Heard that a 400 got bricked at Moredun last night, putting out the glass in the entrance door. With what happened at Clermiston last week it's maybe now time for LB to rethink its service provision to housing schemes after 7pm if this behaviour is going to be a regular occurrence.Anti social behavior unfortunately... Another night of more buses getting attacked
It’s a hard one, because they still want to try and provide the service to those that need it. But more importantly nobody should be getting this happening to them, passengers or staff. I’m sure any decisions needed will be made in due course.Heard that a 400 got bricked at Moredun last night, putting out the glass in the entrance door. With what happened at Clermiston last week it's maybe now time for LB to rethink its service provision to housing schemes after 7pm if this behaviour is going to be a regular occurrence.
Oh right, aye i walked right past the entrance of 499 parked on Criagour Avenue last night but hadn’t noticed any damage to it obviously not noticing the smashed doorHeard that a 400 got bricked at Moredun last night, putting out the glass in the entrance door. With what happened at Clermiston last week it's maybe now time for LB to rethink its service provision to housing schemes after 7pm if this behaviour is going to be a regular occurrence.
because they’ve been sold...Just noticed on bustimes.org, B9TL's 836-873 have been removed of the vehicle list.
So I'm guessing one off sold was the charity bus?because they’ve been sold...
837 is the one photographed at Ensign (SK07 CBY, 835 is CBV so can see how you’ve confused them. theres a bunch more than just 837 thoughOnly 826-840 and 851-873 are withdrawn and/or potentially sold at this stage. You’ve still got the ex Coaches ones 841-850 in use at Lothiancountry (841-843) and EastCoastbuses (844-850) plus 874-875 at Central. As I’ve said before I don’t think these will be going (if they do go) until the new ones arrive and then those and potentially some 08 plates are withdrawn/sold, depending on the situation at that time.
None of the 50 AVL’s have been removed from the proper data feed (tfeapp.com/live) at this stage but when that does start to happen that’s when the vehicle has been fully removed and is no longer a part of the fleet, until then it’s just speculation unless somebody has seen pictures, for example I recall seeing a few photos of one (think it was 835) at what looked like Ensign - which interestingly if correct isn’t one of those removed from bustimes.org
So until there’s concrete on what’s where - which will happen in the not too distant future, there’s no point speculating which ones have and haven’t gone.
Should’ve trusted my gut instinct, not sure why I said 835. I can see why I need a new pair of glasses837 is the one photographed at Ensign (SK07 CBY, 835 is CBV so can see how you’ve confused them. theres a bunch more than just 837 though
current order is still open, 50 in the near future - the rest, who knows.I'd put money on 874-925 (minus the bridges ones) hanging around for a while in storage even after the new buses come if service levels return to some semblance of normality later in the year.
Not sure how many B7TLs were left at the end of March last year, but the currently withdrawn/sold B9TLs plus the above batch would probably leave them short of deckers if it's only 50 new ones coming (although I've heard the remainder may still be on order but for the end of the year/early 2021?).
I’ve just seen it happen. I knew the kids were gonna do it but 101 at times is hopeless. Must’ve hit bodywork as bus was able to continue. I really hope that more people don’t get injured but I don’t think this is the end of this sadly.Unbelievable I was on a 400 last week and this happened, when will folk learn not to be so selfish and ignorant, it angers me beyond belief how folk can be so stupid
That's why you can use 999 for things like that.but 101 at times is hopeless.
36 main fleet +7 ecbNot sure how many B7TLs were left at the end of March last year
In this case stones were being thrown from behind and at bodywork (not windows - although that may have just been bad throwing) and the bus kept going - driver did briefly check and presumably radioed it through so I felt that 999 wasn’t appropriate in this case, had it been worse I agree 999 would definitely have been the way to go.That's why you can use 999 for things like that.
If the offenders are still in the area, then that is an appropriate use of the 999 system for future reference.In this case stones were being thrown from behind and at bodywork (not windows - although that may have just been bad throwing) and the bus kept going - driver did briefly check and presumably radioed it through so I felt that 999 wasn’t appropriate in this case, had it been worse I agree 999 would definitely have been the way to go.
By the time I had rang the bus had moved off anyway so it’s a tricky one.
