Hull Trains services formed of two sets
Sad Sprinter
5 Jun 2017
Way on down South London town
I saw a double unit Hull Trains service run through Hitchin yesterday at about midday. Is this normal?
Never saw it before, but the two 802s coupled together made a fine sight.
Wouldn't a double working cut down on the amount of stock for services later in the day?
I saw a double unit Hull Trains service run through Hitchin yesterday at about midday. Is this normal? Never saw it before but the two 802s coupled together made a fine sight. Wouldn't a double working cut down on the amount of stock for services later in the day?
They have five units, and need three to provide the timetable if everything runs as a single unit.
Therefore, Hull Trains are able to double up on one diagram, while still having a maintenance spare, which they typically do over the weekend.
The units are based at Bounds Green, but the main flows are away from Hull, so some positioning moves are needed as well.
AirGamer
18 Jan 2022
Hull
I've been on one of the doubled-up services
I recall at one of the stations (Howden?) the train being longer than the platform and ended up blocking the level crossing when stopped
Failed Unit
26 Jan 2009
Central Belt
I think they have 10 car daigrams on Friday as standard. Not sure specifically which trains, but you often do see a 10 car on Fridays (an weekends) more likely today as I suspect demand is higher with the engineering works at the weekend.
Barnsley
20 Feb 2010
Barnsley
Hull train run 10 car formations on the 0824 from hull and return and the 1508 and return on Thursday Friday and Saturday, one unit goes ecs to Beverley, then the other unit shunts out of the sidings into Platform 7 where the unit from Beverley couples to it, the train is too long for the platform but is behind the signal, platform 7 is to be extended, Hull trains units stable in sidings C D and E overnight at Hull
