National Routeing Guide update
MikeWh
15 Jun 2010
Crayford
Indeed. Didn't we have confirmation from ATOC that that is how outboundary travelcards work? Would this change have needed approval from the DfT? Have any ticket sites implimented this change?
@yorkie @SickyNicky @Indigo2
FenMan
13 Oct 2011
I've only just noticed that a new version of the routeing guide instructions was published on 15 November 2019. The only substantive change is the addition of the following paragraph:
A NOTE ABOUT ROUTEING WITH OUTBOUNDARY TRAVELCARDS
(TRAVELCARDS VALID FROM STATIONS OUTSIDE THE LONDON ZONAL FARE AREA TO ZONES WITHIN IT)
The route you take between your origin station and the point at which you first cross into the London zonal area (Zones 1-9) should be the route valid for a journey to ‘London Terminals’, regardless of the zone(s) to which the ticket is actually valid or the combination of London Travelcards being used. This does not affect validity within the London zonal area, where you are permitted to use any eligible National Rail service within the zone(s) for which your Travelcard is valid.’​
This is, I think, the first direct indication in the routeing guide of which routes are permitted for a Travelcard. As it specifies Travelcards, I assume this does not affect tickets to locations such as "Zone U6 London".
I've just checked a journey where a route is permitted to a station in the Zones that is not a permitted route to London Terminals. Both NRE and a MixingDeck site report the journey can be made using an outboundary Travelcard. This indicates there may be an issue in implementing this change in journey planners.
Paul Kelly
Verified Rep - BR Fares
16 Apr 2010
Reading
Is it really a change? It looks to have been done in a way similar to how non-contractual notes have recently been included in the NRCoT. It specifically calls itself "a note", and it also says your route "should" (i.e. not "must") be valid for a journey to London Terminals. It's also very weird the way it says it should be a route to "London Terminals", a fares concept, and not "London Routeing Group". This looks to me like a non-contractual addition. It probably is worth somebody asking DfT and Passenger Focus about documentation relating to the consultation process, though.
kieron
22 Mar 2012
Connah's Quay
You can buy a ticket to "London Terminals" from most (if not all) stations outside the London zones, so asking people to use the routes they would use for one of those has a clear meaning. "London routeing group" is only used in the routeing guide for calculating mapped routes, so I don't know how easements affect it or how shortest route calculations could be made.
I don't know if there's a difference between "should" and "must" in the way each is used in the routeing guide, though, or what the significance is of calling it a "note",
kieron
22 Mar 2012
Connah's Quay
Some more changes were published this afternoon.
Changes from 08 Jan 2020 (289) to 15 Jan 2020 (290).
Permitted Route changes:
Hitchin (HIT) to Stratford London Gp (G74) gain AS+OV lose KE+OV
Stevenage (SVG) to Stratford London Gp (G74) gain AS+OV lose KE+OV
These journeys no longer have mapped routes via both Canonbury and London which do not go via Shadwell.
Peterborough (PBO) to Stratford London Gp (G74) gain AS+OV
This journey now has mapped routes via Canonbury which do not go via London.
Easement changes:
Added:
700895 (Fare route) Due to engineering works and the replacement of trains with rail replacement bus services on Sundays 19 and 26 January 2020 and Saturday 25 January 2020. Tickets to and from Dagenham Dock, Rainham (Essex) and Purfleet priced (00112) VIA BARKING, will be valid on rail replacement bus services travelling to Upminster.
This is the same as easement 700893 for just after Christmas, except that the buses are going to Upminster here rather than Grays.
700896 (Fare route) Due to engineering works and the replacement of trains with rail replacement bus services on Sundays 19 and 26 January 2020 and Saturday 25 January 2020. Tickets to and from Dagenham Dock, Rainham (Essex) and Purfleet priced (00114) VIA GRAYS, will be valid on rail replacement bus services travelling to Upminster.
As above, except for "via Grays" tickets. You can buy Purfleet-Upminster tickets with either route, so it's important to be able to catch the bus with them.
kieron
22 Mar 2012
Connah's Quay
Some more changes to the routeing guide were published this afternoon.
Changes from 15 Jan 2020 (290) to 22 Jan 2020 (291).
Huddersfield Group (G40) to Warrington Group (G31) gain GM+NO
Leeds Group (G16) to Warrington Group (G31) gain MN+NO
Stalybridge (SYB) to Warrington Group (G31) gain GM+NO
Warrington Group (G31) to York (YRK) gain NO+MN
These journeys now have mapped routes via Newton-le-Willows.
