GW43125
- Joined
- 8 Dec 2014
- Messages
- 2,174
Not going very well today as (assuming they're still on diagram) diagrams 2 and 5 have both failed.
Any updates on both of them? I was on the 13:30 Padd-Temple Meads earlier and there was some sort of issue with it that felt like only one powercar was providing traction but both sounded like they were powering when I bailed and watched it leave. I'd very much like to know so I can put only the powering one(s) in my movesNot going very well today as (assuming they're still on diagram) diagrams 2 and 5 have both failed.
Any updates on both of them? I was on the 13:30 Padd-Temple Meads earlier and there was some sort of issue with it that felt like only one powercar was providing traction but both sounded like they were powering when I bailed and watched it leave. I'd very much like to know so I can put only the powering one(s) in my movesTo add to that I'm now on the 17:03 Padd-PZ awaiting departure with no updates so far but from overhearing the driver it sounds like he's unable to release the brakes?
EDIT: Guard has just made an announcement and has confirmed a brake fault with the front powercar but has said that they think they've found the cure and that we should be moving very shortly.
Yeah, presumably went to Phillips Marsh so they could fix the problem.1A24 (diagram 2) was cancelled throughout and the stock for the next working has come from elsewhere, so I'd assume the set was taken to bed.
Good that the 17:03 was fixed though. All I heard was something to do with air (which tallies with your announcement about brakes).
Update: I've asked people in the know who say the 13:30 was One Engine only. Couldn't tell you which one however.
Yeah, that's definitely about right. Torturously slow accelerating away from stations too.I was on the 1330. Max speed 100mph, 85mph through Slough etc. Not sure what power car wasn’t working properly tbh
Should be a HST.Hi all, newbie here just signed up. Just wondering if anyone can tell me if the 10.01 Plymouth to Paddington on 27th April will be an HST or IET, thanks in advance.
I have booked 1st class tickets for one of the HST's on the 18th May but it says coach E which as far as I know is standard on a HST, if it is actually a HST will reservations be placed on the day in the correct coach or will there be no reservations?
Just seen the 18:03 Padd-PZ (diagram 2, which was caped at Bristol earlier) pass with an IET vice HST. Looks like it formed off a train from Taunton.
802113 was substituted to work the 1803
That's first class on a 5 car 800, if it is a HST then there'll be no reservations.
I've got a reservation with a first class advance in coach K on the 18.03 on 18th May, so they are / were issuing reservations.
Sun 21st April
1. 1A85 > 1C92
2. Spare
3. 1A14 > 1C86
4. 1A83 > 1C89
5. 1A90 > 1Z97
Looks as though at least the 1A83 bit of diagram 4 will be a Class 800 today as it is shown as being formed of 9 vehicles.
802113 on 1A83. No doubt due to covering the failed HST and overnighting at Penzance as mentioned up thread ^
I'm booked into coach K on the 18.15 on that last day - 1st Advance. I've not checked a seat plan yet.I have booked 1st class tickets for one of the HST's on the 18th May but it says coach E which as far as I know is standard on a HST, if it is actually a HST will reservations be placed on the day in the correct coach or will there be no reservations?
Two 9-car 802s at Penzance tonight (off 1503 and 1803)?
The 15.03 was 802 107
The 10.03 from Paddington and 15.52 return was also covered by a 9 car unit, 802 103.
How will this work for the 18:30 to Taunton as it is reservations only?It's just that if it's an IET reservation for a HST services, they won't put out the reservations, as the seating plans are wildly different
well the points are about how the diagrams relate to the stock and tangentially the seat reservations that then ensue. Just as, for example, the haulage that would then ensue...This thread is meant to be about HST diagrams.
If you have a question about your seat reservation, how about asking GWR direct?
IET reservations can and are placed out on HSTs. I think all services are reserved as if they are a 10-car 80x (bar services via Oxford), but the reservations can be placed on to an HST or 9-car 80x if that is stock on the day.It's just that if it's an IET reservation for a HST services, they won't put out the reservations, as the seating plans are wildly different
Nope the services booked for 9 cars, have reservations for 9 cars.
I don't see how IET reservations can be put out on HSTs as there are much less table seats on HSTs, and they have a buffet, so reservations in K wouldn't be put out
