bengley
- Joined
- 18 May 2008
- Messages
- 1,925
Not in mine (2015 edition), at least not where it used to be in the older editions.
First page of the Victoria to Brighton maps
Why is it only 100mph on the down? And what is the limit on the up line?
When nonstops ran from Southampton Parkway (maybe still called Southampton Airport then) to Waterloo I once had just a 4 car 4-VEP turn up on a REP/TC diagram. Bit of a squash as you can imagine. But did it move, and I felt beyond Basingstoke we were up towards 100 mph, finally stopping in Waterloo just on 60 minutes from Parkway. That was quite a ride.I experienced a sub-one hour REP/TC/TC run from Southampton to Waterloo once and that was with sitting outside Waterloo for a few minutes waiting for a platform...
When the REPs were being tested in 1967, I've heard stories of speeds considerably in excess of 100 mph, though none of it was officially authenticated.
I seem to remember a story of a 4REP being tested between Tonbridge and Ashford. It was overnight and a speedgun at Staplehurst clocked it at 112mph.
Something to do with Eurostar 3rd rail pick up trials.
So it does, thanks.
My understanding is that it's less a problem of shoegear staying in contact, that the issue is the impact on the ramps. That >100mph would be easily do-able, but for reliability you'd want much longer, shallower gradient ramps. Which means longer gaps between sections, which in turn means more chance of being gapped if a train has to make an unplanned stop.
What about level crossings, though?If you go down that route you could potentially have switched overlap rails so that one side of the train always has a shoe in contact with a live conductor rail, but that would require in line rail insulators, I imagine they could exist but I have never seen one.
Of course a two track railway can have no breaks at all if it wants if it puts the rails on the left hand side (in the direction of running) - the rail could run for many miles unbroken since crossovers will not require a break.
Would 4REPs have still been capable of running then? Given that they donated their running gear to the 442s I'd be surprised, as 73+TC formations had to deputise during the transition because a 432 had to be taken off before the next 442 off the production line could be finished!
Is that actually used anywhere, or is it just your suggestion?That would depend on the third rail shoe gauging and if the road deck could reasonably ride as high as the top of the third rail.
THen you just use the in line rail insulators to ensure the third rail over the crossing is dead unless a train bridges it. Or is even made entirely out of a non conductive material.
Not to mention stations (where the 3rd rail is normally kept on the opposite side to the platform)
The run I was talking about, however, was from Southampton Central to Waterloo, not from Parkway. In those days there was one an hour non stop each way to / from Central.
My quote about Eurostar testing is no doubt wrong. Still trying to find the original story about the REP testing between Tonbridge and Ashford. Even so, 3200hp over 4 cars must have been quite nifty. Almost as good as 4500hp in a 6 car class 395. (AC only).
I'm not sure VEPs would attain 100 mph on the up beyond Basingstoke. They have trouble maintaining 90 on the level.
True, but I was talking about a REP/TC/TC rake...
Could the unit used in the Eurostar tests you mentioned have been one of the "Greyhound" 421 units? As I understand it they could shift a bit...
Greyhound units were very good and quick.
I'm saying nothing more.![]()
This?
In the build up to the Eurostar build, Alsthom engineers and SNCF were
sceptical about the ability to achieve satisfactory current collection
from the third rail so we arranged an overhauled 4 REP with maximum
diameter whelsets to go flat out between Tonbridge and Ashford in a
night time possession. The result was entertaining to say the least.
The speedo was off the clock (100 mph +) and a radar gun at
Staplehurst clocked us at 117 MPH. Ride was bloody awful and I'm sure
that had the straight been longer we could have cracked 120MPH. This
sort of performance is why 4 REP's were never supposed to run alone,
always with one or more TC's.
Another point to bear in mind is that 4xx stock has a balancing speed
on the level of 80 mph or 86 mph for "greyhound" units with a second
field weakening stage, whilst the Electrostars and Desiros will
balance at 100MPH."
https://groups.google.com/d/msg/uk.railway/7uPYi1m4xY0/dGVlJPO4oyQJ
Point of pedantry, electrostars and desiros won't balance at all, they're AC machines driven from inverters, they'll drive to and usually beyond their nameplate ratings, that's more than 100mph.
Absolutely agreed and Greyhounds will exceed 90 mph on the level whilst the logs I've seen of slam door trains are varied. A 4-CEP seemed to have trouble managing 80 but a 4-CIG was good for 5 mph more.
As I understand it a 4-REP had 1,600 hp in each of its end power cars, each power car was essentially a Class 73 loco electrically with no diesel and a passenger body. With a REP/TC/TC combo you thus had 3,200 hp for 12 cars.
A 4-VEP had 1,000 hp, so a 12-car set had 3,000hp, for pretty much the same overall weight, the difference being probably within the tolerances of individual units. Both types had B4 bogies which were good for 100mph elsewhere.
So what accounts for any difference in performance? Gearing? Field weakening?
