paul1609
It would be very rare and you wouldn't pass a Javelin in its dwell time as the line limit is 230 kmh reducing to 200 at kp 6 in London Tunnel 1 so there's no speed differential between a Javelin and Eurostar. Most Eurostars are regulated between the Tunnel and Ashford so there is no conflict between services.Must’ve been a very rare moment for me then when the Javelin we were following very closely behind was held at SFA to let us pass!
However, we probably managed to pass them in their dwell
A late running Javelin can only pull back around 40 secs by Stratford against the timetabled norm. It helps that the line was designed with capacity for 8 Eurostars per hour whereas you're lucky if there's 1 most hours.
