- Joined
- 15 Apr 2008
- Messages
- 15,963
Not got it to hand but I hear ORR have said no again.
I thought that this had more or less got the ok?
I wonder why open access is encouraged on the ECML but not the WCML.
I recall ORR saying LM's Crewe-Euston direct service should be treated like an Open Access service as while they have franchise requirements to meet, they don't need to run a through service between Crewe and Euston to meet those requirements.
95. The original 2018 completion date for electrification works is now unlikely to be deliverable and there are uncertainties around the scope, timing and costs of the project still to be resolved. The expanded project will also still have to go through our own Enhancement Costs Adjustment Mechanism (ECAM) review before plans are finalised
Going off the above (and giving my memory cells a swift kick) Network Rail weren't opposed to Alliance but, and this it the key part, the ORR hadn't yet given permission for the paths to be used by Alliance. It appears from what The Planner has heard they've turned them down.
I guess they had a technical okay but have not got the offical okay.
One problem with WCML services is they are limited to 110mph unless tilting stock is used. This was the first open access application which stated the rolling stock would be tried and tested Pendolinos. In the past applications have used either stock limited to no more than 110mph or a new tilting Polaris train designed by CSRE (Chinese Sourced Rail Equipment.) Every time a CSRE train was mentioned senior people at Network Rail, ORR and DfT started saying the CSRE designs were fantasy and they would be able to get a reliable train working on UK gauge and even if they could we shouldn't be letting UK trains be built outside the EU.
North Western Trains did succeed in running some open access services to Euston but that was pre-Pendolinos.
Perhaps when mk4's are replaced from the ECML, some might have their tilt activated as I believe was originally intended.
I recall this too. I believe it was to improve the reliability of the locos? I'm not sure we would want to replace the tilt equipment in that case!Hadders said:I believe there was provision for tilt in the class 91's and MkIV's but it was never fitted so it can't just be activated.
Also, I seem to remember reading that when the 91's were re-engineered a few years ago the space earmarked for the tilt equipment was used for some other equipment (although I can't remember what).
Was the confirmation for Alliance from NR on the basis of 125mph stock? If not then 110mph non-tilt operation might be acceptable, although the comparatively poor acceleration of a Mk4 set vs a Desiro might still not make it acceptable to use displaced trains from the ECML.
Although they might not necessarily import the loco's as well as the Mk 4's.
Of course, if non tilting 125mph would be fine, we're going to have an abundance of HST stock available in the near future, which would be an easy solution.
it wont be fine though as 125mph running on the WCML is limited to tilting vehicles - or so i understand
The whole Alliance plan is wibble anyway
I didn't think that the class 91s were ever designed to tilt: Just the mark four coaches. It's more of a passenger comfort thing. The APT-P power cars tilted, but I'm not aware that the anti-tilt mechanisms that were fitted to their pantographs were ever part of the class 91 design.I believe there was provision for tilt in the class 91's and MkIV's but it was never fitted so it can't just be activated.
...Leeds - Warrington - Euston? Is there even demand for that?!
Why has this turned into wibble about class 91's? their plan was to use 6 car pendy's
Perhaps we return to topic of Alliance and the ORR seemingly saying no and where they go next?
They still have an active application with the ORR for GNER services: http://orr.gov.uk/consultations/acc...-applications/new-contracts-section-17-and-18
I would think the sensible thing to do for GNWR services is to wait until the next TPE and WC franchises are awarded but I imagine they'll be getting impatient given they were originally told to come back when the WC franchise was coming to an end and they did, but the award for the next franchise was rescinded.
So who thought that London Queens Park (NW6) was a really sensible option for a long distance service to start and terminate at.....?
Might have something to do with old beardy having more money than the government and could bankrupt us all with the legal challenge.