Easement changes:
Added:
700897 (Map) Due to engineering work diversions on the weekend of 25 and 26 April 2020, Cross Country services will be diverted between Cheltenham Spa and Bristol. This map easement will create temporary permitted routes via Swindon and Bath Spa and will apply in both directions.
The diversions have not yet been loaded into the timetable.
kieron
22 Mar 2012
Connah's Quay
Some more easements were published on Friday.
Changes from 22 Jan 2020 (291) to 31 Jan 2020 (292).
Easement changes:
Added:
700898 (Routeing Point) Customers travelling from Roydon (Essex), Harlow Town and Harlow Mill to Basildon, Laindon or West Horndon may travel via Upminster. This routeing point easement applies in both directions
Pitsea is a valid routeing point for all of these journeys, so you could already get a web site to show a route via Upminster was valid, simply by putting a double back to Pitsea at the end. None of the available tickets restrict break of journey, so you could miss out the double back when you travel.
With this easement, you can leave out the double back.
700899 (Routeing Point) Customer travelling from Redhill to Northumberland Park, Meridian Water, Ponders End, Brimsdown Enfield Lock and Waltham Cross may travel via Tottenham Hale. This routeing point easement applies in both directions
This easement permits something which was already permitted before it was published. Tottenham Hale is part of the "Tottenham Hale Und" fare group, and the Tottenham Hale Und-Redhill fares are lower than the ones from Redhill to Northumberland Park, etc..
When the routeing guide data feed was updated to include these easements, it was accompanied by another change. Tottenham Hale is no longer listed as part of the Tottenham Hale Und fare group.
Tottenham Hale itself doesn't have any fares listed in the NFM64 list, and there's no substitution given for it in the "new station" list. This means that, while (say) Tottenham Hale-Ipswich has the same valid routes as before, Tottenham Hale-Felixstowe is not longer shown as being permitted via London (as the shortest route goes via Lea Bridge instead).
I don't think there are any other significant changes in the "stations" file, but there are a lot of files in the feed I haven't looked at yet.
Kite159
27 Jan 2014
West of Andover
Considering that going via upminster is the most logical way to reach those stations, seems a bit silly to have to make an easement for it.
kieron
22 Mar 2012
Connah's Quay
Easements were created to enable people to travel in situations where applying the standard rules gives a silly outcome. In this case, it's because the single fares in a 1996 price list aren't a totally reliable guide to which routes are sensible for a journey you might make today.
kieron
22 Mar 2012
Connah's Quay
Some easement changes were published this afternoon.
Changes from 31 Jan 2020 (292) to 03 Feb 2020 (293).
Easement changes:
Removed:
Temporary easements which have now expired.
Added:
700900 (Routeing Point) Due to engineering works and the replacement of trains with rail replacement bus services on the weekends of 09/09 February 2020, 29 February and 01 March 2020, 14 - 15 March 2020, Easter holiday 10 - 13 April 2020 and 18-19 April 2020. Tickets to and from Dagenham Dock, Rainham (Essex) and Purfleet priced (00114) VIA GRAYS, will be valid on rail replacement bus services travelling to Upminster.
700901 (Routeing Point) Due to engineering works and the replacement of trains with rail replacement bus services on weekends of 08-09 February 2020, 29 February - 01 March 2020, 14 - 15 March 2020, Easter holiday 10 - 13 April 2020 and 18-19 April 2020. Tickets to and from Dagenham Dock, Rainham (Essex) and Purfleet priced (00112) VIA BARKING, will be valid on rail replacement bus services travelling to Upminster.
These are equivalent to easements 700893 and 700894, but with different dates. As before, the buses run between Grays and Upminster, and no trains or rail replacement buses stop at Dagenham Dock.
TUC
11 Nov 2010
Is ir just my misconception, or is it just London that seems to issue Routing Guide amendments that are purely to cover RRBs?
kieron
22 Mar 2012
Connah's Quay
I don't know. These ones were needed because they let you use a "via X" ticket on a route which doesn't go through "X". This sort of situation may be a bit more common in & around London because of the denser rail network, but it does happen in different parts of the country.
kieron
22 Mar 2012
Connah's Quay
Some more easement changes were published this afternoon.
Changes from 03 Feb 2020 (293) to 12 Feb 2020 (294).
Easement changes:
Removed:
The "new stations" file now lists Tottenham Hale as using the prices defined for Northumberland Park (this actually changed on 3 February, although I didn't check it at the time). This means that it passes the fare check for all of these journeys without an easement.
