Old Oak Common Station construction
BrianW
22 Mar 2017
The first job is several miles of contiguous piling round the outside of the future station box and construct the bracing at surrounding (existing) ground level hence it won't look too much different from the above photo for a long time part from the piling rig and cranes moving.
There must be (in time) a lot of material 'arising' from what is dug out- any idea where it is going? I imagine it will be more than somewhat 'contaminated'?
Former Willesden container terminal, connected with a conveyor system, thence onward to landfill by rail. Hasn’t decontamination taken place prior to this stage?
Verulamius
30 Jul 2014
The Ian Visits website https://www.ianvisits.co.uk/blog/20...il-to-fill-in-a-cambridgeshire-open-pit-mine/ suggests that HS2 spoil is being used to fill up an old limestone mine in Cambridgeshire.
https://www.realtimetrains.co.uk/service/gb-nr:H01681/2021-06-29/detailed provides the detail of Tuesday's train to Barrington.
Meerkat
14 Jul 2018
If up to seven trains of spoil a day are being loaded does that not justify building a hopper loading system rather than using shovel loading?
Bristol
For only a couple of years, it's an expensive investment. Not to mention the diggers are more mobile, more flexible, easier to crew, don't require coveyers to lift spoil to the top of them, don't require wagons to be shunted for them and would probably be required anyway to smooth off the load.
Meerkat
14 Jul 2018
Fair enough - very comprehensive thanks!
Horizon22
Jobs & Careers
8 Sep 2019
I’ve noticed they’ve now dug up the tracks which formed part of the old HeX depot. The main building shell is still there though.
hwl
5 Feb 2012
The tracks to the east of the building were in the way of station box construction rather than the depot building itself.
matt_world2004
5 Nov 2014
Maybe the hs2 construction team are going to use the hex depot for storage and staff facilities seems bizarre to knock down a building only to build another one if it isn't in the way
Same reason they knocked down Kirkdale shed and replaced it with a new one in exactly the same place - the new building is more suitable for modern needs than the old one.
matt_world2004
5 Nov 2014
I meant construction staff facilities not train staff facilities I would assume the inspection pits and track pits.would need removing /filling in but apart from.that it could be used for.construcrion materials and toilets and showers for builders
Horizon22
Jobs & Careers
8 Sep 2019
These are the tracks to the south of the building - we might be talking about the same thing but it's here that Im talking about.
18 Oct 2017
Those tracks and the shed are in the way of the future GWML platforms and approaches. I've no idea of the programme, but presumably the sooner the old Hex infrastructure is out the way, the sooner they can start work on the new GWML side of the station infrastructure. At least the Western end - the Eastern end GWML sits on top of the HS2 station box - though IIRC they plan to build that "top down" so maybe they can work on the GWML once the structural elements and roof are on. Though the Euston Tunnel TBM's will be down there also for a while.
Horizon22
Jobs & Careers
8 Sep 2019
Those tracks and the shed are in the way of the future GWML platforms. I've no idea of the programme, but presumably the sooner the get the old Hex infrastructure out the way, the sooner they can start work on the new GWML side of the station infrastructure.
Yes I am aware they are, was just clarifying where it was and giving an update to the thread. The vast majority of activity remains in the station box.
Verulamius
30 Jul 2014
How does this relate to a proposal to create additional platforms so that the Chiltern line trains can terminate at OOC? There does not appear to be room on your picture?
Bristol
It's not part of the official plans, but an unofficial suggestion.
Yindee8191
16 Mar 2019
Does anyone know approximately when work is expected to start on the GWML platforms? I know it won’t be for a while since the station box has to be done first.
SynthD
4 Apr 2020
I think the squared area is not intended for the station itself, but the connections to those sidings are where the station will go. That squared area will be a park, and later the Chiltern station. It looks like it would be a tight fit.
18 Oct 2017
Schedule 17 Application for the OOC station (20/0012/HS2OPDC) contains some indicative timescales and indications of the construction method/sequencing.
Here's a link to the "Written Statement For Information" http://planningregister.opdc.london...heSeqNo=1396789485&theApnkey=9397&theModule=1
Here's an excerpt from the "construction programme" of said document, though these things tend to be highly fluid...
Proposed Programme and Sequence of Works
Anticipated Start on Site Date / Activity / Estimated Completion of Works
Underway / Enabling works / Q3 2020
Q3 2020 / HS2 station box / Q1 2026
Q1 2022 / Conventional rail overbridge and platforms / Q4 2026
Q3 2024 / OOC station main compound site restoration / Q2 2027
Q3 2020 / Enabling works for Old Oak Common Lane utility diversions / Q1 2021
Q1 2021 / Old Oak Common Lane utility diversions / Q1 2022
Q1 2021 / Replacement of Central Line Bridge / Q4 2026
Q1 2021 / Works to replace Great Western Mainline bridge / Q4 2026
Q4 2026 / Realignment works to Old Oak Common Lane / Q3 2027
There is no "Chiltern Station" - AFAIK it was only ever a crayonista dream. It won't be possible in future without knocking down part of Wells House Road or some very expensive and disruptive retrospective grade separation.
JamesT
25 Feb 2015
It was somewhat official crayonista. https://www.networkrail.co.uk/wp-co...-East-West-Rail-Strategy-summary-document.pdf is a Network Rail document from 2017 suggesting reinstating the Acton-Northolt line to allow trains from the Chiltern Line to access Old Oak Common.
Nicholas Lewis
9 Aug 2019
How disruptive is building the new station going to be to GWML services? GWR has been a state semi permanent disruption now for over a decade.
Id imagine some significant amounts of two track timetables. Whether that is weekends and bank holidays or mid-week remains to be seen post COVID.
They can probably build the northernmost platform and its tracks offline, then slew the track over during a short closure and make a start on the next one, and so on.
Not very, I’d expect. Look for example at how they widened Reading station from basically 4 to 9 through platforms. The only significant full closure there, (over a Christmas period), was to insert the new wider bridge at the west end throat.
In this case they don’t need to maintain access to an existing station, that removes a huge amount of temporary passenger route problems. So they’ll almost certainly build half of it offline to the north of the existing tracks and then probably re-route the reliefs through two of their eventual platforms. That will allow room to slew the mains to their new positions, and then build the rest of the platforms. That could even be done in separate up and down phases..
mr_jrt
30 May 2011
Brighton
I would have much preferred the grade separation and a Crossrail extension, but that was never the "Chiltern station" proposal, that was the Crossrail extension. The Chiltern station was to do away with the grade separation and thread a track or two between the relief lines and Wells house into a terminal platform (or two) north of the Crossrail platforms. I suspect a single track would fit easily (and would be fine for a low-frequency pair of platforms), the only real concern being how long a Chiltern platform or two you would be able to fit in.
Horizon22
Jobs & Careers
8 Sep 2019
I’ve noticed today they’ve start to tear into the old Heathrow Express depot - the side facing the railway has been gutted although the structure and signage is still there. Didn’t quite catch a photo.
The old line towards Northolt seems to be being dismantled but couldn’t tell.
