Remaining GWR HST Diagrams
FGW_DID
23 Jun 2011
81E
Have the diagrams for the 4th May been released yet?
Sat 04/05:
1. 1Z76 > 1C12 > 1A20 > 1C89
2. 1Z83 > 1C22 > 2E57
3. 1A75 > 1W02 > 1P65 > 1C95
For all you Cotswolds HST fans:
1W02 = 10.22 Paddington - Hereford
1P65 = 15.13 Hereford - Paddington
Usual disclaimers apply!! :D
Jamesrob637
12 Aug 2016
Well yes that’s the plan, because isn’t that what GWR have explicitly announced?
Don't know as I don't follow GWR much since I've not lived in the West Country since the 2000s but 18 May sadly doesn't allow me time to get down for a final run on one along the wonderful Dawlish sea wall :(
RailWright
27 Feb 2019
Is there any visibility yet into the earlier diags on Sat 18th May?
I'm hoping to take my HST-loving son on final trips between CHP and BRI on the Sat (PAD is too far), if they're still running. These are listed in SO IW11:
1C16 1330 Paddington - Bristol TM
1A24 1600 Bristol TM - Paddington
Does anyone know whether those are confirmed for HSTs yet on Sat 18th, or of any other confirmed BRI services that day?
Thanks!
Their press release has been linked a few times in this thread, I think it’s pretty much a fixed date now. I’d copied it into post #1125 yesterday.
Melancholia
21 May 2016
Argleton
Sat 04/05:
Cheers. I'll be doing all of the last one
FGW_DID
23 Jun 2011
81E
Also, are the post 26/4 diagrams confirmed yet?
27/04 diagrams are back at post #1041
29/04 - 03/05 the diagrams are as posted in #1010
1. As per IW001
MO (29/04) starts at SPM with first working being 1A70 0605 Frome - Paddington
MX (30/04 - 03/05) starts at Laira with first working being 1A71 0451 Plymouth- Paddington
2. As per IW005
3. As per IW003
WesternLancer
12 Apr 2019
well you will have Castle HST sets along the sea wall I think, after May 18th, and also XC HST's along there too, at least.
HamworthyGoods
15 Jan 2019
Thanks!
There are some daytime Bristol services on the 18th May, I don’t have the details to hand but I’m sure one of the other guys on here might be able to help.
WesternLancer
12 Apr 2019
Yes, booked HST (IW3) and unless a set swap occurs it should be Set OC45 with 43162 & 43172.
Yes, this was all correct, thanks. I had a very enjoyable journey on the 13.03 from Paddington. Used the Pullman dining car. There would have been space to have walked up and dined without pre booking, even with a Std Class ticket, it was about 75% to 80% full.
At the risk of diverting onto a minor related matter ref the seat reservations - Of note was that seats reserved in Coach K (the dining car) were placed out in coach L (the FO) with the original tags that stated K (used the same seat numbers, as the FO was otherwise lightly loaded and I think the seat reservation computer allocated from seat K which of course is no good when in use as a dining car). This caused some minor confusion with passengers boarding but a member of staff was on had to help them find their non dining seat.
Apedlar12
13 Apr 2017
1. As per IW001
2. As per IW005
3. As per IW003
How about the diagrams for the 28th April?
Mintona
8 Jan 2006
South West
It would appear that the 1415 Paddington - Cardiff, 1656 Cardiff - Paddington and 1930 Paddington - Weston SM are an HST set today. I’m fairly sure that’s not booked anymore.
FGW_DID
23 Jun 2011
81E
No they certainly are not booked HST.
Today they are booked for HST! For whatever reason IW5 has a FO variation:
1A81 Penznce 07:41 Padton 13:15
1B42 Padton 14:15 CrdfCen 16:22
1L82 CrdfCen 16:56 Padton 19:07
1C28 Padton 19:30 Wsmare 21:53
gaillark
27 Jan 2013
Would it be possible to advise what sets are working today the 1233 Pad - Tau and 1930 Pad - WSM (Sorry might have posted in wrong forum which I apologise for in advance).
cactustwirly
10 Apr 2013
43098 & 43071 on the 1233 PAD - TAU
43170 & 43018 on the 0741 PNZ - PAD
Mintona
8 Jan 2006
South West
Ah there you go then. Thanks. I thought I’d already had my last go but looks like I’ll get another chance tonight.
FGW_DID
23 Jun 2011
81E
1C81 12:33 London Paddington to Taunton should be set OC54 with 43155 & 194
1C28 19:30 London Paddington to Weston-Super-Mare should be set OC53 with 43018 & 170
WesternLancer
12 Apr 2019
Yes, the HST diagrams will be HST! :rolleyes:
The 5 HST diagrams for 27/04 contain the following services:
1. 1A80 > 1C85
2. 1A83 > 1C87
3. 1A92 > 1C32
4. 1A75 > 1C77 > 1A94 > 1C33
5. 1A04 > 1C76 >1A87 >1C92
So it looks like tomorrow's (sat 27th) HST schedule is on routes to / from London to Plymouth-Penzance - apart from a couple of late evening runs back to Bristol? Assume this is still the case apart from any last minute on the day changes?
gaillark
27 Jan 2013
Unfortunately IW05 planned schedule is cut short tonight because of a fatality at Swindon this afternoon. Was going to get on 1B42 at Reading but was terminated here and sent back to Paddington. Informed it went as 1630 to Taunton.
50Fan91
7 Mar 2011
For whatever reason, you ask?! It'd be very boring if we sent out the same diagrams, every week! Unfortunately it hasn't quite gone to plan this evening, but the intention of putting a set on to SPM tonight is to balance the sets and work 1A04 tomorrow.
Thanks very much, wish there was a like button!
Will this be the last HST from Frome?
No, this won't be the last HST from Frome.