Added:
700902 (Map) Due to engineering work, on the 02 - 03 May 2020 Cross Country services will be diverted between Cheltenham and Bristol via Swindon and Bath Spa. This map easement will operate in both directions
The only trains from Bristol Parkway on those dates are going to/from London via Swindon. Crosscountry are diverted via Swindon between Bristol and Cheltenham, using this easement. GWR are diverted via Gloucester between Swindon and Newport, with no easement.
kieron
22 Mar 2012
Connah's Quay
A new easement was added to the routeing guide this afternoon.
Changes from 12 Feb 2020 (294) to 19 Feb 2020 (295).
Easement changes:
Added:
700903 (Circuitous Route) Customers travelling to London Terminals from Tilbury Town and Tilbury Riverside may not use ferry connections and travel via Gravesend. This circuitous route easement applies in both directions.
This is, I suppose, intended to compensate for the fact that fares from Tilbury are generally cheaper than ones from Gravesend, even with £5 for the ferry.
kieron
22 Mar 2012
Connah's Quay
Two more easement changes were published yesterday:
Changes from 19 Feb 2020 (295) to 21 Feb 2020 (296).
Easement changes:
Added:
700904 (Fare route) Due to engineering works on 22 and 29 March 2020 and the replacement of services with rail replacement buses, there will be fast bus services operating between Worcestershire Parkway and Gloucester that do not stop at Cheltenham Spa. Tickets priced on (00171) VIA CHELTENHAM SPA, will be valid on these services.
From a brief check, it appears that "via Worcester" tickets (as mentioned in easements 700703, 700704 and 700731) will not be valid on these services.
Changed:
700903 (Circuitous Route) Customers travelling to London Terminals from Tilbury Town and Tilbury Riverside. Or via Tilbury Riverside, may not use ferry connections and travel via Gravesend. This circuitous route easement applies in both directions.
This increases the range of journeys this easement affects.
Kilopylae
9 Jan 2018
Oxford and Devon
[1] Does anyone have any record of this original confirmation from A.T.O.C.? The closest I can find is a July 2012 forum post from user OwlMan, where he said, in reference to a Boundary Zone 6 ticket, that A.T.O.C. had told him:
It is only valid if used with a valid Travelcard/Freedom pass that covers zone 6.
It is valid to the first crossing of the outer boundary of Zone 6, using any permitted route (observing any fare related restriction) to any station within zones 1-6 that the associated Travelcard/Freedom pass is valid to.
[2] Is there any precedent for non-contractual additions to the Routeing Guide, or, other than poorly informed T.O.C. Twitter accounts, routeing advice from generally accepted authorities that has been proven to be non-binding or incorrect?
I don't have it in writing, but I do know that the planners implement it, and it is the reason why the outboundary Travelcards from the south WCML have "route Watford Junction" on them, whereas the point to point fares don't.
JB_B
27 Dec 2013
JB_B
27 Dec 2013
No, I meant they implemented the idea that you could use any permitted route to the boundary station of your choice.
I don't know if they have been changed in accordance with that link yet.
OK - thanks - in that case we're in agreement. As far as I can tell (e.g looking at Reading to Coulsdon South for which NRE offers a travelcard) journey planners haven't changed their behaviour since the mid Nov '19 change to the RG instructions text. ( As expected.)
Kilopylae
9 Jan 2018
Oxford and Devon
I've had a look to check whether or not N.R.E. has changed, and it was happy to sell me a Super Off-Peak Day Travelcard from Exeter St David's (£97.80) with the following itinerary, clearly based on the classical interpretation that a Zone Six station may be selected and any permitted route used thereto:
Exeter St Davids [EXD] > Westbury [WSB]
Westbury [WSB] > Swindon [SWI]
Swindon [SWI] > Didcot Parkway [DID]
Didcot Parkway [DID] > Oxford [OXF]
Oxford [OXF] > West Ruislip [WRU]
I would be very surprised to find that a guard on any of those trains would reject an Exeter St Davids out-boundary Travelcard, even without a printed itinerary from N.R.E. - though it now seems that such a journey is "grey area" at best, and I might very much need to bring a supporting document with me!
kieron
22 Mar 2012
Connah's Quay
Another easement was added to the routeing guide this afternoon
Changes from 21 Feb 2020 (296) to 26 Feb 2020 (297).
