually unchanged since the Dore & Chinley railway was opened in 1893! At least the section from Dore West to Earle's sidings is to be resignalled as part of the HVCS, although how much will actually be changed remains to be seen. Not a lot one suspects.
The time currently allowed to clear the 60 mph limited 3.5 mile Totley tunnel between Grindleford and Totley Tunnel East is at least 5 minutes, another choke point on the line.
Not usually one to quibble with The Planner's informative posts but to be completely clear we Hope Valley travellers need more block sections, not their abolition! "One engine in Hope Valley" operation? No thank you.Needs wholesale re-signalling to get rid of the block sections if you are going to do it properly.
Although the ability to get past a stopper around Bamford might be useful during disruption, I’m not convinced that it’ll help the freight situation as you describe. The signalmen over there seem to do a pretty good job of regulating stuff with the limited options available to them already. It’d be difficult to identify a decent margin (other than its booked path!) for a freight onwards from Dore at the time that it leaves Earles or Bamford - a lot can happen in the intervening time. A laden freight getting away from a loop at Bamford will immediately face a harsh rising gradient that, whilst easing, continues through into Totley Tunnel. It’s 15mph, with the attendant approach control arrangements, around the curve at Dore anyway, so any advantage over looping on the approach to Dore West is immediately lost anyway. Far better to get freights there, with somewhere to get them out of the way of following traffic, until a suitable margin exists that they can drop virtually straight into. It is a challenge at the moment, as you say, with no potential to hold them on the curve itself, so there’s often no way to deal with the situations without hammering at least one passenger train.However, a laden stone train heading away from Earles Sidings may have to be held on the tracks before Dore West Junction until it's path is clear round the tight curve through Dore Tunnel and across the mainline at Dore South Junction before entering Bradway Tunnel en route to Chesterfield and places beyond. That's two lines it has to cross, Manchester westbound and Sheffield north bound. If the timings are wrong it may mean holding trains on either line to let it cross. If it's not allowed to cross it will hold up eastbound Hope Valley passenger services so it needs to be released from Earles with fine timings.
At present Earles is signalled from Manchester. Dore West is from York. When the scheme is complete York will control from Earles Sidings eastwards. That should help to co-ordinate matters better.
A loop is to be constructed to the west of Dore West Junction to allow a freight service to stand there off the main running tracks while it waits to pick up a clear path in either direction. For an empty service returning light towards Earles that should be fine. The tightness of the curve between Dore West and Dore South junctions, plus the uphill grade towards Bradway Tunnel, will make a hard pull for a locomotive hauling a full load that may have to stop in the loop and on that curve.
The loop at Bamford will allow a laden freight to wait a little further back so it can get a better run either through Dore & Totley station and Sheffield, or via the Dore curve to go south. (It could also be used to allow an eastbound stopping train to be overtaken by a fast service, a facility which will not be available for westbound services.)
The Dore loop may not be long enough for the longest trains, so some may be limited by that constraint.
Quite possibly the Earles-Walsall cement train, which I often see tucked tightly onto Dore South Curve. (It is slightly confusing to refer to it as a 'loop' in relation to this thread which is also about 'proper' loops at Bamford, etc.)Couldn't that in principle be fixed by just extending the loop a bit, either towards the Hope Valley or towards Chesterfield - running the extension it as a new single track alongside the existing tracks?
Incidentally (and somewhat ironically for this discussion) Google maps actually shows the loop with a freight train on it! That train is pretty long (I'm guessing just over 30 wagons) but clearly (just) fits on the loop, and I be surprised if the longest trains were much longer than that, so I'd surmise that you wouldn't need to extend the loop by very much to fit all trains on it.
I meant the absolute block, Im not sure why you thought I would make it worse...Not usually one to quibble with The Planner's informative posts but to be completely clear we Hope Valley travellers need more block sections, not their abolition! "One engine in Hope Valley" operation? No thank you.
It's something to do with the safety clearances at either end of the train, but no, the loop can't be extended in the deep cutting towards Chesterfield, or towards the Hope Valley due to the bridge carrying West View Lane and the flats immediately beside it. Residents are annoyed enough about the loop already. It was accepted at the public inquiry that the longest trains operating wouldn't fit in, but I think they may be running at night. See after construction picture, plan from the public inquiry and how it looks now.
Incidentally (and somewhat ironically for this discussion) Google maps actually shows the loop with a freight train on it! .
OK I see it's an extension of the south chord, with about 600m standage as far as I can tell. I was thinking about a 'right turn lane' between the Totley tunnel and the West View Lane bridge, thus:
I’m not sure what restrictions are currently placed on its use, but the minimal distance available beyond the signals at each end must make it a pain to use in practice (so, even if a train from the Valley would fit inside clear, there’d have to be a margin on the Down Main from Chesterfield, which would foul the overlap, to just to be able to signal it onto the curve).
Interestingly if you follow that Google map north to the station you'll see the car park is full with 4 cars parked out of marked bays, but not one in the 7 disabled bays. Probably pictured about 11.00 from the shadows. That's normal with up to 100 cars for rail users parked on surrounding roads and spare land.
That land has also struck me as the only available place for an expansion of Dore's car park, which would be needed in many of the more ambitious proposals on here (although I reckon all three could be accomodated with a bit of engineering). I assume the land is owned by Network rail, they must be saving it for something as it would fetch a fair bit for development otherwise!Sounds reasonable to me, but I'd have wanted them to extend the loop alongside the track out of Sheffield from the Twentywell Lane over bridge to allow for overtaking there. That might also allow to hold stock from a passenger service running up to terminate at Dore before returning in the Sheffield direction. The land beside the junction is flat, although part is earmarked for a sub-station for eventual electrification of the MML.
