GWVillager
West Drayton, I believe.I love a quiz as much as the next person, but where on earth is WDT?
This does seem to be becoming standard practice. I've been down the line about once a fortnight in the past couple of months, and on every occasion noticed all the outer suburban GWR services, fast from Paddington to Slough, were cancelled.All Didcot stoppers cancelled
The Didcot stoppers are running fast from padd to reading. Skipping slough and maidenhead.As per just a couple of posts ago - it absolutely is standard practice.
Both relief and main lines are now timetabled to capacity, therefore any disruptive event, even fairly minor, requires the immediate implementation of agreed service reduction plans between the operators.
The Didcots/Newburys should normally be able to terminate and start at Reading, as is the case this morning with the Newburys turning round.
Actually there are services which are notably more intense than this. The GEML, long before the Liz Line, had a peak service intensity much greater, and is also paired by use which makes crossover moves more conflicting. Yet it was never in this constant planned cancellations mode.As per just a couple of posts ago - it absolutely is standard practice.
Its the bit between Airport Junction and Paddington which is at maximum capacity, on both relief and fast lines, from services to Heathrow. There is capacity at slough, but where are those trains going to go if they can't go into Paddington?Actually there are services which are notably more intense than this. The GEML, long before the Liz Line, had a peak service intensity much greater, and is also paired by use which makes crossover moves more conflicting. Yet it was never in this constant planned cancellations mode.
And my own experiences, waiting on Slough platform in the peak and looking across the four tracks, is that it's not at all what I would consider "at capacity".
Was causing delays of more than 15 minutes yesterday. More delay repays.
Also causing cancellations this morning.
Well it seems that nothing nowadays on the Reliefs east of Slough terminates at Paddington anyway. All either go into Acton freight yards or down the hole into the Liz. Nothing into Paddington any more. And if I'm not mistaken just about all the disruptions have been west of Paddington, down the line. The main station now has effectively a 2-track approach. Today's latest hiatus (assuming only one) has been at Ruscombe. That's out at Twyford. And the only crossing movements are the (now cancelled) half-hourly outer suburbans at Dolphin, near Slough.Not at Slough but east of Heathrow Junction they are - where are the trains going to terminate east of Slough? And comparing to the GEML is sort of a null point as that has a range of different factors and practically no timetabled crossing movements Liverpool Street - Shenfield (excepting freight and disruption).
Yes there might be space in Paddington, but there is no space on the line between Heathrow Junction and Acton, there are a number of factors contributing, for example faster trains and therefore longer headways, the timetable still catering for that crossing move at Dolphin junction, and importantly the line being an important freight corridor, and therefore having to cater to slower freight trains.Well it seems that nothing nowadays on the Reliefs east of Slough terminates at Paddington anyway. All either go into Acton freight yards or down the hole into the Liz. Nothing into Paddington any more. And if I'm not mistaken just about all the disruptions have been west of Paddington, down the line. The main station now has effectively a 2-track approach. Today's latest hiatus (assuming only one) has been at Ruscombe. That's out at Twyford. And the only crossing movements are the (now cancelled) half-hourly outer suburbans at Dolphin, near Slough.
Yes, I'm sure someone can come up with something at 04.30 that goes from the Reliefs into Paddington. I'm describing the mainstream service.
That's what GWR are saying. But it doesn't change the overall thrust behind the thread: the service on this stretch of line so far this month has been pretty poor in terms of the number of infrastructure issues.Are we sure about this? The line was blocked in the down direction (1W25, 800008 failed at Southall), but the mainline is also blocked in the up direction at Twyford, which is totally the opposite direction to the train failure, miles away, and the broken down train has been moved. Does anyone know the Up Main at Twyford is closed? Didcot semi fasts being cancelled due to OHLE failure, but that might not be accurate.
GWR also just told someone to take SWR from Maidenhead on Twitter, so I think that shows their opinion isn't very credible. The failed train is most definitely now sitting in the loop at Southall, with trains running past on both lines. The current issue around Twyford isn't a failed train, and my point is it's yet another infrastructure failure, but this time GWR seem to, intentionally for not, be covering it up as a failed train.That's what GWR are saying. But it doesn't change the overall thrust behind the thread: the service on this stretch of line so far this month has been pretty poor.
My final total last year was 85 delay repay payments. So far this year I've only had 3That's what GWR are saying. But it doesn't change the overall thrust behind the thread: the service on this stretch of line so far this month has been pretty poor in terms of the number of infrastructure issues.
Todays delays are not infrastructure related but by a broken down train at southall
Tfl are mentioning the broken rail. Gwr say delays are due to a broken down trainNo there is also a broken rail between Twyford and Maidenhead.
It's remarkable generosity of spirit to describe it as "pretty poor".the service on this stretch of line so far this month has been pretty poor
Disruption expected till end of day, Didcots and Newburys cut to ReadingUM still shut between Twyford East and Maidenhead East:
yhhh I believe that’s because of the incident with the failed trains, I heard there were a lot of sparks coming from the pantograph to say the least.There’s also been more disruption on top to Elizabeth line as they are not allowing electric traction through the Down Main at Southall so any 387s (both HeX and GWR) are being fed onto the Relief lines AND there’s a points failure reducing access to Old Oak Depot.
Not to mention the overall number is very small, so a singular incident could result in that entire increase.The Elizabeth line had biggest increase at 225%, although doesn't mean all happened on section of line in thread title
GWR has the highest volume of delay repay at 307,413 for periods 5-7 in latest ORR figures (table 1.1)
Clearly having to pay out average of over 25,000 delay claims a week shows not just paying out for minor problems.