Easement changes:
Added:
700905 (Local) Customers from Ashchurch for Tewkesbury travelling to Worcestershire Parkway may travel via Cheltenham Spa. This local easement applies in both directions
Previously, NRE treated direct trains as valid, as well as ones with a change at Worcester Foregate Street/Shrub Hill. This change adds a few more journey opportunities.
I have noticed that, if I put this journey into NRE, it usually assumes that anyone travelling via Cheltenham would prefer to go all the way to Gloucester before doubling back. The easement hasn't been implemented on NRE yet, but I worry that this may make it less effective than intended.
kieron
22 Mar 2012
Connah's Quay
Another easement was published this afternoon.
Changes from 26 Feb 2020 (297) to 03 Mar 2020 (298).
Easement changes:
Added:
700906 (Map) Due to engineering diversions on Sundays from 10 to 31 May 2020, Cross Country trains will be diverted between Leeds and Swinton. This map easement will create temporary routeing links for electronic journey planners that avoid travel through either the Wakefield or Pontefract group routeing points. It will apply in both directions.
Crosscountry will send their trains via Fitzwilliam, Normanton and Woodlesford on those dates, avoiding the stations in both Pontefract and Wakefield groups.
There are some trains (such as the Friday 23:15 from Sheffield to Leeds and the Sunday 18:27 from Plymouth to Leeds) which use this route on a more regular basis. This easement does not affect these in the same way.
kieron
22 Mar 2012
Connah's Quay
Another temporary easement was added to the routeing guide this morning:
Changes from 04 Mar 2020 (299) to 12 Mar 2020 (300).
Easement changes:
Added:
700907 (Map) This easement allows travel from London to Shenfield and beyond on replacement bus without calling at Romford during engineering works on 15/03/2020 and 22/03/2020
The line from Shenfield to London is closed on both dates, with buses from Ingatestone to Newbury Park and a London Underground connection from Newbury Park.
kieron
22 Mar 2012
Connah's Quay
Two easements were added to the routeing guide this afternoon.
Changes from 12 Mar 2020 (299) to 25 Mar 2020 (300).
Added:
700908 (Map) During engineering works on 22/03/2020 and 29/03/2020, customers travelling from Cleethorpes, Grimsby or Scunthorpe to Manchester or Manchester Airport may travel using Services between Sheffield and Huddesfield. This easement applies in both directions.
There are no through trains planned on this route on Sunday, and the fastest route then goes via Leeds rather than Sheffield.
700909 (Doubleback) Customers travelling via Motherwell and via Carlisle may double back between Carstairs and Edinburgh. This easement applies in both directions and applies until 30/05/2020.
Caledonian Sleeper are currently sending trains to/from Glasgow with a double back between Carstairs and Edinburgh, so this accommodates some journeys using their trains.
A London-Carstairs or London-Motherwell journey is valid anyway due to it being a through service. This isn't the case if your ticket starts before London, or if you intend to change at Carstairs to go to somewhere like Holytown.
clagmonster
8 Jun 2005
Interesting that 700908 does not mention customers travelling from Habrough or Barnetby. I would have thought from or via Scunthorpe to or via Manchester a more appropriate wording. The easement will have been implemented because TPE trains are diverted Sheffield - Manchester via Huddersfield and that is the route TPE publicity recommends, although I agree going via Leeds is the more sensible route as it is faster and both involve two changes.
kieron
22 Mar 2012
Connah's Quay
Thanks. I didn't check the TPE site yesterday.
You would need to change three times if you were going to/from Manchester Airport on this route, though, as the Sheffield trains only go as far as Manchester Piccadilly.
NRE doesn't seem to consider the route in easement 700908 to be a valid itinerary for a Cleethorpes-Manchester journey, though. I suspect this may be (at least in part) because there's no easement to let you double back through Meadowhall for that journey. At least it accepts the route involving rail replacement buses.
Paul Kelly
16 Apr 2010
Reading
I suspect this may be because there's no easement to let you double back through Meadowhall for that journey.
Correct - journey planners don't even get as far as checking for the map easement, as the route is already invalid due to the doubleback, which is through Swinton (and possibly Rotherham, depending on the exact route taken) as well as Meadowhall. It's an interesting diversion.
kieron
22 Mar 2012
Connah's Quay
Some more changes were published to the Routeing Guide on Wednesday.
Changes from 25 Mar 2020 (300) to 22 Apr 2020 (301).
Easement changes:
Removed:
700890 (Map) On Sunday 08 March 2020, Cross Country services will be diverted via Newport (South Wales). This map easement will apply in both directions.
Temporary easements which have had no effect since March.
