Some more changes were published in the routeing guide yesterday.
Changes from 25 Nov 2021 (364) to 01 Dec 2021 (365).
Easement changes:
Removed:
700513 (Local) Passengers traveling from Saxmundham and Wickham Market to Norwich may travel via Ipswich, Stowmarket and Diss. This easement applies in both directions.
The tickets are all either "via Ipswich" or "via Lowestoft" now, so this wasn't needed.
Added:
700970 (Routeing Point) Customers travelling to Putney from Upminster may go via Clapham Junction. This routeing point easement applies in both directions
This easement does for Upminster what 700969 was intended to do. It doesn't affect any routes which are permitted under the "shortest route" rule (of which there are a few), and doesn't affect Oyster or contactless journeys, but it has an effect.
700971 (Map) During weekend engineering works 8th/9th, 15th/16th, 22nd/23rd, 29th/30th January 20222 when the route between Didcot and Swindon is blocked. Customers from/via Didcot may travel via Reading and Pewsey to reach Bath Spa and beyond to Bristol and South Wales. This map easement will apply in both directions
This creates a route from Didcot to Bristol via Reading and Newbury, but the data doesn't restrict its use to journeys from or to anywhere. That sad, the only flexible Didcot-Bath tickets are "via Swindon" ones, which wouldn't be valid this way.
700974 (Fare route) During engineering work disruption on the weekends of the 8/9, 15/16, 22/23 and 29/30 January 2022. Fares priced on route (00810) NOT VIA READING from or via Didcot Parkway to Bristol and beyond are valid via Reading. This fare route easement applies in both directions
This means that the "not via Reading" tickets offered for (say) Appleford-Bath are valid on the diverted route. In the data, this is shown as something which is valid for journeys which go via Newbury and also from/to/via Didcot.
700972 (Local) Customers travelling from Soham to Newmarket or Dullingham may travel via both Ely and Cambridge this Local easement operates in both directions
700973 (Doubleback) Customers travelling from Soham to Newmarket or Dullingham may travel via Bury St Edmunds. This doubleback easement applies in both directions
Web sites treat the shortest route as being with a change at Kennett, but there's only one westbound train a day which stops at both. These easements permit you to use the better-served routes via Bury St Edmunds, and via Ely and Cambridge.
Having a look at a couple of web sites, greateranglia.co.uk only seems to show the journeys via Bury St Edmunds as being valid, whereas gwr.com only accepts those via Ely and Cambridge.
Changed (added sections in red, removed ones in green):
700964 (Routeing Point) Customers travelling to Kennett and Soham from or via London Liverpool Street on tickets priced on route (00000) ANY PERMITTED may travel via Stowmarket. This routeing point easement will overcome NFM64 fares checking, and operate in both directions.
Tickets to Soham use the same NFM64 fares as Kennett, so they have the same limitations.
Easement 700116 (GREATER ANGLIA)
Customers travelling from March, Manea, Kennett,Bury St Edmunds, Thurston and Elmswell to or via Ely, may travel via Cambridge. This positive local easement applies in both directions.
+ve local easement (07/03/2011-)
contain ELY, go from BSE ESW KNE MCH MNE SOJ TRS & go via CBG
contain ELY, go to BSE ESW KNE MCH MNE SOJ TRS & go via CBG
Stations:
Bury St.Edmunds (BSE)
Cambridge (CBG)
Ely (ELY)
Elmswell (ESW)
Kennett (KNE)
March (MCH)
Manea (MNE)
Soham (SOJ)
Thurston (TRS)
Soham has been added to the data for this easement, but not the text. Every train which calls at Soham also calls at Ely.
The following post was made on 2 Dec 2021. Sadly, Xenforo does not preserve this information.
An easement was changed today.
Changes from 01 Dec 2021 (365) to 02 Dec 2021 (366).
Easement changes:
Removing the route restriction means you can travel via Ipswich with "AP Greater Anglia Only" tickets to London, as well as a variety of tickets for longer journeys.
The following post was made on 9 Dec 2021. Sadly, Xenforo does not preserve this information.
Some more changes were made to the routeing guide yesterday.
Changes from 02 Dec 2021 (366) to 08 Dec 2021 (367).
Permitted Route changes:
Guildford (GLD) to New Malden (NEM) gain EF
Guildford (GLD) to Surbiton (SUR) gain EF
These journey now has mapped routes via Claygate.
This is the shortest route from Guildford to New Malden or Surbiton, but may not be if you're travelling from Crowthorne.
Guildford (GLD) to Raynes Park (RAY) gain EF lose PD
This journey no longer has mapped routes via Clapham Junction.
Guildford (GLD) to Wimbledon (WIM) gain EF lose PD PD+SC
This journey no longer has mapped routes via Clapham Junction or via Sutton.
These changes made these routes more consistent with one another. Journeys from Guildford to Surbiton and New Malden now have mapped routes via Claygate and via Worplesdon, whereas ones to Raynes Park and Wimbledon also have a mapped route via Motspur Park.
Easement changes:
Added:
700975 (Routeing Point) Customers travelling from Kennett and Soham to Dullingham and Newmarket may travel via Ely and Cambridge. This routeing point easement will overcome NFM64 fares checking and apply in both directions
For Soham, this is a "routeing point" version of the "local" easement 700972. I don't know if this easement is the reason, but greateranglia.co.uk now shows both this route and the one via Bury St Edmunds as being valid. Not every web site does, though.
700976 (Doubleback) During engineering work diversions between 27 and 31 December 2021 and Sundays 09 and 30 January 2022 Cross Country services will travel via Newport (South Wales) passing Severn Tunnel Junction twice. This doubleback easement will permit the doubleback and operate in both directions.
The line through Bristol Parkway is closed then. A few trains will reverse just west of Severn Tunnel Junction (and so don't need an easement), but most reverse in Newport, and do. Unlike some previous easements, this is only shown as a valid route if you use Crosscountry to and from Newport.
Easement 700971 (GWR)
+ve map easement valid on Sa Su (08/01/2022-30/01/2022)
contain BPW BRI BTH DID FIT LWH NBY RDG RDW SRD TRO WSB & go from DID
contain BPW BRI BTH DID FIT LWH NBY RDG RDW SRD TRO WSB & go to DID
contain BPW BRI BTH DID FIT LWH NBY RDG RDW SRD TRO WSB & go via DID
This restricts the data for the easement to journeys from/to/via Didcot.
700974 (Fare route) During engineering work disruption on the weekends of the 8/9, 15/16, 22/23 and 29/30 January 2022. Fares priced on routes (00810) NOT VIA READING and (00847 VIA SWINDON from or via Didcot Parkway to Bristol and beyond are valid via Reading. This fare route easement applies in both directions
This change extends the easement to cover (for instance) Didcot-Bristol tickets.