EDIT: The police are now in the area checking bus stops so they’ve been made aware.
It's definitely a hard one. On the one hand, stopping services would get the message across that they don't tolerate such behaviour. However, you're then punishing the majority for the actions of a stupid minority. Not an easy decision either way.It’s a hard one, because they still want to try and provide the service to those that need it. But more importantly nobody should be getting this happening to them, passengers or staff. I’m sure any decisions needed will be made in due course.
https://twitter.com/Mr_Mark_Brown/status/1370491589127241733 (Image taken by driver, reposted by Cllr Mark Brown)Heard that a 400 got bricked at Moredun last night, putting out the glass in the entrance door. With what happened at Clermiston last week it's maybe now time for LB to rethink its service provision to housing schemes after 7pm if this behaviour is going to be a regular occurrence.
Something will have to be done and fast as this is not an isolated incident. While they want to have a service to every part of the city; driver safety and passenger safety comes first and if that means they need to avoid areas, then so be it.It’s a hard one, because they still want to try and provide the service to those that need it. But more importantly nobody should be getting this happening to them, passengers or staff. I’m sure any decisions needed will be made in due course.
It's a straightforward decision in my opinion. Do you wait until a brick hits someone on the head and kills them, or do you act now, remove the services from the troubled areas and reassess the situation? We are lucky that a driver was not blinded when a brick was thrown through the windscreen last weekend and glass went in to his face. It's only a matter of time.It's definitely a hard one. On the one hand, stopping services would get the message across that they don't tolerate such behaviour. However, you're then punishing the majority for the actions of a stupid minority. Not an easy decision either way.
Much of what you see at the moment is for spaces for people.Hi folks. Apologies if this is the wrong part of the forum to ask this question or if it has been covered before. I remember seeing an article a while ago about lothian/ECC looking to close every second bus stops or something like that, to speed up journey times. Has this started to take place, specifically around the Cameron toll area, or is this to do with spaces for people.
Thank youhttps://twitter.com/Mr_Mark_Brown/status/1370491589127241733 (Image taken by Cllr Mark Brown)
I do, however, wonder if the union will force their hand.
When LRT as was first started running into Moredun with the 36 and 69 in 1988, these were "working day" services which finished at 7pm and so vandalism at nights there wasn't a problem.https://twitter.com/Mr_Mark_Brown/status/1370491589127241733 (Image taken by Cllr Mark Brown)
Wont be many B8L's though i believe.
Yea enough is enough. It was bad enough eggs and small stones being thrown but it’s now at the stage where it’s whole bricks, something that could easily kill somebody. Certain areas have now seen more cover and combine the factor that kids know they can get away with it it’s actually only getting worse. Perhaps a total withdrawal of all services after a certain time might eventually happen, and I would be for that.https://twitter.com/Mr_Mark_Brown/status/1370491589127241733 (Image taken by Cllr Mark Brown)
The image was taken by the driver, not the councillor - he's just getting involved, to get involved.https://twitter.com/Mr_Mark_Brown/status/1370491589127241733 (Image taken by Cllr Mark Brown)
Initial B5TL's, the image of which has been shared online, were initially built for East Coast - changed for main fleet pre interior fit out.Surprised there's any B8Ls in the order or was it the case they were already in build?
Even if there's no more after the 50 I think resulting fleet would be exceptionally modern comparison to other similar sized companies.
Thank you for correcting me. (And I do agree with your sentiments).The image was taken by the driver, not the councillor - he's just getting involved, to get involved.
but this isnt the place to discuss the uselessness of local councillors.
Is the image anywhere else than Facebook?Initial B5TL's, the image of which has been shared online, were initially built for East Coast - changed for main fleet pre interior fit out.
It wasnt on Flickr.Is the image anywhere else than Facebook?
I can't seem to find it on Facebook or Flickr either.
Thanks .
It wasnt on Flickr.
i dont have permission to share the image so i've shared the link to it. Click here.
As they were initially to be built for East Coast in "coach spec" there isnt a glass staircase. I believe the rest of the batch is to follow suit.
The bodies were built for East Coast, Lothian started selling B9's, then switched the early batch to an order for Lothian so they were fitted out for main fleet. At that point, the B8L's were delayed. East Coast deckers will follow on.
