The question is is there one? Short of rebuilding it higher up so it's not on the flood plain...
Yes, providing a route for water to drain through.
Come on! If the track bed is on its viaduct above the water line and the ballast is draining properly then there wouldn't be any problem at all. The flood water is going under the bridge spans, don't forget. After all, we don't have speed restrictions on properly maintained track just because of heavy rain, do we?That would help, but wouldn't prevent other damage caused simply by waterlogging.
Was that because the water had been dammed up? or was the whole width of the valley under water - and would the water have been that deep if the railway and other embankments hadn't been impounding it?The trackbed was under water in places, wasn't it?
Section 7 of the Transport (Wales) Act 2006, as subsequently amended, appears to give the Welsh Assembly powers to procure a replacement bus service of an appropriate standard:Yes, this. I would support closure to be replaced with a Swiss style Postauto on a regular interval timetable. Not, as would happen, a single rotting old Dennis Dart being driven up and down in a reckless manner, which is what it would be (and is what the X1 was).
I guess a political obstacle might be that the on-going cost of the bus subsidy would come out of the WA's devolved budget, whereas the cost of rebuilding the railway would effectively be met by the UK government, via the Network Grant to Network Rail.7 Provision of public passenger transport services
(1) The Assembly may secure the provision of any public passenger transport services which it considers appropriate for the purpose of meeting any public transport requirements within Wales which would not in its view otherwise be met.
(2) In exercising its power under subsection (1) the Assembly must have regard to—
(a) a combination of economy, efficiency and effectiveness,(3) For the purpose of securing the provision of a service under subsection (1) the Assembly may enter into agreements providing for service subsidies.
(b) the Wales Transport Strategy, and
(c) the transport needs of members of the public who are elderly or disabled.
(4) But the Assembly may not enter into an agreement under subsection (3) unless the service in question would not be provided, or would not be provided to a particular standard, without a subsidy.
(4A) The reference in subsection (4) to the standard to which a service is provided includes—
(a) the frequency or timing of the service;
(b) the days, or times of day, when the service is provided;
(c) the vehicles used to provide the service.
Isn't Wales still subject to bus deregulation? That quote seems to give WG the same power as local authorities to procure services, but these are subject to challenge if they appear to be competing with a commercial service.Section 7 of the Transport (Wales) Act 2006, as subsequently amended, appears to give the Welsh Assembly powers to procure a replacement bus service of an appropriate standard:
We've had the promises that "there's a replacement bus and it's equivalent to the railway that's just been torn up" before.
Do people believe it.
Also, do people genuinely believe that the money to run their railway in the area, will go to local schools, social care etc, or will the saving just be lost in the next round of Council grant cuts.
I wonder ?
These powers are similar, but not identical, to those of English local authorities/PTAs. An amendment, specific to Wales, introduced by Section 69 the Local Transport Act 2008 (para. 4(A) in the extract I quoted above) specifically allows subsidies if a commercial service is not to the required standard, in respect of either the timetable or the vehicles used.Isn't Wales still subject to bus deregulation? That quote seems to give WG the same power as local authorities to procure services, but these are subject to challenge if they appear to be competing with a commercial service.
I don’t feel comments like that are particularly helpful to be honest and they’re becoming a bit of a cliche. The line is there, it’s important to the local economy so it’s essential it is repaired.
I suspect , back in the day , the existance of the power station at Trawsfynydd was a major strategic factor in the retention of the route as there were reasonable numbers of nuclear trains running. (which also kept the section south of Blaenau functioning - an extant route which has had a few issues of late in potential "restoration")
So , there are no realistic options for strategic or other freight traffics, - there were unrealised slate waste trials a good few years ago.
The future is therefore on the passenger service. I suspect the economics are very precarious , particularly having assessed a Rail Partnership Programme bid in the days of the SRA , where the case fell at the very first hurdle on potential patronage. The cost / benefit ratio was well below acceptance level , and this was with 15x rolling stock , not some Swiss Rhaetish Bahn panorama trains or "scenery viewer" trains.
