Some more changes were made to the routeing guide on the Friday before last, Monday and Tuesday. Sorry about the delay. Friday's changes were:
Comparing RJRG0512 to RJRG0513 published 27 April 2018
Maghull North (MNH) has been added to the routeing guide data. duye to open 18 June 2018
This is associated with Liverpool, Preston and Wigan, (like Maghull), although there are no fares in the published NFM64 list for it.
I notice that the code for the station is given as MNH here, but MNS in the timetable feed file. I'm sure they'll settle on something before it opens.
Adding Timing Links to the maps in preparation for Derby resignalling. This will allow journey planners to generate journeys that do not pass through the (G09) Derby routeing point by adding in a timing connection between Chesterfield and Tamworth routeing points.
Map BY - BIRMINGHAM TO YORK changed (1 added/ 0 removed links)
Map PY - PLYMOUTH TO YORK changed (1 added/ 0 removed links)
Crosscountry trains between Birmingham and Chesterfield or Nottingham will go via Castle Donington instead of Derby. There are 16 other maps which include the Chesterfield-Derby-Tamworth section, and 12 which include Nottingham-Derby-Tamworth.
Duplicate easement(s) removed - covered by easement 700761
Removed 700776: Customers from Burley Park to Rickmansworth may travel via Leeds. This routeing point easement will override fares checking and operate in both directions
For 700761 here, read 700777.
2 easement(s) changed
700761: Due to engineering works affecting journeys via Cheltenham Spa and Bristol. Cross Country services will be diverted via Kemble, Swindon and Bath Spa on Saturdays 12, 19 and Sundays 13, 20 May 2018. This map easement will create temporary permitted routes and will apply in both directions.
This used to say "via Bristol Parkway", and covered fewer dates.
700777: Customers to Rickmansworth or Amersham travelling from stations between Hornbeam Park and Burley Park, and between Ilkley and Kirkstall Forgemay travel via Leeds. This routeing point easement will override fares checking and will operate in both directions
This applied to "stations in West Yorkshire" previously.
They also fixed a typo in easement 700781.
Monday's changes were:
New data set 513 published 30 April 2018
Comparing RJRG0513 to RG0512
For engineering diversions easement(s) added
Added 700782: Over the Bank Holiday weekend of the 05 -07 May 2018. Ticketspriced on (00000) ANY PERMITTED from or via Reading to London Terminals, (excluding Radley and Oxford) will be valid via Basingstoke and Surbiton to London Waterloo. This map easement will apply in both directions
That's ANY PERMITTED, and not VIA BANBURY, or AAA PANGBOURNE, or anything like that. Oxford-London tickets will remain valid via Ascot.
Added 700783: Due to Sunday trains from Glasgow Central being diverted via Mount Florida from 13 May to 09 September 2018, connecting services require this map easement to ensure journey opportunities are presented to customers. This easement will apply in both directions
There are no trains through Motherwell (on 13 May, at least), so this probably means some tickets will be allowed from Glasgow to somewhere via Mount Florida, Newton and Holytown. I don't know how much the easement covers, as the above is all it contains.
Added 700784: During engineering work over the Bank Holiday weekend 05 -07 May 2018, affecting journeys into London Paddington. Tickets from Worcester, Evesham and stations on the route to Oxford may travel to London Marylebone via Oxford and Princes Risborough. This map easement applies in both
Unless I've missed something, this easement allows you to do something which is permitted anyway.
Dated easement(s) removed
Removed 700762: Due to engineering works on the 17 and 18 March 2018, journeys to London from Cheltenham Spa to London Terminals may travel via Birmingham New Street and Milton Keynes. This map easement applies in both directions
Removed 700763: On Sunday 1st April 2018, during the engineering works closure of London Euston. Journeys using the outward pportion of tickets from Liverpool Lime Street to London Terminals, may travel to London St Pancras via a rail replacement bus service between Rugby and Kettering. This map easement applies in both directions
Removed 700764: On Sunday 1 April 2018 during closure of London Euston, journeys from Manchester Piccadilly to London Terminals may travel on First Trans Pennine Express services to Leeds for onward connections to London Kings Cross. This map easement applies in both directions
Removed 700770: On Friday 30 March, to facilitate customers travelling from Bath Spa to Gloucester, temporary permitted routes via Swindon will be created by this map easement
All temporary easements with no future validity.
To add additional dates engineering easement(s) changed
6 change(s) in 700781: Due to engineering works on the 26 and 28 May 2018 affecting journeys on Virgin Trains to or via Birmingham New Street; this map easement will create temporary permitted routes via Tamworth, Stafford and Smethwick Galton Bridge. It will operate in both directions
27 May (a Sunday) has been replaced by 28 May here. As Virgin are taking the same route between London and Birmingham on both dates, this may not be intentional.
Tuesday's changes were:
New data set 0514 published 01/05/18
Comparing revision RJRG0514 to RJRG0513
Late request engineering work easement(s)
Added 700785: As a result of engineering works on the Bank Holiday weekend 05 - 07 May 2018, journeys to Crayford, Bexley, Albany Park, Sidcup, New Eltham, Mottingham and Lee (London) via Gravesend and Dartford may doubleback at Abbey Wood via Slade Green. This doubleback easement applies in both directions.
There are no trains between Crayford and Dartford (and none through Blackheath at all, for that matter). There are some between Slade Green and Dartford, but the faster ones don't stop between Abbey Wood and Dartford.
The text is a bit unclear, but according to nationalrail.co.uk this is valid for (for instance) Sidcup-Gravesend but not Sidcup-Dartford.
They also removed the changes to maps BY and PY which were made 4 days before.
