The parts that were CPOd will be offered back per the rules. The rest will be redeveloped in a rush, probably at great loss.If OOC becomes the longer-term, or even permanent, terminus, what will happen to the massive building site that used to be called Euston?
It is being made safe for the time being.If OOC becomes the longer-term, or even permanent, terminus, what will happen to the massive building site that used to be called Euston?
It would be a bold move to fully cancel Euston and write off any chance of it being the eventual terminus, as there isn't another obvious site for a terminal station of its ilk. Can it be safeguarded indefinitely or is that not allowed?The parts that were CPOd will be offered back per the rules. The rest will be redeveloped in a rush, probably at great loss.
It is owned by HS2/us. It could sit there empty forever. I would sincerely hope that it is not offered for redevelopment but we can manage to somehow find a financially acceptable way to build it. It's all politics anyway, the amounts being spent are a trivial amount of government expenditure and the site is very likely to produce money for the government in the longer termIt is being made safe for the time being.
Not only is there no other obvious site, but if I understand the plans for OOC correctly, it would be almost impossible to divert the onward extension to a central terminus in any other direction. I suppose the tunnel boring machines could be redirected (hypothetically) to somewhere like Earl's Court/Olympia (although still not very central). Or Paddington, by moving more of the long distance trains out of the main shed (Heathrow Express for starters). There isn't any more space around Kings Cross/St Pancras.It is being made safe for the time being.
There was another suggestion of building a line via an underground station at Waterloo to Ebbsfleet. I can't remember which organisation suggested it as an alternative terminus and a way to reach HS1. If I remmber rightly is was very expensive.Not only is there no other obvious site, but if I understand the plans for OOC correctly, it would be almost impossible to divert the onward extension to a central terminus in any other direction. I suppose the tunnel boring machines could be redirected (hypothetically) to somewhere like Earl's Court/Olympia (although still not very central). Or Paddington, by moving more of the long distance trains out of the main shed (Heathrow Express for starters). There isn't any more space around Kings Cross/St Pancras.
Hunt said in an interview yesterday that no decisions had been taken, but he admitted that HS2 costs were out of control, largely because of inflation.Sunak just refused to comment on HS2 at his statement on Net Zero.
The costs aren't going to come down with a delay. Presumably it is volatility of cost that is unbelievable, rather than the actual cost. If it is unacceptable now, it is never going to be acceptable, as it will always be greater than the point at which it is paused.I imagine the tactic will be to suspend work on Phase 2 until the costs of the whole project are believable and acceptable.
That doesn't remove the cost of building to Euston, nor is it practical at Old Oak Common.What about half of the services stop at OOC and half to Euston.
It depends on the politicians to be honest. Should the current plans go ahead without further interruption, then Phase 1 OOC-Curzon Street is 2029-33, Handsacre link for WCML services is also 2029-33 but 18-24 months later than the first services, services to Crewe are 2034/35 and Manchester opens 2037-41. Euston will open either in time for Crewe or the full Manchester service, depending on the results of the redesign. The current industry rumours that I am aware of are that a 6/7 platform station will open for 2034/35 for Crewe, and the remaining platforms for the 2037-41 full service. The TBM to Euston was scheduled, even with the current delay, to launch the tunnel drive in around 18-24 months, and is being installed and buried now to enable this.Iirc, Euston is meant to open in 2036. Do you guys think this is likely? or do you think it's possible it will open earlier after the economy stabilises in a couple of years, or will it open later? You guys have been following railway construction for years, so your gut instincts will be better than mine.
They could come down either through descoping (fewer platforms?) or through value engineering i.e. reducing the quality of the station - but I would imagine the latter would be fairly marginal.The costs aren't going to come down with a delay. Presumably it is volatility of cost that is unbelievable, rather than the actual cost. If it is unacceptable now, it is never going to be acceptable, as it will always be greater than the point at which it is paused.
ThanksIt depends on the politicians to be honest. Should the current plans go ahead without further interruption, then Phase 1 OOC-Curzon Street is 2029-33, Handsacre link for WCML services is also 2029-33 but 18-24 months later than the first services, services to Crewe are 2034/35 and Manchester opens 2037-41. Euston will open either in time for Crewe or the full Manchester service, depending on the results of the redesign. The current industry rumours that I am aware of are that a 6/7 platform station will open for 2034/35 for Crewe, and the remaining platforms for the 2037-41 full service. The TBM to Euston was scheduled, even with the current delay, to launch the tunnel drive in around 18-24 months, and is being installed and buried now to enable this.
However, should the politicians announce any more changes, then all bets are off.
Isnt Cost pressure eased if you slow down build so are chasing fewer construction workers/assets at any one time?The costs aren't going to come down with a delay. Presumably it is volatility of cost that is unbelievable, rather than the actual cost. If it is unacceptable now, it is never going to be acceptable, as it will always be greater than the point at which it is paused.
To a degree, but your other costs will keep climbing.Isnt Cost pressure eased if you slow down build so are chasing fewer construction workers/assets at any one time?
Immediate costs are reduced, but in simple terms, if you employ 10 workers for two years at £30,000 per year with 5% annual wage increases in total you pay £615,000.Isnt Cost pressure eased if you slow down build so are chasing fewer construction workers/assets at any one time?
Umm, and what revenue is expected. Hint - the current farebox is £135m for Birmingham Int and New St to Euston.You also put back the commencement of revenue generation which as financing will almost certainly be through borrowing means higher cumulative financing costs.
Think of it like the difference between a ten year and a twenty five year mortgage, the annual payments will be higher on the shorter mortgage but you end up paying far less in the long run.
Costs on HS2 aren't out of control because of inflation, if they are out of control it is because the project management has been about as good as that for Berlin Brandenberg airport.
HS2 also hasn't opened yet!Berlin Brandenburg was 11 years late and 3.5x over budget. HS2 isn’t quite that bad!
Nothing is happening now on the existing station. The HS2 part is make safe and wait.What is the plan now for the existing Euston station , just leave as is?
And then the operational cost of running and maintaining the line needs to be deducted from those fares .
You also get to defer paying for rolling stock, if your supplier and the contract have not been inked with a fixed date already. Oh.
Interesting front page of tomorrow's Times. Also goes on to say that there are real splits in govt and the cabinet, with Michael Gove named as pushing hard for it to be built in fullRishi Sunak has been told by David Cameron and Boris Johnson to drop plans to scale back HS2 amid warnings that a "mutilated" line would be "insanity" https://www.tomorrowspapers.co.uk/times-front-page-2023-09-23/
