They can be fitted fairly easily, they have to on all modern 3rd rail units, also see 350/1s.I would expect that these units do not have transformers or rectifiers etc. fitted. So the conversion would not be that straight forward.
Indeed. Why Class 70 diesels when that range was for DC electrics? Vanity, if nothing else. My class number is bigger than yours...Trying to apply logic to TOPS classification is a fool's game
Could they, once you factor in multiple unit vehicles in that number series?Yes they could have gone for anywhere between 61 & 65 but no, class 70 it was. Stupidity strikes again.
Surely vehicle numbers are exactly that, vehicle numbers as distinct from locomotive numbers - HST power cars were originally vehicles numbered in the 43xxx series in units of classes 253 and 254, they later became designated as locomotives as 'class 43' although that class had previously been used for Warships.Could they, once you factor in multiple unit vehicles in that number series?
And had been used for DC electric locos, the 3rd rail electric locos designed by OVS Bullied were known as class 70.Why Class 70 diesels when that range was for DC electrics?
Previous discussion has suggested it certainly isn't easy - the only thing you wouldn't have to do is cut lumps of roof off to fit the pantograph but everything else would be needed. The 350/1s are a complete misnomer having been designed as dual voltage units - it just shows that it is possible (and gives you a starting point for the design), not that it is easy
Locomotives are vehicles, so in your example HST power cars are still considered to be vehicles in the 43xxx series. The separation is between vehicle numbers and multiple-unit numbers.Surely vehicle numbers are exactly that, vehicle numbers as distinct from locomotive numbers - HST power cars were originally vehicles numbered in the 43xxx series in units of classes 253 and 254, they later became designated as locomotives as 'class 43' although that class had previously been used for Warships.
When introduced they were designated as multiple units and numbered in the multiple unit number series, trailers 40xxx, 41xxx, 42xxx, power cars 43xxx as class 253/254 units.Locomotives are vehicles, so in your example HST power cars are still considered to be vehicles in the 43xxx series. The separation is between vehicle numbers and multiple-unit numbers.
There is no multiple unit vehicle number series. Locomotives, carriages and multiple unit vehicles all shared the same 3, 4 and 5 digit number series. Wagons (and now, new multiple unit vehicles) have numbers with 6 digits.When introduced they were numbered in the multiple unit number series, trailers 40xxx, 41xxx, 42xxx, power cars 43xxx as class 253/254 units.
Back in the 70s when HSTs were introduced there were separate number series for hauled stock, DMU and EMU stock.There is no multiple unit vehicle number series. Locomotives, carriages and multiple unit vehicles all shared the same 3, 4 and 5 digit number series. Wagons (and now, new multiple unit vehicles) have numbers with 6 digits.
Why do you think Colas's Class 66s have been numbered 66841-850? Because there are Class 350 and 450 multiple unit vehicles also numbered in the 66801-840 sequence.
however the likes of Wikipedia like to describe the 700 range, it’s basically just ‘anything built fairly recently or coming soon, but not quite everything’
Unit Type | Class Allocation |
AC and AC/DC electric multiple-unit sets | 300 – 399 and 700 – 749 |
Multi-mode*A multiple-unit sets | 750 – 799 |
800 is DFT programmed as is 801, but I can see 805 and 807 being reclassified as 802 and 803 with the current non IEP 802s and electric only version for ECT. After all, they did that with the 711s becoming 720, and I believe the 701s were also supposed to be two separate classes for 5 and 10 coach version.I know people will say it doesn’t matter, but someone should have kept a tighter control on the numerical allocation of new types as it is now all over the place, and however the likes of Wikipedia like to describe the 700 range, it’s basically just ‘anything built fairly recently or coming soon, but not quite everything’
There is only the DMU sequence which works well, with similar types generally next to each other, and the higher the number generally meaning the newer the stock.
The fact that identical builds get a whole new number is annoying as well. Imagine if they’d done that with the 170s considering the amount of different builds they got, surely minor differences should just be xxx/1 /2 etc. 802s, 803s etc should really be 800s?
Opening that old can of worms again..There is no multiple unit vehicle number series. Locomotives, carriages and multiple unit vehicles all shared the same 3, 4 and 5 digit number series. Wagons (and now, new multiple unit vehicles) have numbers with 6 digits.
Was being the operative word, like “is” in my original statement. The addition of units and coaching stock to computer systems was done nearly 40 years ago and saw various renumberings including HST TRSB vehicles from 400xx to 404xx to avoid a clash with Class 40 locomotives. Likewise DMUs in the 50xxx and 56xxx series and NPCCS in the 81xxx and 86xxx series etc etc etc.Opening that old can of worms again..
There WAS a series for the HST. As stated 4xxxx. It may not be the case now but it was until the late 1980s.
An example is the 44xxx TGS clashing with class 44 locos.
One an unpowered trailer and one a loco. No chance of a TGS being rostered to haul a Toton coal train!
Hitachi units post-802 do have some significant changes, compared to the 800/801/802. Different mechanical specifications, and the 803s are not fitted with any diesel power packs.The fact that identical builds get a whole new number is annoying as well. Imagine if they’d done that with the 170s considering the amount of different builds they got, surely minor differences should just be xxx/1 /2 etc. 802s, 803s etc should really be 800s?
Class numbers have been recycled before - classes 41 and 43 being the best known examples, and with no dc locos remaining except the 73s (which are essentially diesel locos now) and the 60-69 block rapidly filling up expanding into the 70s seems the obvious thing to have done. No-one seemed to object when the class 87/2s were reclassified as class 90 before any had actually been built.Indeed. Why Class 70 diesels when that range was for DC electrics? Vanity, if nothing else. My class number is bigger than yours...
All coaching stock (except pre-nationalisation designs), including multiple unit stock, was numbered in a single number series, but dmus, demus and emus had separate blocks within that series - 5xxxx (and 79xxx), 60xxx, and 61xxx-78999 respectively. HST vehicles were given their own block in the 4xxxx range, recently vacated by the last BR-design non-corridor hauled stock, made redundant by the GN electrification scheme. Other blocks were:Back in the 70s when HSTs were introduced there were separate number series for hauled stock, DMU and EMU stock.
But lucky that they picked a 7xx number in the half that they'd be classified as anyway.The 777s got the number before the 750-799 being multimode rule was put in place. They were told they could have any number in the 7xx range so they picked the nice number of 777, no other reasoning.
I doubt the would be classified in that half, they aren't getting batteries from new and even if they did I doubt batteries alone can classify it as multi mode.But lucky that they picked a 7xx number in the half that they'd be classified as anyway.
They are DEMUs which are in the 200 range (220/221, 230, 231)Is there any significance why Voyagers are 220/221 rather than in the 100s (probably would have been 180/181s)?
I thought they were getting batteries...I doubt the would be classified in that half, they aren't getting batteries from new and even if they did I doubt batteries alone can classify it as multi mode.
Clarification: They are getting batteries for depot work only. There is an option to fit batteries for non-electrified work should Merseyrail/Merseytravel want it but it will not be fitted from new. I doubt either are enough to classify it as a multi mode unit.I thought they were getting batteries...
That's it. The batteries can be a source of traction power so the 777s qualify as being multi-mode.A multi-mode unit is one with two or more sources of traction power, at least one of which is external.
Which makes the division of the 700 series into multi-mode and pure electric redundant then, as all pure electric units delivered in the modern day are capable of having two sources of traction power - third rail and OHLE. Usually they don't come with shoegear if they don't need it, same with a pantograph, but they're still theoretically multi-mode unitsThis is the numbering standard's definition of a multi-mode unit.