The answer clearly has to be how much money "UK PLC" feels that the line can absorb. Operationally and retention / restoration of the infrastructure.
I need to be clear here - I’m not advocating closure in the current political / operating model of the railway.
What I am suggesting is that if the system changed, and we had a willingness by the politicians to guarantee a much better bus/ coach service - run as part of the rail franchise in the national network with all that entails - then it would unquestionably be better for the passenger (more frequent, more reliable, quicker service), and taxpayer (much lower cost). I can’t see any downside.
I also suggest that if/when Wales gets full autonomy on transport spending, it will work this out.
This line is probably the best example of this potential, although no doubt here are a handful of others.
It's a single line south of Llandudno Junction, with a passing loop at Llanrwst North. If you up the frequency, you either need to stop through trains to Llandudno Town, drop the clockface timetable, or spend money on infrastructure upgrades.Is there anything stopping a more frequent train service being operated today, or is it just stuck with an old timetable like the Whitby line ?
Anyway, this is the sort of "potential" I can happily do without.
This appears to provide TfW with a defence against a challenge from a "cowboy" commercial operator offering an inferior service.
Two hourly seems to me to be the very minimum level of service that one would need to make it useable.
If you want to get the weekend tripper market, it also needs a late evening Friday service (2100 ish) and a Sunday service. The UK does have a bad habit of throwing away markets for this kind of thing - Windermere is similar - it just finishes too early.
I think in places the river level had raised sufficiently to place some parts fully under water. That wasn't what caused the embankment washaways, but I suspect it did cause some of the equipment damage. Llanrwst station, for instance, is quite low down and has a number of times flooded to platform level. I'd imagine that may be what has caused Dolwyddelan platform to flop - it's only ply and it would have been waterlogged.
Yes indeed. It's amusing how so many on here are so quick to start drafting the closure notice, when no one has even bothered to run a decent service yet.
Near-clockface, then. It's about as near as they can make it with a single 150, and it's a lot closer than it was in the past (though I'm sure it's drifted again in the past decade).It doesn't have a clockface timetable, though it needs one. Unfortunately, there isn't *quite* enough time to run clockface two-hourly with one unit (turning at the Junction) - it was tried in the past but was not workable.
With the present passing loop you could run two-hourly clockface but would require a second unit and crew, but could do this without any infrastructure changes. There might be a sensible way to do this involving having it do an additional Llandudno-Jn shuttle in the (excessive) layover.
When I did a desktop/crayon job of looking at a two-unit two-hourly solution, I felt things would be very tight for exchanging single line tokens at the Junction: timings were slim anyway, and if the unit from the branch ran into P4 as now, it'd be a dash over the bridge with the token in the case of late running. If it ran into P3 to save the crew's legs, then it might introduce conflicts with coast services (and P1 would be occupied with the unit waiting to go down the branch in the meantime).
Er, like they have in Wales, do you mean? In Wales, the Traws Cymru bus network is centrally funded by the Welsh Assembly, and is an integrated network of interconnecting, long-distance services with modern, Traws Cymru-liveried coaches and buses. Replacing Conwy Valley services with a Traws Cymru service would mean it wouldn't be subject to the kind of problems associated with commercial and local authority supported services.We would have to ........ have a completely different attitude to funding buses to achieve something like this.
Is Traws Cymru only possible because most of its territory doesn't have enough passengers for anyone to make any money on a commercial serivce? The fact Express Motors have tried on this route suggests there could be another commercial challenge, especially if the train is no longer there.
As opposed to the luxury trains provided on the Conwy Valley? NOT! The last time I travelled on the Conwy Valley, the train was filthy and rode like a bucking bronco, with unpleasant wheel squeel at every tight bend.Traws Cymru is *not* the level of quality required. It has fancy buses, but it's still operated like a bus service, largely under lowest-cost tender by the precise disreputable small local operators who I don't want anywhere near the thing. It also has poor luggage and cycle provision, and no through ticketing with the railway. And there's no law against anyone trying to compete with it and thus trash it.
It looks glitzy, but in reality it is done on the cheap.
