Tesco to increase its use of rail freight
Jozhua
6 Jan 2019
I find it kind of crazy looking at the M1 and still seeing so many long distance trucks. You see big brands with the extra tall trailers for inter-warehouse distribution - I think a lot of that could also move to rail should the warehouses be sited correctly.
Oh dear. I can see a lot of the forum's "experts" in logistics being very unhappy to hear that after all the ink spilled in telling us that it is impossible for a modern supply chain to use rail to a greater extent than currently. :p
Indeed it seems so!
The Tesco supply chain is specifically designed to accommodate rail hauls - this is expansion of their existing modern supply chain.
I think there has to be an element of different supply chains if rail is to be used - rail might not be competitive on like for like journeys, but a supply chain designed with rail as an integral part seems like a competitive proposition. This seems like what Tesco has done. I would be interested to see what flows Tesco uses rail freight for!
Mikey C
11 Feb 2013
Indeed it seems so!
Chiller wagons to transport fruit and veg from Spain is an excellent use of rail. 15 weekly trains from Spain to Barking
WestRiding
21 Mar 2012
Got to say, its looking good for rail freight in general. This is just more excellent news.
Jozhua
6 Jan 2019
Happy to hear the Eurotunnel is in use more now for rail freight!
It makes a lot of sense, freight does not need to be accompanied in the same way on rail. In theory you could drive a loco from the French side, uncouple it and send it back (perhaps with another load), with the driver never having to leave the cab.
Even if you don't do that, you still vastly reduce the test+trace/border overhead.
With less Eurostar/Shuttle services running, it makes a lot of sense to utilise it even more now.
The channel tunnel is a great example of the kind of strategic infrastructure we need more of - it continues to pay dividends in terms of its value, even at a time of limited passenger movement between the countries.
plugwash
29 May 2015
It's just a great shame to me that they decided in the end not to build a connection to European loading gauge between HS1 and HS2.
Bristol
Why? Freight on HS2 would destroy capacity for the fast trains and the Classic WCML is W10/12 cleared. You get far, far more out of both lines by separating the fastest trains from everything else.
DynamicSpirit
12 Apr 2012
SE London
Sorry. But this is sooooooo obviously Tesco!
I don't think I would have made the connection if it didn't say 'Tesco' in small print. I suspect that, in the absence of any clues, in order to realise it's Tesco, you would have to be the sort of person who instinctively notices fonts - which probably not everyone does.
I don't think Tesco were trying to hide that it was them. Most likely, it's a case of, the people who design these logos forgetting that most of the public don't spend most of their working days thinking about logos and therefore connections that look obvious to logo designers will be completely missed by much of the general public. I seem to recall a recent discussion on railforums where the same issue came up in relation to the London NorthWestern Railway logo.
I would further hypothesize, that since it seems the word 'Tesco' was added to later versions, that was probably in response to various people within Tesco realising that - astonishingly - not everyone recognised who it was from the font. :lol:
WestRiding
21 Mar 2012
Not at 2am in the morning it wouldn't. I agree, the HS2 and HS1 should be utilised for freight 'out of hours' when not affected by engineering works. Though it'll never be a thing as it won't be standard railway signalling compatible.
takno
Tesco do loads of stuff like this. It's one of the most recognisable logos in the UK, and whether you spotted it or not, the vast majority of people it was aimed at will have got it just fine.
3 Mar 2020
Furness
This might sound daft, and feel free to shoot me down if it does. When you observe the train flying past on the WCML at line speed and the logo image passes through your eyes 20 to 30 + times, the lettering scrolls through and you may interpret the 'advert' and hence the lettering differently than if you were merely observing the single box from a photo in #20. Specifically look at the shape of the letter L.
I don't know if the Tesco logo designers did this deliberately?
DerekC
26 Oct 2015
Hampshire (nearly a Hog)
In a sensible world HS2 money would have gone into a strategic freight route like that proposed by Central Railway back in about 2003. It's been clear for a long time that the passenger-carrying value of rail is marginal outside major agglomerations and likely to be undermined by automotive developments. The energy efficiency "edge" in terms of freight is much larger. Covid has simply kicked the process along. Does anybody now have confidence that HS2 will really fill 18 trains per hour out of Euston?
Hadders
27 Apr 2011
HS2 is being built to accommodate 50 years worth of growth, it's not all about what happens on day 1.
Only in a world where investors don't want a return on their cash. It came up with the same old Woodhead stuff, Grand Central, 4 tracking the Chilterns and around the M25. It would have got just as much fierce resistance as HS2 does. It wanted diesel through the Channel Tunnel and was only expecting Class 6 60mph timings.
Have a read through some of their route assumptions. It was going up Miles Platting with an Ordsall flyover, single track Woodhead, exclusive use of the slow lines to Syston, "modest" track and station relocations. The on the inside of the M25 until Leatherhead. It also reckoned they could have 4 hour white periods for maintenance. You get more sensible stuff being proposed on here!
