Longest railway journey on a single train in the UK
Vespa
20 Dec 2019
Merseyside
What would be considered the longest distance single railway journey from point A to point B without changing train ?
It would interesting to ride in such a way you can see most of the country without getting out of your seat.
Towers
30 Aug 2021
Wasn’t the Highland Chieftan the longest journey?
Choo choo 66
26 May 2020
Kernow
UK wise yes Aberdeen-Penzance (think it is starting again in May timetable change)
If you go into mainland Europe there are many much longer journeys
hexagon789
2 Sep 2016
XC Aberdeen to Penzance?
Should be when it resumes in May -
752mi 60ch
A mere 570 mi and 33 chains ;)
either aberdeen-penzance or the caledonian highland sleeper?
752mi 60ch for the former and 567mi 44ch for the latter. (It is shorter to Euston from Inverness than King's Cross but the available route is faster via Edinburgh and the ECML.)
class ep-09
5 Sep 2013
That may be a topic for International Transport , but what is / was a longest journey on one train by country ( currently and historically )?
Depends on whether you're counting distance or time. The longest distance service that runs regularly is Aberdeen to Penzance - currently Saturdays only, but resumes running Mondays-Saturdays from the May timetable change.
Occasionally engineering works mean that the train travels over an even longer distance than normal, and upcoming ones mean that there is, unusually, a northbound Penzance to Aberdeen service too, running via Toton, Doncaster and Leeds.
The longest service by journey duration is, however, the Caledonian Sleeper's Fort William portion whenever it runs via the East Coast Mainline. This results in an earlier departure from, or later arrival at, London Euston as the train reverses at Wembley Yard. Journey times average around 14 hours - about 45 minutes longer than the standard Aberdeen to Penzance timing.
I think this qualifies as the longest "regularly scheduled" service on the basis that ECML diversions are generally planned on an LTP basis for weeks at a time, rather than just ad-hoc.
liamf656
2 Aug 2020
Derby
Crosscountry are running a Penzance to Aberdeen service, but only on Saturday 27th May, 3rd and 10th June. This is due to the Erewash diversions
Techniquest
19 Jun 2005
Nowhere Heath
I'd absolutely do it in First Class, it would be a consideration in Standard as long as I had a good supply of food and drink with me. I'd also need a decent hotel before and after the journey, as well as a good bit of exercise immediately before/after the journey.
This actually sounds like a good plan, I'll have to investigate some time off and book it soon!
Kite159
27 Jan 2014
West of Andover
Although it won't run on the 3rd June due to the strike
penguin8967
21 Aug 2020
South West
The Aberdeen-Penzance service on 29th April got diverted via Severn Tunnel Junction, only adding on around 15 miles though (but also meaning it passed through 3 countries!)
james60059
6 Jul 2006
Hinckley
I would have thought the Trans-Siberian Railway from Moscow to Vladivostok is (or was?) the longest journey (5753 miles)
Bristol
This thread has been split to be specifically UK, the other half is in International transport.
D6130
12 Jan 2021
West Yorkshire/Tuscany
If doing a first class All Line Rover, how about 08 20 Aberdeen-Penzance, then straight onto the Night Riviera to Paddington?....although if the CrossCountry were to be delayed, you might have to bale at another Cornish station.
TT-ONR-NRN
30 Dec 2016
Farnham
I also want to do this, and if you win the weekdays only Seatfrog - which I believe is a fixed £5 regardless of journey for XC though I might be wrong - first class for even cheaper! In standard it’d probably be a drag for me.
Techniquest
19 Jun 2005
Nowhere Heath
I had booked a hotel in Aberdeen specifically to do the 0820 to Penzance last year, then discovered it wasn't running. Mind you, it led to an awesome day mostly on ScotRail HSTs which worked out well!
If I was doing the 0820 throughout, I would stay in a hotel in Penzance. I'd not want to jump straight off one train and onto the next like that. I'd be needing some serious exercise between trains to do that!
Wow, I've never used Seatfrog but for that purpose I'd have to investigate it!
24 Sep 2017
Having of course got to Aberdeen on the sleeper from London beforehand ;)
MotCO
25 Aug 2014
Taking it literally about not changing train, how many circuits of the Circle Line could you do in a day from when the train left the depot to when it returned at night? (I realise that the Circle Line is no longer circular!) It will probably win on length of time, but probably not on distance due to the low speeds achieved, based on the rough calculations below.
Wikipaedia quotes the old Circle Line as being 12.89 miles long and took a minimum of 51 1/2 minutes, Let's round it up to 13 miles and 60 minutes. Assuming a start at 06.00 and finish at 23.30, this means 17 1/2 hours at 13 miles each lap equals only 227 miles. This means it would exceed the Aberdeen - Penzance train on time, but hardly scratch the surface with regards to distance.
12LDA28C
14 Oct 2022
The back of beyond
Clearly this thread is concerned with timetabled service trains but I've certainly done some charter trains that have been booked to take 15 hours plus to reach their destination although the distance involved was less than 600 miles.
Back in the days of LHCS on CrossCountry services I would do a week's All-Line Rover and stay on the move the whole time, using Sleeper services overnight (although always in seated accommodation). It was possible to do over a thousand loco-hauled miles a day.
D7666
12 Aug 2013
cue someone else to work this out for the Glasgow subway.
mm333
28 Aug 2008
53.8331°N 1.7734°W
I tried to do Aberdeen-Penzance in 2019, but waves coming over the Dawlish sea wall meant that Voyagers were being terminated at Exeter so we had to board a GWR HST for the rest of the journey. If I tried to do it again, I'd do it in First Class rather than Standard. Especially as we were an hour late and so I got a 100% delay repay refund.
jrail1992
9 May 2012
Wigan
Re: Glasgow Subway, it's 6.5 miles so rough calculation, 752.5÷6.5=116 (rounded up). Do any of the Subway units do 116 trips around the loop in a day?
