The last coal train?
richieb1971
28 Jan 2013
Immingham seems fairly well stocked of imported coal. Not full, but not shabby either. Picture taken in 2024, not sure when.
crosscity
5 Dec 2011
The Ratcliffe train (6M61) didn't run today, and looks like it's only scheduled for tomorrow (Wed) and Friday, so only three times this week.
crosscity
5 Dec 2011
Have all 30 booked trains run now?
The 30 coal trains were mentioned by a Flickr poster, before they started up at the end of April. The 30th train ran on Fri 14th June, and three more ran this week so we are at 33.
I was in touch with the poster who says he has no inside information but said his contact gave an end date of Fri 28Jun, so some may still run next week.
I see there is an STP schedule which has appeared for both Mon and Tue next week for 4E63 BARNETBY DOWN RECP GBRF to Immingham Humber International Terminal which has been a good indicator that 6M61/4E87 to/from Ratcliffe would run later in the day.
There is no STP schedule for Wed, Thu or Fri as yet, so perhaps Tue will be the last one (pure speculation on my part).
Freightmaster
7 Jul 2009
The final train is booked to run next Friday (June 28th) as an STP working from Doncaster, I'm told.
MARK
class 9
18 Nov 2010
Non of this is Ratcliffe coal, the top stocks are British Steel, where it says Oxbow is CPL brickette plant, next to that is the old NCB/ reception coal loading pads, I don't know where this coal is destined.
The Ratcliffe coal is loaded at the HIT, which is to the right of the photo.
Adrian Barr
2 Jul 2020
Doncaster
richieb1971: Immingham seems fairly well stocked of imported coal. Not full, but not shabby either. Picture taken in 2024, not sure when.
Hard to make out on the screenshot, but a 66 and a rake of HTAs are visible on Google maps at Immingham Bulk Terminal Coal Pad 2, above where it says "Hargreaves Mobile Plant Workshop," with Coal Pad 1 just below that. Meanwhile there are two iron ore trains visible in the adjacent Ore Terminal. The coal (or maybe coke) stockpile where it says "Maxi haulage" also appears to be connected by conveyor to the Coal loading pads in the Bulk Terminal.
As discussed in the freight news thread, coal trains to Scunthorpe Steelworks Coal Handling Plant are not currently running (apparently ran out of coal stocks to load, but should resume at some point). However, trains of coke have been running from Immingham Bulk Terminal to a new discharge point at the steelworks near Anchor Sidings, currently 2 or 3 trains a day.
Although the imminent end of the Ratcliffe trains spells the end for power station coal trains, as mentioned in previous posts there will still be some coal trains from the HIT supplying Hope cement works (seems to be running twice at week at the moment).
Killingworth
30 May 2018
Sheffield
The Hope cement works is due to close by 2042. That could mean a lot more coal trains.
furnessvale
14 Jul 2015
The planning permission expires in 2042. IF the UK has insufficient cement manufacturing capacity on the date I would hope (no pun intended) that the government of the day lean heavily on the Peak District National Park to extend that permission.
Killingworth
30 May 2018
Sheffield
The company already has a run down plan and has had a first consultation about uses for the sites. Although I'd agree, anything can happen over the intervening18 years.
Sun Chariot
16 Mar 2009
Today the 30th train ran to Ratcliffe since they started up again at the end of April. Does anyone know if any more are planned, or is this the end of them?
Answer is: 6M61 is on it's way to Ratcliffe today (Mon 17Jun) behind 66784.
I follow this thread with a tinge of regret, as I never got to photograph any workings into, or out from, Ratcliffe PS.
2017-19, my job took me from the south coast to Nottingham once per week. The A453 (new-ish road passing the PS) gave me occasional glimpses of trains on the loop.
3 May 2023
Too far from an HST...
You and me the same. I had coal trains to West Burton and Cottam on my doorstep but only got interested in MGR a week after West Burton stopped having MGR deliveries
joshTikeeti
20 Jun 2024
I am happy that Britain io
The first railway was not built to haul SRF! Until recently coal was still a large proportion of rail freight. I am glad that Britain is close to stopping using coal on a commercial scale but its very understandable that people will want to mark the end of an era.
Same here. I am really happy
DBS92042
13 Apr 2019
MARK
Do you know if there will also be a train on the 25th and/or 26th June please?
crosscity
5 Dec 2011
There are STP schedules associated with it for tomorrow (25th) but not the 26th.
