Incident at Talerddig, Wales - 21/10/2024
bahnause
30 Dec 2016
bülach (switzerland)
This is exactly what the WSP system does, repeatedly 'pulsate' the brake in a bid to modulate the slide by getting the wheels rotating again. The newest systems tend to be more effective than those fitted when the 158s were new, but they in turn were much more effective than the systems fitted to the earliest disc-braked stock.
It may be worth taking a long and close look at the WSP of these trains under different conditions. It wouldn't be the first time a WSP system would impact braking performance more than it should in a small part of it's operating envelope.
12LDA28C
14 Oct 2022
The back of beyond
It earths the braking system to avoid any chance of the brake being released by mistake until it has timed out.
So the same as on other traction types then in that it can't be released until the train has come to a stand. But not the same as on other traction types as it provides no additional brake force (20% extra on a Class 165, as an example).
InkyScrolls
20 Jul 2022
North of England
The reason newer units add additional brake force was due to an 80s directive on driving standards: Drivers were expected, on a good railhead, to brake in step three (full service) at their brake point and release only for final coming-to-a-stand adjustment. Units built after this time give ~20% additional brake force in emergency to provide a buffer if the driver misjudged his braking. Obviously this is not how trains are driven today!
bengley
18 May 2008
To be honest I'm starting to think the policy of most companies to put the brake in emergency during a slide and 'let the WSP work' is really poor advice.
In some situations sure, it's better. But like this where there's a full slide, you'd be better off being able to retard the brakes and get the wheel rotating again. Old 80s/90s WSP isn't all that great.
bahnause
30 Dec 2016
As a train driver I can only judge the behaviour of the first vehicle or, in the worst case, the behaviour of the axle with the sensors for the speedometer. The conditions can change considerably over the length of the train. Releasing all the brakes does not necessarily lead to an improvement in braking force. WSP is mainly a tool to prevent damage to the vehicle, not so much to shorten the braking distance. In principle, sufficient effectiveness of the brakes must be demonstrated under various circumstances during the vehicle acceptance process. Many vehicles would still have some reserves in terms of braking efficiency in dry weather, but do not utilise them because the requirement has already been met.
norbitonflyer
24 Mar 2020
SW London
Presumably there was nothing further he could do in the cab at that stage.
Other than sounding the horn, but I doubt that would have been audible in a train coming the other way. Might be appropriate if the runaway were approaching a station or level crossing.
bengley
18 May 2008
I agree, I am also only aware of what's going on with the first vehicle if judging entirely based on the gauges. You can, however, feel when the train is not at all or barely decelerating (which means all or most wheels are sliding).
In this case there's no disadvantage to briefly releasing the brakes and trying for a new application because what is there really to lose?
If WSP isn't there to shorten the braking distance in low adhesion conditions then it definitely shouldn't be taught to drivers that it's best practice to just let the WSP do its job where letting it do so could cause a collision such as the one here - really it should be the case that we do everything possible to try and rectify the situation. Once the brake is in emergency there's absolutely nothing we can do (on most traction).
chuff chuff
25 Sep 2018
As I said earlier in the conversation I have when the brakes have been released and brake gauge continues to read zero applied a little bit of power to get the wheels turning,get a reading on the speedo and start braking again.This was on approach to line speed reduction,signals and station stops I then follow orders so no come back on myself.
bengley
18 May 2008
Yep I see no issue with that myself. Ultimately you want those wheels to be turning again and if you're in emergency that's not gonna happen until railhead conditions improve.
24 Mar 2013
What do you mean by 'this years leaf fall season'? Do you have any figures to demonstrate that this year is any worse than previous years, as that seems to be a sweeping generalisation to make without any evidence. Also, WSP has been around a lot longer than '10/15 years'.
I have no empirical evidence sorry, not even sure how you’d measure this, it’s just from my experience of driving over the years. WSP was a rarity years ago but from perhaps 10 years ago it started to be retrofitted to a lot of the ex BR stuff I drove.
So what is the point of having an 'emergency' position of the brake then, if if provides no extra brake force? Might as well not be there.
Emergency generally activates the sander too, whereby full service brake does not. Also shows on the OTMR the driver was aware of the requirement to stop asap.
chuff chuff
25 Sep 2018
Last time I did this I informed the relieving driver another long in the tooth guy like myself he said he does this as well,I may be wrong on this but the way I look at it is you can't brake a wheel that's not turning.
westcoaster
4 Dec 2006
DTOS A or B
But going against company policy is a big no no. I've seen drivers do this and receive tea and no biscuits.
