As you're probably aware if you've been watching the trains, GBRF did take over the running of the steel trains to Shotton as predicted. Unlike the previous arrangement with Freightliner on this flow a while back (to help with a driver shortage), I understand the reason GBRF have taken over the Shotton flow is to do with a requirement of the Tata Group to have more than one supplier on this type of contract. It's fairly common for major users of railfreight (e.g. Tarmac, Cemex, Network Rail) to divide up work between two or more hauliers on separate contracts.
Interesting to see that Colas have immediately started using Class 70s on the Lindsey "Prax" contract, since Sunday. Many of the tank wagons used are still EWS prefixed and DB-owned.
The first train was the 6M57 Kingsbury tanks on Sunday with 70807 (none of the pics linked in this post are mine) -
https://www.flickr.com/photos/robmcrorie/52191535600/
70805 worked to Jarrow overnight and should return this afternoon.
70814 is on the way to Kingsbury with this morning's 6M57.
Another Colas move that was rather unexpected (at least to me) was the first despatch of concrete sleepers from Halling. I didn't even know there was a concrete sleeper plant being built there...
The sleepers were loaded to 18 of the new Wascosa FEAs fitted with flat decks (using the familiar engineers' fishkind "salmon").
https://www.flickr.com/photos/136510631@N08/52181997766/
Some of these sleepers have been used in engineering works at Severn Tunnel Junction over the weekend, which I think might be the first use of these new "modular" FEAs on an engineering worksite.
Can't find much information about the Halling sleeper plant online, but it looks like the area of the old Halling cement works sidings has been used to build a plant next to an existing "Cemex Floors" facility (which make things like concrete stairs). Can't resist a flashback to 1988 and a Class 73 shunting Rugby Cement wagons at this location -
https://www.flickr.com/photos/36034969@N08/11090409103
Another bit of news - DB are starting up a new intermodal flow from the "Tilbury 2" terminal at Tilbury Docks to Trafford Park, running in a lunchtime path from Tilbury. First train should be departing today.
For anyone not aware, "Tilbury 2" port development opened in January, and uses the connection to the main line which formerly served Tilbury Riverside and later Tilbury "IRFT" (International Rail Freight Terminal; it was used as a Stora paper terminal amongst other things). General plan of the site here, can't find anything more up to date -
https://tilbury2.co.uk/the-application/proposed-arrangement-tilbury2/
The container terminal at Tilbury 2 should not be confused with the old Freightliner Tilbury RCT (Rail Container terminal), or the "London Container Terminal" (previously the old "Northfleet Hope" terminal, down the branch on the other side of the docks).
Tilbury 2 also has an aggregate loading facility. A seemingly unlikely departure last week was a rake of loaded Freightliner HHAs on a Tilbury to Norwich Trowse service, via Stratford, Brimsdown and Ely. It returned empty via Ely again and used the Seven Sisters - South Tottenham chord to access the line to Barking and Tilbury. A similar working was pictured in May; the caption to this photo of empties from Trowse says the train arrived in the morning from Tilbury -
https://www.flickr.com/photos/132139568@N08/52087359905/