DynamicSpirit
12 Apr 2012
SE London
A train leaving Euston HS2 every 3 minutes....? (just checking). It seems crazy that these will be filled.
Crazy? Not when you factor in that HS2 will eventually absorb the vast majority of long-distance passengers who currently use any of Euston, St. Pancras or Kings Cross, plus a few Marylebone-Birmingham people. That's already not that far off 18 trains an hour. Add in that the faster journey times will attract more people who currently drive plus new journeys by people wouldn't have travelled at all on current journey times, and then factor in the long-term (50 years or so) growth that other people in this thread have pointed out... And after that, allow for the new interchange opportunities at Old Oak Common, which will attract yet more people. I actually wouldn't be surprised if 30 years or so after opening, people are complaining that we should've built it with more capacity.
(The only potential iffiness is that I'm assuming we do build phase 2. If we don't, that'll depress passenger numbers quite a bit).
Western Sunset
23 Dec 2014
Wimborne, Dorset
I'm sorry but "LESS CO2" does not make me instantly think Tesco.
It does me, though. The "L" is similar to a "T" and get rid of the "2"..... Plus font is identical to Tesco.
One I never got, from many years ago, was "Now for Britain itself". Of course, it was promoting "Elf" petrol - funny what one remembers...
Class 170101
1 Mar 2014
This, people can't quite grasp that fact.
And unfortunately the politicans neither.
And will allow more space for freight on the WCML.
More space on WCML South, I agree with you, but HS2 doesn't get you to Felixstowe, Southampton or the WCML north of Crewe to Scotland nor through Manchester Piccadilly so I fail to see where the freight capacity increase is coming from unless we believe that covid will see a need for fewer passenger trains on the rest of the network at all times of the day to allow for more freight trains.
Dr Hoo
10 Nov 2015
Hope Valley
This is getting rather off the Tesco-specific thread but there are various other schemes to deal with issues elsewhere.
Recently (or in progress or under development) we are seeing train lengthening at Southampton, Werrington (following Joint Line upgrade), East-West Rail, Ely, Ipswich Chord and so on. On the terminal front it is all about new sites contiguous with warehousing like iPort, East Midlands Gateway, Four Ashes, DIRFT extension, Mossend, etc.
(Yes, there will no doubt be a need for further schemes such as overtaking capability on the northern WCML too.)
Trainguy12345
9 Oct 2021
Dundee
Interesting article in The Guardian newspaper at:
https://www.theguardian.com/busines...es-stay-stocked-despite-supply-chain-problems
"Tesco is to increase its use of trains to distribute products by almost 40% as its boss credited investment in rail freight for helping to keep its shelves stocked during the lorry driver crisis.
Murphy said the supermarket aimed to deliver 90,000 40ft containers of goods a year to its warehouses via trains by the end of 2021, up from about 65,000 at present. The tactic comes amid a battle for lorry drivers that led Tesco to offer new sign-ups a £1,000 incentive this summer."
I mean I have seen quite some Tesco wagons lately
Class 170101
1 Mar 2014
Agreed, my point is without schemes away from HS2, including the ones you highlighted and others, it doesn't matter whether its Tesco, Asda, Sainsburys, Morrisions or anyone else you care to mention without those schemes HS2 by itself doesn't get you more Freight space except between Willesden and Basford Hall.
Whatever one thinks of it (and I think the rail haulage is excellent news), "LessCo2" is an excellent pun.
If be tempted to shop there myself if they sold the right beer.
Bristol
But then you end up in the circle of 'hs2 is pointless without other schemes which are pointless without hs2'.
At some point you have to break the circle to make progress. Build one and it makes the other more worthwhile.
Bertie the bus
15 Aug 2014
Perhaps people may recall that initially TESCO were reluctant to emblazon their containers with their name, relying instead on "Less CO2 Rail".
You are confusing some marketing people trying to be clever with wordplay, and possibly being a bit too clever, with deliberately trying to hide something or mislead.
To me Less Co2 immediately says Tesco but then I’m aware of the connection. I did once have a chat with a passing jogger who was asking which train I was waiting to photograph and we got onto the Tesco Express. He had some knowledge of the railway but wasn’t an enthusiast and he thought the Less Co2 train was to do with nuclear power, i.e. a greener type of energy, and hadn’t connected LessCo with Tesco.
xotGD
4 Feb 2017
It isn't pronounced 'Lessco'. So it doesn't sound like Tesco.
Bertie the bus
15 Aug 2014
It is wordplay as I said. There is obviously an intent to link LessCo with Tesco. It doesn't matter whether you say CO2 as C O two, the point of it was to be a direct link to Tesco.