I think most companies use a very similar brief in autumn, initial brake application in step 2/ 60% brake and then apply more including emergency if necessary.
InkyScrolls
20 Jul 2022
North of England
This years leaf fall season is reminiscent of how it always used to be 10/15 years ago before WSP and the RHTT. I’d hazard a guess well over half of the drivers on the mainline have been driving less time than this, so will have no experience of how to drive in these conditions, other than what they get via training.
It's actually been quite a good year where I am!
Belperpete
17 Aug 2018
He could have sent an emergency message on his train radio.
The report says that the emergency message was only sent after the collision, and doesn't seem to mention any other message sent by the driver of the sliding train. The signaller was already aware before the collision, and had alerted the other driver. So what alerted the signaller? He should have been automatically alerted of the SPAD when the train passed the stop marker at the end of the loop, but I am not aware of anything that would have alerted him any earlier than that. So if the driver of the sliding train had sent an emergency message as soon as he realised he was in trouble, this might have allowed the driver of the train coming the other way slightly more warning. Can this emergency message be sent by just pressing a button in the cab, or does it involve having to spend time talking to the signaller? I could understand the driver not wanting to stay in the cab any longer than necessary.
Other than that, in my opinion he did the right thing by evacuating the cab and warning the passengers.
35B
19 Dec 2011
Interesting questions, but which need to be answered against the operating instructions crews work under.
MotCO
25 Aug 2014
When the train exited the loop, I assume the points were set in his favour or else he would have derailed. Why were the points not set for the train approaching from the other direction?
Running through points set in the wrong direction does not generally cause derailment, they are just pushed over.
AndrewE
9 Nov 2015
I don't think derailment follows running through incorrrectly-set trailing points, you just break the end bit off the switch blade...
All you need to do is press the red button. That will bring everything in the same area to a stop.
No the points were against it, and the train ran through. No derailment, as is usual.
12LDA28C
14 Oct 2022
The back of beyond
Is that definitely the case on a Class 158? On some other DMUs the sanders certainly operate in full service brake, or even initial braking, dependent on the traction type.
Lurcheroo
21 Sep 2021
Wales
Step 1 - no sanding.
Step 2/3 - Automatic sanding when WSP activity is detected.
Emergency - the braking instructions say full time sanding but I was told by maintenance staff that it is only under WSP activity so I’m after some clarification on that.
12LDA28C
14 Oct 2022
The back of beyond
Cheers - that's more in line with what I expected. It would appear unusual in this day and age to have automatic sanders that only operate in emergency brake.
Krokodil
23 Jan 2023
Wales
Had any other trains that day or previous days suffered from adhesion issues?
Plenty of reported adhesion issues up and down the network, plus some units lost on track circuits. Remember that this was just after a very windy day so a lot of leaves may have been blown out of the trees.
Bikeman78
26 Apr 2018
That seems logical to to me. If the wheel is already not turning, gripping it harder will do nothing. It will make no difference to the adhesion. Ideally the WSP needs to keep the wheels on the cusp of slipping but you might still run out of track before it manages to stop the train. Isn't that what happened with the class 165 at Slough back in the 1990s?
Jim
11 Jun 2005
Wick
Given that the driver must have been expecting to pass something, if that is correct then it is surprising - as soon as the driver knew he was going to enter the single line beyond the loop you’d expect him to initiate a REC.
There's two ways to look at this really, for example in the case of Salisbury, once the driver knew they were going to pass the signal, an earlier REC (I must admit I can't recall if there was one or not, I try not to remember that night at work!) could have got the driver of the GWR to stop in a potentially more vulnerable place than it did.
MarkyT
20 May 2012
Torbay
Are they sprung, or locked in position?
Locked points, the loop is bi-directional.
Points are designed to be run through without (much) risk of derailment. For traditional point machines and mechanical installations, that usually means bent or broken thrust, lock and detection rods. In clamp locks, the force on switch rails overcomes the clamping force. For the HPSS, manufacturers had to incorporate a 'frangible link' to get approval. In all cases, the point mechanism is broken in some way after a run through and needs repair before being placed back in service.
