Stations which could be joined together to make a better large station
Mikey C
11 Feb 2013
Two stations that have been very usefully connected are Hackney Central and Hackney Downs, which I'm sure is used as an interchange far more now than if it had remained an out of station connection.
Pdf
29 Jun 2022
I think there's a plan to merge Dalstons Juntion and Kingsland as part of Crossrail 2.
Basil Jet
23 Apr 2022
Aren't they planning 2 new stations on the Overground routes for OOC instead of pushing people up to Willesden Jn?
"Planning", yes, but there seems to be no money, and the new ideas about OOC being the HS2 terminus for many years don't seem to have made the Overground stations any more likely.
dastocks
3 Nov 2021
Hove
Edgware Road, linking the Bakerloo platforms to the sub-surface station with escalators and eliminating the lifts.
MarkyT
20 May 2012
Torbay
One is still on the cards as part of a wider West London orbital route.
The Old Oak Common Lane site has potential. It could have independent platforms for NLL, Dudding Hill (WLO), even WLL. It's not a crazy distance from the HS2/GWR/EL concourse, with fairly level pavement likely alongside the station access road following the EL Depot boundary fence. Maybe 200 - 300m. Perhaps they could put a canopy roof over it.
Silenos
13 Dec 2022
Norfolk
Catford and Catford Bridge stations are only about 100 metres apart and are both aligned in a north / south direction. So these stations I think could realistically linked by a single footbridge, perhaps with a common entrance from Catford Road. There is a block of flats in between the two stations which probably would complicate matters though.
The redevelopment a few years back did improve the connection a bit, but you share the access road onto the South Circular with any cars/lorries that are using it. Originally, the development plan from Lewisham council did propose a central ticket office building in between the two stations, to be shared by both, but that got dropped in later iterations. Widening the plaza outside Sainsbury’s over the Ravensbourne to provide easier pedestrian access from Catford Bridge side entrance towards Catford would be a possibility, but there’s not much you could do beyond that without major reconstruction.
Wolfie
17 Aug 2010
Do yo mean just Pancras Road, or as far as the junction? Any tunnel would need to be quite deep because of the larger vehicles that pass through the area, and you couldn't sink a tunnel anywhere near Euston Road, for obvious reasons :lol:
But yes; if you could pedestrianise the whole area between the two stations (or at least as far north as Battle Bridge Place, with pedestrian priority and only taxi access to/from the south) it would link them better above ground as well as below.
Wonderful for rail users. Crap for local bus services and residents. Expect opposition from the local MP, one Sir Keir Starmer.
Tester
5 Jul 2020
Watford
Surely the two St Budeaux stations are low hanging fruit?
No structural work required - merely re-signing.
Whilst it will never be a major interchange, there are useful connections to be made - I've done it!
adamedwards
4 Apr 2016
I suspect the footbridge might be further than the existing route!
Indeed it might, but my idea was in part keeping the station to station bridge inside the barrier line which increases the sense of safety as you are not walking out on to unfamiliar streets. Hackney Downs to Central is an excellent example of this.
Euston to St Pancras gives you a walking choice of a pavement next to a busy main road or a backstreet route which is fine in daytime, but as it brings you out at the side of Euston where there are sex shops, not a nice walk in the dark. I'd love to see a bridge from within the barrier line for EMR to Euston platform 1, again within the barrier line, so there is no walking outside or along any steets. It is of course too far and would never be a financial priority.
Magdalia
1 Jan 2022
The Fens
This would not work for taxis, which need separate drop off and pick up ranks at both stations.
At Kings Cross taxis come in from the north, drop off at the Western Concourse, then pick up near to the Great Northern Hotel.
At St Pancras Eurostar taxis come in from the south, drop off opposite the Great Northern Hotel, near to the Eurostar check-in, then drive round the north end to pick up the other side of the station near the side entrance to the British Library.
Both allow taxis to move from drop off to pick up without going out onto the Euston Road.
If Pancras Road was not available for taxis the congestion on Euston Road would be horrendous!