They moved a Morrisons to expand the diesel depot at Penzance, so rebuilding a Tesco isn't beyond the realms of possibility.
Panel photos (and Simsig!) suggest that the overlap at both ends covers the first track circuit in advance of the signal, in both cases taking it out over the junction.With a maximum speed of 15mph on the chord, clear overlaps at either end can be as short as 50m, which appears to be the case at the south junction today.
Why do anything? If we are going to do something (anything) worthwhile about reducing CO2 emissions then people are going to have to get used to the idea of walking, cycling or getting a bus to their station. Dore, Dorridge or Dorking, we have to de-carbonise. I'm sure it's no coincidence that obesity and diabetes have ramped up since we (some people anyway) learned to expect central heating and never leaving the house other than by car.As for car Parking at Dore Station would it not be easier to double deck (triple deck?) on the existing site rather than find more land for parking?
Whilst being in sympathy with the underlying point about sustainable and environmentally friendly access to railheads have you ever actually been to Dore (or other stations along the Hope Valley line)?Why do anything? If we are going to do something (anything) worthwhile about reducing CO2 emissions then people are going to have to get used to the idea of walking, cycling or getting a bus to their station. Dore, Dorridge or Dorking, we have to de-carbonise. I'm sure it's no coincidence that obesity and diabetes have ramped up since we (some people anyway) learned to expect central heating and never leaving the house other than by car.
https://www.simsig.co.uk/Media/Wiki...field/sheffield-modern-signal-number-plan.pdfPanel photos (and Simsig!) suggest that the overlap at both ends covers the first track circuit in advance of the signal, in both cases taking it out over the junction.
My bad, I thought there were two tracks towards Manchester, the second omitting the platformWell, since all trains pass through the said platform, I'm not sure how that logic works.
...suggests that there's actually quite a bit less than 50m available to the fouling point, so presumably the signal would have to be moved back (which, in turn, might present some problems - not insurmountable - with the proximity to the short tunnel on the curve). Either way, the ability to get one onto the curve to stand to await a forward path, in either direction, without interfering with traffic at the far end is surely an essential part of any lengthening work, and indeed one of the most beneficial parts of the whole scheme!
As for car Parking at Dore Station would it not be easier to double deck (triple deck?) on the exisitng site rather than find more land for parking?
Thanks for that - I didn’t know it was owned by SCC. A car park there would be feasible, even a double or triple decked one would be doable with excavation without the eyesore (and strong local opposition) that would arise from attempting to add a deck to the present one. It would however need probably two sets of traffic lights installing, and perhaps even a full reworking of the Twentywell Lane junction - it’s bad enough as it is!Earlier I mentioned that a feasibility study had been made into restoring the mainline platforms at Dore. That envisaged substantial extra parking provision. Two options were suggested, both already mentioned here. Costings were vague. Adding two extra decks to the current car park would just about cope with demand for the 2 platform station and it's services anticipated after completion of the HVCS! One extra deck would be full by the end of September if word got round that it was available now.
What is locally known as the railway triangle is not flat. It's spoil dumped during the building of Bradway tunnel and the Twentywell cutting leading up to it. The land is owned by Sheffield City Council and managed by their Parks and Open Spaces department. They let part of it to Network Rail for rail maintenance purposes, a nice little earner. More of that area is to be used by Network Rail as their principal construction site during the planned works at Dore (although half of the works are in Bradway). Some levelling is likely and the illustrations in the material for the public inquiry show a flat area left at the end, just right for - a car park! However, parking is NOT part of Network Rail's remit and they made that very clear at the inquiry.
That was identified in the feasibility study as a possible site for a large car park, almost 500? It would be easy to excavate if even more space was ever demanded.
Snags? For both options, opposition to more local traffic. Opposition to any encroachment into the green visual and natural environment around the station. Cost. At present SYPTE have a free park and ride policy. They may want to do one of these options, but where's the money? For the triangle option access raises road safety concerns.
The effect of charging would be to push parking further from the station on public roads - and Manchester bound commuters would be more likely to pay. At least there'd be space for those staying a few days/weeks while away on business or pleasure trips from Manchester Airport, a growing practice.
Artist's impression of now, from public inquiry.
Artist's impression immediately after works completed.
Artist's impresion after nature has started to reclaim the plot.
Thanks for finding those! I would imagine a 4-car platform for turning round sprinters could be squeezed in with maybe a little re-alignment, although there are few actual plans beyond this forum at the moment I don’t think.For those who have mentioned a possible third platform at Dore here's the plan for the second platform as submitted to the public inquiry. Sorry I didn't copy absolutely every plan available. Unfortunately it's almost certainly too late to get Network Rail to change anything much, especially if it needs more money! However, a little careful positioning might have got a third platform alongside the mainline, rejoining the westbound line at the south end of the station to make a loop. The old island platform was wide enough for a large shelter including a W H Smith's shop.
At the north end there used to be quite a major junction with signal box. A line off the westbound track just south of Dore station junction would only require one set of points to bring a track up to the north end of the planned platform 2. See an extract from an old OS map of that area.
Here's a less detailed view, also showing where 5 sidings were used to store empty coaching stock for summer special trains.
