Landslip at Hatfield Colliery (near Doncaster) line to Hull/Scunthorpe now reopened.
YorkshireBear
23 Jul 2010
Train diverted via Google instead
Ainsworth beat me to it!
I suggest you go back through the thread and look at the pictures,that is the google line, no train is going down there my friend.
Waits for the cogs to click into place.... Tick Tick Tick Tick Tick
As long as I make it back to London by 11:30pm, should have been on the one leaving Hull at 18:30
NRE is estimating that journey times are going to be extended by sixty minutes so I'd start by guessing it will be at least 2215 by the time you get to Kings Cross.
Less blocking...more obliterated
True! :lol:
NathanPrior
13 Aug 2007
SE London
I'd love to see replacement bus services carry 500+ of us Charlton fans between wherever it is, would take about 2 hours to get on a bus
FGW_DID
23 Jun 2011
81E
F*** sake, an increased journey time then, better get a damn refund then.
Why would you get a refund, you are paying to travel to a destination, which the company are doing, replacement bus service will be at the mercy of the local traffic!
FGW_DID
23 Jun 2011
81E
No, that was for a refund on booked Advance tickets which was changed at the last minute, not a delay repay that you are referring to.
Best bet will be to speak to the customer services of the TOC concerned.
I would think the answer would be no but have no idea what would happen if say the replacement bus was caught in a snarl up at say a road traffic accident and was majorly late, I'm sure someone will know the answer or have a good idea!
TG
15 Dec 2008
second star on the right and straight on until mor
the slag heap would like to apologise for the inconvenience caused to your journey!!
jokes aside, it's a pain but think what it will be like if this is not fixed by the summer with the planned closure of selby swing bridge for a major overhaul... at least this is just one weekend of inconvenience!
eastdyke
25 Jan 2010
East Midlands
I am not so sure that the idea of a permanent rail diversion is so much pie in the sky.
Take a look at google satellite and you will see the extent of the slag heap. I don't think that there is room on the site to accomodate the huge quantity of material that would need to be moved, even if it was safe to do so. You will also see that the heap sides are much further from the houses to the north-west than from the railway (for which just now the residents must be a tad relieved).
Curiously on the opposite side of the railway to the incident, I won't call it a slip because much of it is heave, there is a very substantial nearby excavation!! What's that all about?
All in all I would say that the re-opening of the route 'on line' could be many many months if not years, away.
Yes a permanent diversion to the south-east will make some appeal.
johnnychips
19 Nov 2011
Delay repay is payable no matter what the cause of delay is i believe?
If it is going to be such a long term job, I assume a provisional timetable will be put into place soon, and then delay repayments will go on that rather than the now-impossible timetable in the NRG
370001
13 Feb 2012
London N1
Curiously on the opposite side of the railway to the incident, I won't call it a slip because much of it is heave, there is a very substantial nearby excavation!! What's that all about?.
I grew up very near here. The excavation you describe is the Bootham Lane landfill site. Unsure whether this is still operational.
eastdyke
25 Jan 2010
East Midlands
Thanks.
I've travelled the line a few times but not noticed the landfill site. Probably because I always look at the mine / heap / etc.! Do you know when and why it was dug out in the first place? And what barrier (if any) was placed between the un-dug sides and the tipped materials?
IanXC
Emeritus Moderator
18 Dec 2009
Even if the Selby works go ahead, presumably services could go on a rather long diversion?
Hull
Goole
Snaith
Knottingley avoider
Shaftholme Junction
Doncaster
I bet theres very few crews who sign that though! Could be a solution for Hull Trains if the summer Selby Swing Bridge works go ahead.
Tomnick
10 Jun 2005
I suppose a long diversion is better than a trip on a bus! As you say though, route knowledge (and pathing south of at and south of Shaftholme?) would be the big problem. The avoiding line at Knottingley is shown as a goods line too - not sure what, if anything, would be required to run passenger trains over it. If every freight train to and from Hull and Goole is diverted that way too, the single line beyond Goole will be a bit busy too. However...
I wouldn't be surprised if the Selby works were postponed if the line's not open again at Hatfield by then. I know it's not as simple as it sounds, but I'm sure there'll be a lot of pressure for Network Rail to do something!
trainplan1
6 Dec 2010
Hull
Goole
Snaith
Knottingley avoider
Shaftholme Junction
Doncaster
Oh no it's even better, there currently planning Hull, Goole, Snaith, Knottingley, Pontefract, Crofton, Calder Bridge Jn (Reverse!), then Hare Park, Adwick, Doncaster
Any one fancy a really fun diversion book your ticket now! :lol:
IanXC
Emeritus Moderator
18 Dec 2009
Ooo definately! I had heard rumours of Grand Central using Selby Canal Curve and Temple Hurst Junctions with the ongoing Colton works (and Hambleton to come isn't it?), I suppose that becomes more likely as paths through Knottingley if be required for Hull services?
trainplan1
6 Dec 2010
I think Hambleton/Colton is all done for now, any further ahead I'm not sure but will check when the plans come around.
They have had some great ones too like Bradford Interchange, Holbeck (Yes right on the approach to Leeds station...), Wakefield, Doncaster...
Tomnick
10 Jun 2005
Are TPE planning similar diversions to Leeds too? I'd have thought it'd be better to concentrate on running them via Snaith instead (if they can be encouraged to get enough traincrew to sign the route - surely Northern have the same problem?) for connections to Doncaster and Sheffield from Leeds - it'd probably be just as quick for Doncaster passengers as the long-winded diversion, and maybe quicker for Sheffield if the path and connections worked out well!
I sense a forum meet maybe in the near future with these diversions...
Passenger Focus have done a couple of studies on this and they've determined that passengers would rather a long diversion on the train than just be dumped onto a bus that was direct.
