Don't give them any ideas. CalMac is enough of a mess as it is.Meanwhile are the RMT going to black all ships as there have been many cases of Legionella on them, perhaps the RMT also play a part in Hotels and shopping Malls?
In which case the damage has potentially already been done. That said cleaning the toilet as soon as the legionella is discovered wouldn’t make much difference.If Legionella has been discovered, it's probably been standing undisturbed for a while and so it's very unlikely to have been flushed any time recently
The procedure in a hospital is to deal with it as soon as it’s discovered, not to put a do not use sign on the toilet in question and leave it for ages.It's really not. It's a proportionate response.
If they found it in the bog at a hospital, would they close the hospital and evacuate all the patients? No, of course not, they would lock the toilet pending cleaning.
I haven’t tried claiming to be an “expert”. I do however have a basic understanding of how legionella spreads, and therefore know that the best option is to deal with it as soon as it’s discovered.Are you commenting from a point of recognised expertise ?
Indeed, little to no risk of the toilet is out of use. It seems their quarrel is with the train being put into service whilst the traces are on board regardless of the minimal risk.
Locking a toilet out of use and then running the train in service with the legionella still present is not adequate.
By left for ages I meant after it was locked out of use. I perhaps should have phrased it slightly better.Directly from the article it says: “While it is extremely unlikely this would cause any harm to passengers or colleagues, the toilets affected were immediately locked out of use. Why have you assumed it was “left for ages”? Or they’re lying?
It doesn’t in all fairness state that once the train diagram had finished, it was then sent for a thorough clean. But personally, I would assume they would make requirements to do so at end of day, swapping diagrams if needed to be at the relevant depot with facilities.
It’s entirely inadequate. If someone were to catch Legionnaires as a result (which I accept is unlikely but it is still very much a possibility), it’ll be the the union’s employees that are ultimately handed the blame for it. I can see why they want to strike over it.It is entirely adequate. And certainly not worth threatening strike action about.
This is what does the RMT no favours. Threatening a strike over (literally) microscopic issue, without any recourse to talks, or even (apparently) understanding what has happened.
Anyone would have thought the RMT are gearing up for a major fight with the industry, and looking for candidates to be Archduke Ferdinand.
1), followed by 3) if 1) is either not done or the unit is allowed back off depot in service without the correct cleaning being done, and it isn’t an isolated incident.It’s a possibility that someone could catch gastroenteritis from bacteria in a toilet that has been left in a less than clean condition by a previous passenger. When that is discovered by a member of staff, what is your opinion of what should happen:
1) toilet locked out of use until it completes its diagram at a depot
2) removed from service immediately.
3) threaten strike action
How could that be?
No doubt it’ll be the staff that get blamed for not cleaning the toilets properly. Whether they should actually get the blame or not is a different matter, but unfortunately that’ll be what happens in most cases, management will do anything to escape the blame themselves.How could that be?
One only has to look at the RMT's web site to realise that it has other considerations than simply acting as a trade union:It is entirely adequate. And certainly not worth threatening strike action about.
Objects
4. The objects of the Union shall be:-
(b) to work for the supersession of the capitalist system by a socialistic order of society;
Unless there’s wilful ignorance / disregard of known rules and management can show the employee has been given all required training, knew what tasks had to be completed and no concerns had previously been raised about their performance.If (and it's a huge if, in a "won't happen" sense) it does happen, it will be whoever made the decision that is handed the blame for it.
Anyone got access to the holiday rota at RMT HQ?
Just wondering if most of the top brass are on holiday this week and a certain headcase is in charge?
I am a Microbiologist and have tested water for Legionella, including for train companies. Going by the article, GTR have done everything correctly: Have a programme in place to detect it and take the correct action to disinfect the affected pipe work.This week on RMT strike action bingo, they are threatening strike action on......Thameslink.
Of course this is a serious issue, and maybe I'm being naive, but it looks like Thameslink have taken all necessary steps to rectify the problem? Would RMT prefer the entire class 700 Thameslink fleet be taken out of service?
Rail workers threaten to strike over legionella toilet outbreak
RMT union calls for urgent meeting after ‘potentially lethal’ bacteria found in Thameslink trainswww.theguardian.com
What is there to blame? It isn't the staff or management's fault that legionella grows in standing water, indeed the fact that the legionella testing picked up the presence of bacteria shows that the processes for managing legionella are working, because the testing spotted it while it was at a low level and action could be taken. It's not feasible to drain and bleach every toilet tank every time its refilled, so there's always going to be periods where some water sits in a train tank for a period of time and is susceptible to buildup of bacteria.No doubt it’ll be the staff that get blamed for not cleaning the toilets properly. Whether they should actually get the blame or not is a different matter, but unfortunately that’ll be what happens in most cases, management will do anything to escape the blame themselves.
Exactly what you say. There will be set process in place for what to do when this happens. As long as they have followed the correct process then as far as I can tell it is a none story.I am a Microbiologist and have tested water for Legionella, including for train companies. Going by the article, GTR have done everything correctly: Have a programme in place to detect it and take the correct action to disinfect the affected pipe work.
No you can’t, but that doesn’t always stop employers from doing so. That said it does seem likes there’s key information missing here.Rubbish. You can’t blame people for not cleaning toilets if they are locked out of use and still in service.
If it is as serious as is being claimed where it is a risk to safety then yes I am.So let's get this right... you're apparently supporting the threat of strike action that would disrupt tens of thousands of people's lives and very likely cause a lot of harm to the railways, on the basis of a small alleged possibility that union members might get blamed for something (even though they haven't actually been blamed for it, and you haven't cited any evidence that they would be - it's just an allegation you've made) ????
Who are they striking on behalf of, i.e. who is being balloted? This doesn't seem clear. What is the problem for them specifically?
RMT declares dispute over Legionella outbreak on Thameslink trains.
RAIL UNION RMT said today that it has declared a dispute over a potentially lethal Legionella outbreak on Thameslink trains and is prepared to ballot for strike action if GTR and Siemens don't take urgent action to resolve the crisis.
To date 7 toilets, on 4 trains have had identified actionable traces of legionella. The fourth unit was discovered on August 9th and the company advise they are removing it from traffic where 'reasonably practicable' and if it remains in service all that will happen is that the toilets will be isolated. RMT has described this half hearted and inadequate approach as gambling with the health of passengers and staff alike.
RMT's executive had met and the General Secretary has instructed to:
• Write to the company advising that a dispute situation now exists between our organisations.
• Demand an urgent Joint Safety Committee meeting be arranged to discuss the legionella contamination, the company response and its responsibilities under procedure agreement 2 and the associated codes of practice and regulations.
• Demand full disclosure, including live updates of the unit numbers of any units found to contain Legionella.
• Distribute the report from our Health and Safety Department to our Health and Safety Reps.
RMT General Secretary Mick Lynch said;
"RMT has been raising concerns over Legionella on the Siemens Thameslink fleet for weeks now and the latest cavalier approach from the company is pitifully inadequate and is an outright gamble with passenger and staff health.
"We have now declared a dispute and be in no doubt if we don't get serious action we will ballot our members and do whatever is required to end this reckless approach to a potentially lethal situation on these increasingly busy trains."