MarkyT
20 May 2012
Torbay
I'm not convinced there are overwhelming benefits containing a long walkway between combined station facilities behind a barrier line. A good well-signposted walkway between separate station entrances can be 99% as good and actually might feel more secure to customers with visibility by other locals in the area rather than a long winding passageway at a quiet time that might not be being monitored as closely as it should.
From a revenue POV, having to exit a gate line and enter another can more accurately trace individual journeys, preventing fraud and reducing the likelihood of annoying unresolved PAYG trips.
Whether 'railside' or 'streetside' a good interchange means high-quality surfaces, sufficient circulation space to prevent crowding, at least partially covered for shelter if possible, with excellent lighting, signposting and integration of information systems, no or very minimised crossing of heavily trafficked roads and the highest priority given to transferring rail passengers at any such crossings at grade.
Between Euston and St Pancras/Kings Cross, significant pedestrian improvements have been proposed by TfL along Phoenix Rd - Brill Place, connecting directly with a new east side entrance at Euston. This would have facilities constructed on and platform access via the redundant parcels deck.
Fawkes Cat
8 May 2017
This. Accepting that '99%' may be hyperbole, it seems to me that signing and so on will cost some thousands of pounds and get most of the benefits of a separate bridge/subway/whatever that would cost some hundreds of thousands of pounds. So the signing would be much better value for money.
Would it be too modest for this forum to suggest that it would be good if the railway tried well-signed routes to see what level of benefit followed - and then only if there remained a substantial unmet demand to move towards special footbridges?
MarkyT
20 May 2012
Torbay
I suppose there are some streetside inter-station links that are beyond hope in terms of making them feel hospitable and safe, where no amount of signage and lighting is going to convince people that secluded alleyway is a viable way to interchange or indeed stay alive and well, but I suspect these are in a fairly small minority in reality. Ebbsfleet-Northfleet is an example where adequate walking provision has been actively resisted by one of the station operators for years in fear of their customers' posh cars being damaged, because of course criminals intent on stealing cars or doing damage to them are known to absolutely never arrive in their own motor vehicle (or someone else's, previously nicked!). A covered direct walkway bridge could reduce the connecting distance significantly and remove all at grade traffic conflictions and dodgy alleyway elements. It would likely not be behind the gate-line, but would be a dramatic improvement if developers, who still haven't started any constructions in the immediate vicinity, would remove their objections about being 'overlooked' by the bridge that has been proposed in the past.
Fawkes Cat
8 May 2017
Liverpool Lime Street and Liverpool Central?
What - as well as the railway between them?
Of course, there isn't a convenient line back in the opposite direction (Central to Lime Street) but each time this one comes up the eventual consensus is that the walk is neither excessively long nor excessively alarming. Although this rather depends on whether you see the well used pubs on Great Charlotte Street as a risk to your security because they're noisy, or as a guarantee of your security because they're busy.
Silenos
13 Dec 2022
Norfolk
If we’re extending to walking routes, I seem to remember in another thread people complaining that interchange between Yeovil Junction and Yeovil Pen Mill was unsafe to walk (because of the heavy traffic and lack of pavements) so perhaps that’s a candidate for a good walking route.
Edit. As an aside - there must also be number of station pairs, particularly in metro areas, where it is possible to travel between them by rail but actually quicker to follow a walking route.
urbophile
26 Nov 2015
Not a risk to security, but an annoying nuisance. Not the best welcome to the city for any visitors who might be heading for Northern Line destinations. Yes there is a rail link, but usually more hassle than it's worth.
It's obviously not a priority, and highly unlikely to be judged worth the expense. But it is a shame that the link line (unlike the Wirral loop) was never linked directly to the city's main station. With better planning it surely could have been, and a large underground station at Lime Street would have done away with the need for one at Central.
As it is, the distance between them is probably not much more than from the main concourse at Manchester Piccadilly to platforms 13-14. But there is a travelator.
hux385
25 Apr 2023
Edinburgh
It's definitely not feasible with current infrastructure, but I would love it if there was a direct link between Newark Castle and Newark Northgate. It's such a faff when changing here and the walking route is through lots of small side streets :(
It would also give Nottingham better connections north if changing at Newark was easier!
