Locomotive Services Fleet (LSL) updates
Trackman
28 Feb 2013
Lewisham
No news on the peak then?
Last I heard it is still receiving attention, but they are working on it, so I've been told - that was about 6 months ago.
Think it's been over 12 months since the last cancelled railtour.
12LDA28C
14 Oct 2022
The back of beyond
Will it be swinging around on the rear of tours before it hauls them ?.
Traction refresher for drivers maybe.
The plan I believe is once drivers, fitters etc are trained (and it has been declared fit for service) it will be on the rear of some Saphos tours for the time being. It can't multi with LSL 47s so will be of no use on a Statesman tour for example if it's booked for a pair of 47s (i.e. not top-and-tail).
Nym
2 Mar 2007
Somewhere, not in London
Wonder if they’ll have released the ETH jumpers or left them painted closed…
The plan I believe is once drivers, fitters etc are trained it will be on the rear of some Saphos tours for the time being. It can't multi with LSL 47s so will be of no use on a Statesman tour for example if it's booked for a pair of 47s (i.e. not top-and-tail).
It can’t multi with any Class 47…
bleeder4
19 Jan 2019
Worcester
Looks stunning. I've got some Saphos tours booked for next year so hopefully it will tag along on one of those. I didn't know that a 57 couldn't double-head with a 47. Rather ironic really, considering that a 57 is basically a refurbished 47.
12LDA28C
14 Oct 2022
The back of beyond
Correct me if I'm wrong but have they not got 2 57's
They also have 57003 but 57/3s cannot multi with 57/0 currently. 57302 is still at Eastleigh Arlington being worked on and the two 57/3s will be able to multi with each other when they are both eventually in traffic.
I understand that when 57311 enters service it may well be on the rear of Saphos tours initially (leading the train where necessary). 57s have a rather different electrical and control system I believe so not that ironic.
43096
23 Nov 2015
It would make sense to have all four 57s capable of multi with each other. It may also make sense to through wire the 57/0s with ETS cabling so they could run a 57/0+57/3 combination and run round the train without needing to run the locos round each other as well.
ac6000cw
10 May 2014
Cambridge, UK
A 57 is a rebuild, using a 47 bodyshell, bogies and (I think) traction motors but with a different (EMD) diesel engine and Brush alternator (instead of a DC generator) - so the traction control system is very likely different to its 'parent' loco. In any event 47's were not MU equipped when built - it was added later to some of the class.
A class 69 is a rebuild based on a 56, and it can't MU with its 'parent' either.
JammyJames08
7 Apr 2009
With the purchase of 37401 and 37409. Alongside their 37521 & 667, are there plans to hand back 37688 to the Severn Valley?
Forty29
10 Dec 2021
Bicester
Brilliant to see 37409 back on the mainline and last week repainted in rail freight grey 20118. Presumed will be paired up with 20132 in the future. Looking forward to seeing what they do with 37401, hopefully will keep it sounding like it does now!
12LDA28C
14 Oct 2022
The back of beyond
37688 is not based at the Severn Valley, although it was there on loan a few years ago. It's owned by the D05 Preservation Group, who also hire 47828 to LSL.
D365
29 Jun 2012
Reportedly [according to the DRS heritage vehicles thread] it's due for an engine overhaul.
Nym
2 Mar 2007
Not at all ironic if you know the vehicles.
Has this ever been possible? I'm assuming it was not specified as part of the "Class 57 ETH" build.
No.
The Class 57/0 was built without the ability to Multi-Work with any other vehicle.
The 57/3 was built "technically" able to multi-work, but it's not pretty how it does it and is "operationally difficult". There have also been a significant amount of mods done over the years that are... err... Recorded in the freight way. These will have affected the ability to multi-work.
While it is *possible* to mod a 57/0 to multi with a 57/3, it very much falls into the realm of "Anything is possible" in terms of engineering, it's not something that I'd want to be spending my money on. I won't say "If I where LSL" because I'm not, and I think I've made my opinions very clear on the company previously, but I'd much rather be spending my money improving the asset reliability and usability through a nice amount of remedial work, particularly on the Phase 1 Freight locos and getting them into a better position for ETCS fitment. If you must make them work in multi, then it needs to be engineered into the vehicle properly, not simply "boshed on" as it simply will not work.
Oh and if anyone does have access to the asset data and wants to feel smart, yes there are designs for the 57/0s to multi work, no, it wouldn't work with a 57/3. That is all...
Wyrleybart
29 Mar 2020
South Staffordshire
Very interesting "Nym". You clearly know your stuff.
I am under the impression that EMD series power units do not have pneumatic operation of the engine fuel racks, unlike the indigenous UK designs, which means that those cussed little white engine control air pipes are not necessary for multi control of said power units. So I would have expected the various types of design fitted with the 645 series engines to talk to each other. But that is the extent of my knowledge and clesarly not actually the case.
Thanks
12LDA28C
14 Oct 2022
The back of beyond
No.
If someone were an electrical engineer with a keen interest and a good line in problem solving, I'm sure they could engineer a successful multi-working solution relatively cheaply and easily. Maybe LSL employ just such a person...
Nym
2 Mar 2007
Thanks
The 57 conversion did indeed do away with the pilot air and replace with an electrical throttle control which is basically identical to the EMD series. There is a proposed method for multi-working with other EMD units, some fun things to make the throttle bodies work.
They may well, but from the condition I've seen of their vehicles, I do not have any confidence in this.
12LDA28C
14 Oct 2022
The back of beyond
We shall see. Converting the DBSO rake, for example from using the lighting circuits for through train control to a bespoke hard-wired control system suggests they know their electricals.
43096
23 Nov 2015
Except that it was DRS that fitted blue-star to the DBSO. LSL have just through wired the rest of the set with control cables and (presumably) control air pipes. Not bespoke, and hardly the most difficult of engineering tasks.
Jturner98
2 Jan 2021
Kent
I’ve booked the class 90 railtour in February. Does anyone know when the diagram will appear on Real Time Trains?
