Hydroflex - testing
norbitonflyer
24 Mar 2020
SW London
Another issue is that hydrogen's production process is very 'un-green' - it requires fossil fuels to produce it.
Any source of electricity will do to make hydrogen and, unlike a straight electric but like a battery it can be generated any time, using surplus off-peak generating capacity, with thge energy stored (as hydrogen) for use later.
Orkney generates more electricity from the wind and waves (of which it has a super-abundance) than it can use, and uses the extra to make hydrogen.
23 Nov 2015
Not if it is produced by electrolysis, and that electricity is from renewable sources.
It's still a hugely inefficient process that needs lots of energy to produce - hardly something to aspire to. Further, you need almost three coaches of train for two with passengers in - again a waste in terms of use of resources.
Get the wires up!
Also from a personal point of view would rather see the HML with hydrogen powered trains than spoil the beauty with OLE.
The railway is a transport system, not a fairground ride! We should de-carbonise it in the most efficient way possible.
Journeyman
16 Apr 2014
Not impressed by the miserable, negative comments here. It's a big step forward, and as such it deserves some praise. Yes, there may be issues with this initially, but I'm sure the 50mph thing isn't a hard limit, and converting existing rolling stock is always going to present issues that won't be present if building new.
Mikey C
11 Feb 2013
Another converted 319
In 20 years time I look forward to another 319 being used to demonstrate a Nuclear Fusion powered train :E
It’s not that inefficient. About 70-80% to produce the Hydrogen. And if it’s from renewables that would be otherwise unused (as is increasingly the case on these isles), then it’s ‘free’. Sort of.
Nevertheless, batteries will be better for most applications.
spark001uk
20 Aug 2010
Did I hear the BBC reporter right? It takes most of a day to fill the tanks?
Really??
Bevan Price
22 Apr 2010
Hydrogen needs to be handled very carefully. See the data sheet here, for example:
And note the bit about storing containers away from direct sunlight, so cylinders on a train roof is a bad idea. Also note the hydrogen/air explosive mixture limits. To me, hydrogen can be potentially used safely - provided nobody involved with use / maintenance gets a little careless. Badly fitted control valves, and worn/leaking connecting pipes are potential problems. Hydrogen gas molecules are very small (compared with oxygen/nitrogen) and can easily "escape" through even minor defects in the supply system.
ABB125
23 Jul 2016
University of Birmingham
Amongst other things, yes!
Must have been a rather expensive form of transport!
On the subject of safety, I'm told that space rockets are the safest mode of transport on a casualties-per-mile basis. They happen to be filled with very flammable fuels, and rather more of it than a hydrogen train.
Journeyman
16 Apr 2014
Probably only because of the vast distances involved. The Space Shuttle seemed terrifyingly lethal - two out of five lost, with 100% casualties each time.
Yep, about £7k one way in today’s cash.
Re space rockets, I always think casualties per mile is a poor measure of transport safety.
It should be casualties per hour of travelling.
Meerkat
14 Jul 2018
Why? A journey is X miles.
Whilst Hydrogen escapes upwards etc, this assumes it doesn’t escape inside the train
3 Sep 2020
Dublin
To me, 61 crew seems absolutely extraordinary - what did they all do? Make cocktails at the on-board bar?
"Only" forty of them were the regular crew (remember that 1930s rigid airships needed, among other things, an engineer to work each individual engine, and most of the crew stood watches, as on a ship, so there were typically three people for each position). The others were on board for training or as observers. See https://www.airships.net/hindenburg/disaster/crew-list/ and https://www.airships.net/hindenburg/flight-operations-procedures/#crew.
Energy
29 Dec 2018
Why do some on here try to say that it wasn't hydrogen gas that was the cause of the Hindenburg fire? Is it because hydrogen is considered green and therefore immune from any criticism?
No, its because the skin of the Hindenburg was made of the same ingredients as thermite, which burns at very high temperatures, these ingredients were only separated by a thin sheet. Mythbusters (American TV show) looked into this and decided that it was a mixture of the skin and the hydrogen, the Hindenburg didn't burn like hydrogen does.
ABB125
23 Jul 2016
As they say, there's lies, damn lies and statistics! You can prove anything with statistics, including opposing arguments with the same data...
Thanks, that's very interesting.
GRALISTAIR
11 Apr 2012
Dalton GA USA & Preston Lancs
Get the wires up!
EXACTLY my thoughts too. Hugely inefficient.
Requeststop
21 Jan 2012
Port Moresby, Papua New Guinea
How much heat energy is expelled into the atmosphere per unit burned compared to say methane, gasoline, diesel, or heat energy expelled from an electric engine? It's not just about CO2 emissions.
If the electricity to produce the hydrogen was generated from renewables then it would otherwise have been warming the earth by exactly the same amount, either by solar radiation or by friction between the wind and other objects. So there's no net extra production of heat, unlike fossil fuels. But I've never heard anyone saying the heat is the problem, as a slightly warmer planet just radiates that bit more into space (if the CO2 in the atmosphere doesn't stop it).
Philip Phlopp
31 May 2015
I don't think there's much heat energy - the fuel isn't burned as such, it's reacted in a controlled manner to generate water and electricity in a fuel cell, I don't think they even get as hot as a normal diesel engine - the water certainly comes out at room temperature.
Because travelling is just another activity in the smorgasbord of life. And life is measured in time.
If I spend an hour walking at 6kph around the rim of an active volcano, and another hour cycling around it at 24kph, my risk of not making it out alive is exactly the same at the end of the hour. Measure by distance, though, and the bike is 4 times safer.
Meerkat
14 Jul 2018
That would make sense if travel was a leisure activity in itself, but it is a way of covering a distance - so the valid comparison is what is the safest way of getting from a-b.
Otherwise it might be safer to run across the rail tracks than to walk over the footbridge.
Northhighland
19 Aug 2016
Get the wires up!
Wrong on both counts. One of the issues with renewables is what to use the energy produced at night. Perfect for making hydrogen for use in transport. If hydrogen is produced using water and electricity it is a truly sustainable environmentally friendly fuel.
As to the Railway and decarbonisation I would agree doing it in the most efficient way. At present it isn’t economically viable to electrify to Inverness. Doubt it will any time soon.
Hydrogen technology is still being developed. It will improve and has huge potential. I feel you are one of Henry Fords faster horses type.
philthetube
5 Jan 2016
I'd take diesel over hydrogen any day. Remember Hindenburg?
Can't say I do, however the deaths on Hindenburg were largely caused by the airship dropping out of the sky, something which trains do not often do. The hydrogen had departed and it was the burning ship which burnt the passengers.
Largely yes, it was a luxury form of transport, even in the 1970's the Canberra had a crew ratio of one to every 2 passengers.
The Queen Mary carries 2695 passengers and 1253 crew
43096
23 Nov 2015
Posting opinions as facts - which is what you have done - doesn’t make me definitively wrong.
I feel you haven’t a clue as to what I think. Electrification is the answer wherever possible as it is fuel source independent: as long as we can generate electricity from whatever source, an electric railway can operate. As for Inverness, if the Germans can make a case for Munich-Lindau wiring, north of Perth ought to be justifiable.