D6130
12 Jan 2021
West Yorkshire/Tuscany
A few years back, most of the Nottingham-Lincoln trains used to reverse into and out of Newark Northgate for ECML connections. However the advent of the more frequent LNER Lincoln-KingsCross service has largely made that manoeuvre redundant and the time saved by not doing so is considered to be more important
A S Leib
9 Sep 2018
Old Oak Common and Willesden Junction - with new platforms on the WCML which would enable all Avanti and LNWR services to call at OOC.
As London Northwestern's stopped calling at Wembley Central (except I think for the current few weeks due to Watford DC / Bakerloo engineering works) I'm not sure how likely that is that all services passing through calling there is, although of course having the HS2 interchange at OOC doesn't make it directly comparable. I don't think there's enough demand around OOC for it to have all bar one trains per hour there calling as Stratford does, but a majority of services (eg all Hertfordshire and Milton Keynes terminators and one or two long-distance services) at least.
Having Southern services calling there would be useful as well, considering that the direct Overground service's ~34 minutes from Watford Junction; the quickest time I can find for changing at Wembley Central, including a six minute change, is 27 minutes.
hux385
25 Apr 2023
Edinburgh
How about combining Coatbridge Central and Coatbridge Sunnyside into "Coatbridge Interchange"? If frequencies and timings aligned nicely, it would allow Airdrie/ Motherwell/Cumbernauld/Livingston to be better connected.
mike57
13 Mar 2015
East coast of Yorkshire
although I recognise there are good reasons why the Pedestrian tunnel was chosen instead.
But most people that know it dont bother with the pedestrian tunnel, level access out the west side of Kings Cross, cross the road and straight into St Pancras or vica-versa. If you are loaded with luggage much easier. I notice that there tends to be a lot of luggage trolleys from the other station at both places. If in a hurry 5 minutes will do it.
Tetchytyke
12 Sep 2013
Isle of Man
Moving the station from Central to Lime Street would have been worse for access to the city centre, though. So a lot of cost for not a huge amount of benefit, given the arrangement utilised the existing underground station at Central.
It’ll depend what the post-HS2 WCML timetable looks like as much as anything. If everything is semi-fast at best out of London then it makes sense to stop everything, but otherwise it won’t make much sense. Realistically you wouldn’t use HS2 if you were heading to anywhere north of Tring, you’d use a legacy WCML service from Birmingham.
A0
19 Jan 2008
Liverpool Street and Moorgate.
Some years ago a work colleague of mine, who didn't know London very well, had to go to offices in Broadgate (next door to Liverpool Street on the old Broad Street site) and having arrived in Euston, walked over to Euston Square to pick up the Met / Circle to Liverpool Street. When he told me this, trying to be the helpful work colleague, I suggested next time he simply pick up the Northern Line at Euston and alight at Moorgate, which he duly did and then walked to the Met platforms to go one stop to Liverpoo Street... I happened to meet him at Broadgate and laughed when he told me what he'd done - when we left the office I showed him why I'd laughed, come out of Broadgate, turn right, walk 2 mins along Eldon Street and you can see Moorgate station......
FlyingPotato
23 Mar 2023
Always moving
The EL station for Liverpool Street is basically a moorgate EL at the same time
Mikey C
11 Feb 2013
In reality Kings Cross and St Pancras ARE integrated, with one low speed road running between them. 99% of people just cross the road, especially as there's a large public area between the stations next to the pedestrian crossing.
Silenos
13 Dec 2022
Norfolk
You do also need to watch out now for speeding cyclists coming down Kings Boulevard, as well as taxis and cars on Pancras Road. Not too bad when crossing STP->KGX but you can get a crick in your neck checking when you cross the other way!
And it’s not that low speed - I’ve seen one or two close shaves with unwary pedestrians.
If you were linking them you could probably incorporate Barbican too.