Changed:
600069 (Circuitous Route) Customers travelling from or via Stratford Domestic station to or via London St Pancras may not travel via Stratford International except on tickets routed 00131 Plus High Speed. This easement applies in both directions.
The PDF easement now covers tickets for journeys via Stratford, as well as ones going to or from there. It doesn't affect one of the HS1 ticket codes now, however.
The easement data file shows this easement a bit differently. This already forbade journeys via Stratford, Stratford International and London St Pancras, but only affected tickets with one of a list of route codes.
For Ipswich-Gravesend (as an example), this means that a flexible ticket is not shown as being valid on ticket sites (as the route code is "+any permitted"), but an advanced ticket may be (as the route code "(00330) +AP GA Plus HS1" is mentioned in neither version of the easement).
The route codes referred to in the data file version are:
(00000) Any Permitted
(00003) Stratford/London
(00006) Via Tottenhm Hle
(00043) Avanti
(00045) Not Via Norwich
(00051) Via Shenfield
(00074) Via Norwich
(00135) Via Cambridge
(00200) Via London
(00420) Ap Grtang&Concts
(00827) Londn Strd/Evshm
(00840) Via Honiton
700831 (Fare route) For journeys from or via West Ealing to or via High Wycombe using tickets priced on routes (00813) VIA GREENFORD (UND) and (00200) VIA LONDON may be used on the 11.47 direct service that runs Mondays to Fridays. This fare route easement applies only to the 11.47 through service.
700832 (Fare route) Journeys to and via West Ealing Mondays to Fridays, that involve interchange at South Ruislip and onward travel on the11.02 10.55 through train between South Ruislip and West Ealing will be permitted on tickets priced on (00813) VIA GREENFORD (UND) and (00200) VIA LONDON. This fare route easement only applies to journeys using the 11.02 service
I don't know the intention behind these easements. If 700832 was intended to permit someone with (say) a High Wycombe-West Ealing "via Greenford" ticket to use the 11:02 from West Ealing, I don't think it's enough. If I work through the routeing guide instructions, I find:
1. There is no through train.
2. West Ealing and South Ruislip are listed on table 115 in the National Rail Timetable, but no distance is given between them. This means that the shortest route goes another way.
3. This isn't part of a mapped route, as the only places which are linked to South Ruislip on any map are London and High Wycombe. Without a link on a map to Greenford or to Ealing Broadway Group, no mapped route can cover this journey.
As it's a "via Greenford" fare, I may be able to look at routes to & from Greenford West Junction (which counts as being part of Greenford station). A High Wycombe-Greenford journey has all of the above problems, however, so this doesn't help.
Unfortunately, neither do these easements.
Route changes:
Changed:
VIA GREENFORD (00813) (169 records)
must go via Greenford (GFD)
must include tube
Removing the requirement to use the tube (which wasn't printed on the tickets) does help with obtaining an itinerary involving the trains between West Ealing & South Ruislip/High Wycombe.
For instance, breaking South Ruislip-Ealing Broadway ticket down at Greenford gives a South Ruislip-Greenford leg (which is a through train), followed by a Greenford-Ealing Broadway leg (which is the shortest route).
kieron
22 Mar 2012
Connah's Quay
Changes from 22 Apr 2020 (301) to 27 Apr 2020 (302).
Easement changes:
Added:
700910 (Circuitous Route) Customers travel From or via Reading to London Heathrow (bus terminal) on tickets priced (00951) AP RAILAIR READING or (00953) RAILAIR READING may not travel via Slough. This negative, circuitous route, easement applies in both directions
According to the RailAir web site, direct buses aren't running between Reading and Heathrow at the moment. It says:
"Due to the reduction in demand for air travel as a result of Covid-19, our RailAir services between Guildford, Reading and Heathrow Airport have been temporarily suspended after the last journey on Saturday 25 April 2020, with no services operating from Sunday 26 April 2020 until further notice."
There are still buses from Slough and Feltham to Heathrow. This easement says that these may not be used via Slough. My understanding of the route code details (described below) says they may not be used via Feltham.
AP RAILAIR READG (00951) (246 records)
must not go via London
must go via Reading (RDG) group
must not go via Feltham (FEL) or Woking (WOK)
must include bus
RAILAIR READING (00953) (575 records)
must not go via Feltham (FEL), Watford Junction (WFJ) or Woking (WOK)
must include bus
It isn't entirely clear to me what they would like someone who has one of these tickets and wishes to travel to or from Heathrow to do.
