If you are talking between Lime St and Manchester, oddly only Patricroft and Eccles can handle 8-car (20m) trains.
On the Wigan line, only St Helens Central.
Some platforms are on a list for extension, but only up to 6 cars.
They are currently all odd lengths from 4 upwards, with no consistency.
Thanks LNW joint. So will the units be made into 3 car in the future?
Edge hill would be 8 car.
According to Quail, P2/3 are limited to 7-car, all the rest are 8+.1. Can Lime Street's Chat Moss and Wigan platforms handle 8x20m trains?
There is quite a long list in the NR CP5 enhancements plan (project NW008).2. Can you please tell us where we can view the list of possible extensions?
Very few of these are on the new electric lines, and the only one of immediate interest is Newton-le Willows (but not to 8-car).Scope of works
Early development identified that platform lengthening would be required at the following stations:
4 x 24m car length at Mossley Down, Greenfield Down, Marsden, Slaithwaite, Mouldsworth, Delamere, Cuddington, Greenbank, Plumley Down, Ashley Down, Hathersage and Grindleford;
4 x 23m car length at Dove Holes, Chapel-en-le Frith, Middlewood, Woodsmoor, Humphrey Park, Glazebrook Down, New Lane, Bescar Lane, Moses Gate, Hall i’th’wood, Darwen, Ramsgreave & Wilpshire, Langho, Whalley and Clitheroe;
6 x 24m car length at Liverpool South Parkway Up and Down fast platforms, Widnes, Warrington Central and Newton-le-Willows; and
3 x 23m car at Bamber Bridge Up.
The scope will be determined by the rolling stock strategy for services in the North West and the operational plans of the relevant train operators
3. In the late Noughties I worked in Folkestone, travelling weekly to and from northern England. Eight and twelve coach trains routinely called at shorter stations and advised passengers to move to coaches 1 to 4 or whatever. This seemed ordinary, normal and unexceptional.
Was this an example of Grandfather Rights or could such practices be introduced up here when we stimulate demand to such a degree that we run eight or twelve coach stoppers?
Yes indeed, Edge Hill is well over 8-car length.
There are no plans to shorten class 319s.
Nothing runs at more than 4-car at the moment.
However it also says:
and all the milestones are "to be determined", so it's not getting very far.
I don't know is the simple answer.
You may well be right on the question of grandfather rights.
Upgraded lines attract new standards (certainly the WCML did recently).
Whether a regional electrification project does is the question.
The new platforms at Huyton/Roby I suppose are an indication.
I still think too much is made of "doubling up" with all its infrastructure and shunting costs.
No Northern DMU services in the NW run with more than 4 cars.
An all-day 4-car service would be more effective than 2/3-car off peak doubling up to 4/6-car in the peak.
There are two issues with train length and stopping at particular stations, one is indeed platform length, but the other is point and signal positioning. While it would be entirely possible to have SDO (selective door opening) at the set level on short platforms - ie an eight-car train comprised of two 319s would only open the doors on one of the two sets (four of the eight cars), though there may be regulatory limitations, but if the train were to block points or overhang a signal block, then it would still not be possible to stop an 8-car set at that station.
One station where I know there is no capacity to stop longer trains, even with SDO, is Salford Crescent. If there are any stations with this issue along these lines (and I'm thinking particularly of Earlestown and Newton-le-Willows with their WCML connections) then this would require resolving before longer trains could stop there.
Moving signals, on an otherwise clear line, should not be outrageously expensive, especially as the line may be resignalled anyway; but moving points will certainly require both trackwork and modifications to OHLE, which is a significant cost and might require moving actual junctions, which may not be possible at all, and would certainly be very expensive indeed.
In the Olive mount Cutting they could have hung gantries from the sides of the cutting walls, as in the Lime St cutting. The posts on the trackbed through the Olive Mount Cutting will be used as an extra costs excuse not to run in further services to Liverpool, such high-speed rail.Thank you for answering my questions, i work on the freight side, last time i was in the cab on this route in daylight was a few months back. Next time i am ill get some photos or footage.
Is it true some posts have been put up in the path of the 4th line at Huyton and will be removed later?
And is there any updates on the land aquisition?
Cheers
Mike
Helpful and interesting, thank you.
SDO in the 319s would be very very expensive job to do as the trains don't have a computer to control this. Platform extensions would be cheaper.
Full-on SDO, sure, but couldn't you just lock-out one of the two units?
If (as expected) 319s get used on Manchester-Preston via Bolton services (as expected) that's a difficult problem to solve.
319s wouldn't be able to leave central Manchester with all 8 cars in use due to Salford Crescent only being able to take 6 x 24m car trains, effectively defeating the point of having a strengthened service.
Are there any 6/8-car Northern DMUs operating on the Bolton route?
I've never seen anything bigger than 4-car (and usually 2-car).
I've been out and about today.
1. Booms up on Carr Mill Viaduct masts
2. The missing mast immediately north of the viaduct now stands proud as part of a portal.
3. The fourth portal for Sankey Viaduct is still lying beside the track
4. Orangemen were using chainsaws on the trees on Sankey Viaduct's western approach embankment, south side
5. Wiring looks rather more finished at St Helens Junction
6. Platform signs being set back in their proper positions at Rainhill
7. More danglies on portals between Huyton Station and Junction
8. The northern mast and associated portal cross-member still missing from Huyton Platform 4 east end
9. Network Rail Orangeman checking lengths at Roby station, it looked like an audit, eg 'the contractors are claiming they've laid x metres of fence, let's measure the fences' (I've made that example up to show the apparent idea).
10. Roby lifts still locked out of use
11. The wires Paul Gaskell photographed the other day definitely continue northwards from the long-standing full wiring which previously ended at Ravenhead Sidings. Paul was unable to establish this for certain on his visit as it got dark.
12. Someone reported recently that there were no wires from Gerards Bridge Jct to St Helens Central. This was surprising, as for some time there has been a very short stretch immediately south of the piers of the former GCR viaduct. I'm pleased to report it is there. It stretches over two gaps between three pairs of masts..
Photos later.
SDO
As to the Folkstone suggestion, back in the late 1990s you had old stock with grandfather rights where common sense was allowed for. Sadly your not allowed this today.
Also the ex-SR lines were mainly operated by 4-VEP, 4-CEP and 4-CIG stock which was gangwayed throughout when running in multiple, so passengers could walk through more than one set. The 319s are only gangwayed within the unit and have non-corridor/non-vestibule driving ends.
What exactly are these danglies?
I have been exercised by wondering why TGBUs appear to be entirely unbedanglied. Have you any idea why they remain as bare as a baby's bum?
You can't unlock the rear unit that easily. I'm not sure if the Northerm mods change it but currently to lock out a unit requires manual lock out each time its implemented. Passengers are currently not permitted to travel in a locked out unit barring emergency situation where theres a genuine safety reason.
Don't forget SDO works by allowing the doors to open. To do this the train uses GPS or beacons then allows driver to open doors as per its programming. The 319s do not have this equipment and it won't be easy to retrofit, requiring major rewiring of the unit. Fact no TOC has done this to a BR era EMU speaks volumes.
Two more bigguns up at Vic.
http://i13.photobucket.com/albums/a260/Geeves8612/IMG_20150105_114414356_zps1e9ce52d.jpg
Lil diragram for you, this is the same as they give us to learn at work
http://irolearn.co.uk/wp-content/uploads/2014/05/image-1-from-page-227.png