MARK
I will keep my eyes peeled for the STP/VAR schedules associated with this as I can't see anything yet. The train must be loaded at Immingham beforehand, unless there's a loaded train already at Doncaster.
DBS92042
13 Apr 2019
Thank you. I assume then if there's no STP in then it's unlikely to run?
Adrian Barr
2 Jul 2020
Doncaster
There's only one set of wagons doing the Ratcliffe coal, appropriately featuring the lowest-numbered of the production HTA batch 310001 (the detailed caption to Adrian Nicholl's photo of 310001 linked below mentions a prototype 310000, which I think is stored at Worksop). https://www.flickr.com/photos/36034969@N08/44591271664/
I remember a while back GBRF were using a second set on the Ratcliffe coal, featuring IIA hoppers which have since gone back onto stone workings from Arcow (which must be one of the few or maybe only aggregate workings to still use full-length former coal hoppers, i.e. ~60 feet instead of the cut and shut ~50ft conversions such as the HYAs hoppers used from Peak Forest).
Back on topic, there's an ominous schedule for a 4L79 18:25 Barnetby - March Up Yard on Tuesday, which is a likely place for the wagons to be sent for storage when the service ends.
https://www.realtimetrains.co.uk/service/gb-nr:R17137/2024-06-25/detailed
It's quite possible that plans have changed since that schedule was created, so keep an eye out to see if it runs or not, or if STP schedules are created for another loaded run after tomorrow's 6M61.
Nicholas Lewis
9 Aug 2019
And as if by magic Ratcliffe has unit two online today at full power since 0930 probably because wind output is very low and they've probably paid for the coal so might as well use it.
mac
15 Dec 2010
You'd like to think that someone in power would notice that in the hottest week this year we are using coal because wind and solar isn't working
Corrected for you. Solar is working fine: over 8GW of fine today.
mac
15 Dec 2010
Corrected for you, tonight at 2225 solar was producing nothing and wind only 10.4% how will this work in winter without coal
Don't know why that was underlined
and coal was producing…. nothing.
for the whole of last winter (21 Dec to 21 March), coal generated 1.28% of our electricity. Solar 1.93%. Wind 35.8%.
It will ‘work’ just fine without coal.
mac
15 Dec 2010
But in winter when we need more power coal can be turned on how do we make the sun shine at night or the wind blow
3 May 2023
Not to get too off topic but isnt this the point of energy storage programs? And building more Nuclear plants etc to act as baseload? Coal was certainly king once but times change, and if we can switch to more efficient forms of generation we absolutely should.
Anyhow... I wonder if anymore HTAs are likely to be preserved, I'd be surprised...which is a shame as I'm quite fond of them
Looks like the final run is scheduled now.
crosscity
5 Dec 2011
MARK
Whoever you've got your information from has been spot on. Thanks for sharing it here, I found it really useful as it inspired me to go and get some photos.
With the wagons going potentially for storage is it likely the Doncaster run on Friday isn't happening now?
There must have been another rake at Barnetby. The train to March ran last night with the loco that worked yesterday's Ratcliffe.
Here's the flesh on the bones for the last coal train to Ratcliffe. The schedules are on RTT, Railcam etc.
I wonder if it's been done like this for the rail and other workers to mark and lament the end of power station coal trains.
Thu 27/6 STP 0R61 02:29 Doncaster Down Decoy-Barnetby Down Reception 03:39. Light engine.
Thu 27/6 STP 4E63 05:12 Barnetby Down Reception-Immingham HIT 05:46. Empty rake.
Thu 27/6 STP 6M61 08:00 Immingham HIT-Doncaster Down Decoy 10:15. Loaded coal.
Fri 28/6 STP 6M61 08:25 Doncaster Down Decoy-Ratcliffe Power Station 11:17. Loaded coal.
Fri 28/6 STP 4E87 14:57 Ratcliffe Power Station-Barnetby Down Reception 17:44. Empty rake.
Fri 28/6 STP 0D87 18:24 Barnetby Down Reception-Doncaster Down Decoy 20:19. Light engine.
Trainbike46
18 Sep 2021
belfast
exactly - the UK has a wide mix of electricity producing sources, including solar, wind, nuclear, hydro, and gas, as well as the option to import (and export) electricity, combined with an increasing range of energy storage options. With the new facilities coming online between last winter and next winter, coal isn't necessary anymore. And that's why this final coal power station is closing this year.
rick pike
6 Jan 2013
Grimsby
The working to March was only one HTA.
