43096
- Joined
- 23 Nov 2015
- Messages
- 16,712
If they just apply vinyls over the top of the existing paint then they are very dumb. The SWR Desiros need a repaint, and they ought to be painting them then applying whatever squiggly graphics the designers have come up with over the top as a vinyl.I thought that. Very challenging. I would guess that the displaced 450s from the Reading line won't all be used to strengthen other services initially, but there will be a sizeable float to enable a significant number of units to be refurbished at once. And of course as the livery appears to be all vinyl, this will be quicker than painting.
This is the curse of vinyl: it gives designers free reign to do whatever they want. Worse, it is not good for the bodyshell as water gets trapped behind the vinyl sheets and causes corrosion. At least with fresh paint under the vinyl, there is less chance of this happening, though if I was Angel I'd be either refusing all-over vinyls or charging a premium for doing so, knowing full well what will happen.
