YorkshireBear
- Joined
- 23 Jul 2010
- Messages
- 9,172
I was under the impresion liverpool would get a better service post HS2... taking som of the manchester paths.
I would expect it to take around 3 hours - journey planners will add on at least 20 minutes as the minimum connection times, when it's a 5-minute walk
I think, in practical terms, this is more than outweighed by the benefits of not changing at Wigan and being able to board at the terminus
Of course, it depends what you mean by 'decent part', but I would hazard a guess that is much less than 1/4 of the passengers.
I suppose that some trains that should go to Liverpool go to Holyhead, in the evening I think there's 2 in an hour out of Euston to Holyhead which probably connects with the same boat. Why one of those trains can't go into Liverpool is beyond me.
You are also ignoring the number of seats needed on Manchester - London services for Crewe/ Stoke/ Macclesfield etc.
This.
Liverpool services only serve Runcorn, and that's only because there's no local service, I'm pretty sure Virgin would cut Runcorn given half the chance, and Stafford, which is lucky as its Trent Valley neighbours have no express service to speak of.
The majority of travellers on the Liverpool service go only to/from Liverpool. Once you look at the loadings in a similar way for Manchester, ie removing the Stoke/Macclesfield/wilmslow/MK loadings, you often have a smaller end-end load off-peak for Manchester than you do Liverpool. In this way, Liverpool fares better as its the way the timetable worked out. TOC input during the development of the new WC timetable wanted calls at Crewe and Rugby/Nuneaton with the Stafford call transferred to another service, but for whatever reason this didn't work and instead ended up being Stafford only. So to this end the addition of the one extra stop at Stafford is the apologetic present from the timetable, rather than an intended hindrance to loadings!
Isn't the whole idea of having a single fleet rather than one actually tailored to match demand that you just interwork services as you are not constrained by 'Glasgow sets' and 'Liverpool sets'?And of course if you speed up the Up Glasgow enough, you could step up the diagrams too. Currently the Liverpools and Glasgow (most of the day) have ridiculous layovers at Euston.
Seems incredibly lazy planning...
I don't know if it is currently the case or not but the Liverpool service had a 75 minute layover at Euston - and this set was then used for another service if a late inbound would cause a delayed outbound. That is smart - not lazy planning.
One train an hour is not bad really, especially as there is the London Midland option as well. Manchester is a much bigger and more important city than Liverpool.
On second thought it is even more stupid as the Virgin traincrew are deemed too fancy to work more than one round trip on the same route (or similar terms) so you probably can't even diagram the same crew with the same unit in and out if the units are restricted to one destination. Thats going to make service recovery a complete faff regardless of what set you have as a nomiated 'step up' set, because you can't spin it straight back out if everything is a crew swap to get around the one trip rule!I seem to remember there was already another set at Euston though as the 'standby'. And yes it still occurs. Arrives at xx56, departs x207.
Margaret Thatcher's closest ministers came close to writing off Liverpool in the aftermath of the 1981 inner-city riots and even raised the prospect of its partial evacuation, according to secret cabinet papers released on Friday.
The cabinet papers released by the National Archives under the 30-year rule reveal Thatcher's closest advisers told her that the "concentration of hopelessness" on Merseyside was very largely self-inflicted with its record of industrial strife.
