tbtc
The thing is, it should never have been built. Or rather, it should only have been built in conjunction with the other parts of the programme, and those other parts should have been built first, because they would have brought immediate advantage, whereas the Chord brought immediate overall disadvantage without the other bits.
To fail to acknowledge a mistake simply for reasons of pride is foolishness of the highest order.
I know that you have a fixation with How Things Were In 1998 but the rest of the world has moved on. Ordsall was built (rather than 15/16). Chat Moss was electrified (rather than the CLC). There were merits to these decisions, there will always be people sad that their favoured thing didn't get approved, but these things happened.
(obviously neither of these projects should have gone ahead - we should have spent all the money in Sheffield instead )
If you want to mothball something that cost tens of millions of pounds then fine, but you're not going to get any other infrastructure built with that approach, so you might as well use the lines that you do have - it's not as if mothballing the chord is going to encourate the Chancellor gets his chequebook out to spend tens of millions more money on another infrastructure in central Manchester in the hope that this one might actually be used.
Either you accept reality and build a timetable fit for the infrastructure we have or you fail.
The Forum seems split between those willing to fashion something realistic from the finite resources available (which will mean some compromises, some existing services being tweaked - maybe some long distance services having to pick up local calls, maybe some through services chopped in two) and those who aren't willing to let reality get in the way of their ambitions. Oddly, I thought that you'd normally have been in the former camp, when it came to other threads, but all of this appears to go out of the window whenever someone mentions the Southport line...
