On the North Downs, the 2234 from Reading is restored as far as Guildford, then running empty back to Reading. The unnecessary waits at Guildford on the stoppers and restoration of Turbo timings will have to wait for another timetable.
I understand a proposal has been submitted to NR to look at the route in a future timetable change. The main issue is the turbo timings were based on the 165/0s initially allocated to the route which had better acceleration due to their lower top speed. Right time performance on the old turbo timetable was somewhat fickle.
This 165/1s it was accepted struggled on the old turbo timings are but the 769 timings are too slow for them so some work is needed to produce some robust timings.
The return of the 22.34 on the Western end of the line is a welcome improvement.
In other GWR changes:
The 10.04 Paddington to Penzance on weekdays reverts to running non stop Reading to Exeter (should please
@irish_rail). The 09.37 Paddington to Paignton ceases to call at Newbury and Pewsey, instead there’s a new 08.38 Paddington to Westbury semi-fast service.
Weston-super-Mare to Paddington through daytime services are restored on weekdays, running every 2 hours.
Also roughly every 2 hours Monday to Saturday services extend from Swansea to Carmarthen. The previously mentioned Summer Saturday services to Pembroke are restored.
The new “Metro West” services are included:
Standard pattern 2 hourly Bristol to Weymouth with a peak extra each way, quite an improvement on todays service. These run at xx03 from Bristol with even hours running to Weymouth and odd hours to Westbury. These trains all run to/from Gloucester as the additional service on that axis from Bristol. The current Bristol to Weymouth / Westbury / Warminster path at xx45 from Bristol extends to Salisbury most hours providing an hourly service at Dilton Marsh for most of the day.
Worcester to Bristol services become standalone and run every hour.
