hexagon789
Must've interpreted the WTT wrongly.Not quite. It's 29.5 mins for 390 timings (30.5 for 80x, which most Liverpool services are now timed for), which rounds to 30 and 31 minutes in the public timetable, respectively. However, there's no engineering allowance until after Milton Keynes, and it's very rare for trains to actually make it in 29.5 minutes.
The lack of engineering allowance before Milton Keynes really does seem "optimistic" to say the least; amongst regions where discrete engineering allowances are used (rather than an extra 10% being incorporated into the SRTs, as happens on the ex-SR regions) I don't think there are any other lines out of London where you can go over 50 miles without needing to incorporate an engineering allowance.
That being said, unlike trains on the Up Fast and Down Slow, trains on the Down Fast can't get held for conflicting trains at Watford Junction, Bourne End or Ledburn Jns.
Admittedly, 30.5 seemed over generous - not even quite 99mph start-to-stop.
When BR were genuinely proposing 155mph running on the WCML without any alterations to the curvature, you can kind of understand the reasoning behind adopting tilt - at those sort of speeds (admittedly you wouldn't be doing 155 'round most curves), the comfort factor is more pronounced.With the exeption of higher maximum speeds, I don't understand why tilt is even considered on UK rails, given it's impacts on our already very restrictive loading gauges
At 125 vs 110, the difference must be fairly marginal. As I said, the Northern ECML gets away with the higher cast deficiency to permit higher speeds. It can be lively (I've had similar rides in France and Switzerland though, and France in particular allows higher cabt deficiencies on its classic mainlines), it's not unsafe.
Perhaps when Virgin were originally aiming for 140mph, tilt was of greater benefit.
