TrainSim Screenshots [Large Images]
Malakhit
22 Sep 2022
Couple of images from over the last year or so. All images use my own reshade preset, AP Skies/Tracks, and a variety of different DLC addons.
RailWorks64 2022-07-05 22-19-44.pngRailWorks64 2022-07-13 21-23-28.jpgRailWorks64 2022-07-13 15-13-56.pngRailWorks64 2022-07-07 18-02-05.pngRailWorks64 2022-05-09 19-54-25.pngRailWorks64 2022-07-13 18-06-10.jpgRailWorks64 2022-05-25 22-42-22.png
Jacob Didcote
27 Mar 2019
Barry
Malakhit
22 Sep 2022
They are brilliant! Would be cool if presets could be downloaded. Makes the game look incredible!
Sure thing, I've attached my presets below. I typically play with the non-DoF one, and use the DoF ones for screenshots. I've set up Ctrl+PgUp/PgDn as hotkeys to switch between presets, so I typically just enter the external camera, hide the UI if it's visible, and pause the game, before setting up my shot.
  • presets.zip
_toommm_
8 Jul 2017
When you say you use shaders, do you mean in-game, or you apply the shaders post-screenshot? If so, what shader pack do you use in-game, as I'm assuming it's not Railworks Enhancer?
Malakhit
22 Sep 2022
In game. I'm using Reshade, which is what Railworks Enhancer is based on, but for free instead.
_toommm_
8 Jul 2017
I'll have to have a look at that. I've struggled getting the sky to look good on some routes with RWE Pro as you'll see from the below screenshot of mine. The clouds and sky looks horrific in the latter screenshots:
4M68 Southampton F.L.T. to Garston F.L.T. set in 2016, driving from just outside Stafford to the entry point of Garston F.L.T. on the WCML Midlands and Northwest:
View attachment 114724View attachment 114723View attachment 114722View attachment 114721View attachment 114720View attachment 114719
EWS 58038
7 Apr 2008
Almere (Greater Amsterdam)
Just to let you know... It works rather well.
Under SteamOS I can have 30fps with pretty high settings. Of course it remains TrainSim so when you reach Clapham Junction with 10 AI trains added the framerate drops to 20 ish, but it is still playable.
I encountered several issues that I was able to iron out over time and by re-installing the whole thing time and time again. But that is fine if you keep learning about the Stemdeck and get better results every time.
The Londo-Brighton route didn't give me any issues but London-Peterborough wouldn't load at all as the system couldn't handle the .ap file structure. This was solved by increasing the decks SwapFile from 1 to 16GB and Vram from 1 to 4GB. (tutorial
It now loads the route fine.
Portable train simming guys.... I have the sim running on a 256GB CF card on my 256GB Deck, but you can easily get away with the 64GB Steamdeck and getting the same results. A new SSD is much cheaper to install afterwards then getting the more expansive option from Valve.
_toommm_
8 Jul 2017
I’m guessing you’re limited to non-AP products as most of AP’s stuff says it won’t work with a controller?
Silver Cobra
4 Jun 2015
Bedfordshire
Here are a series of images of a run with LNER 801201 between Newcastle and York. This is part of a series of scenarios I'm making based on LNER's once-per-day service from Glasgow Central to Kings Cross (1E06).
Malakhit
22 Sep 2022
I picked up Railworks Enhancer Pro, adjusted my Reshade preset to fit with the new effects, and spent some time applying the AP Weather Pack skies to all of my routes. I'm pretty pleased with the results!
RailWorks64 2022-10-23 12-15-55.pngRailWorks64 2022-11-02 19-22-06.jpgRailWorks64 2022-11-04 22-12-23.pngRailWorks64 2022-11-05 17-19-38.jpgRailWorks64 2022-10-17 18-21-25.pngRailWorks64 2022-10-19 18-08-29.pngRailworks64 2022-10-21 12-21-41.jpg
_toommm_
8 Jul 2017
Malakhit
22 Sep 2022
Would you be able to share your RWEnhancer preset please? I love the way this looks!
Sure - it's pretty close to the default, but with a few minor tweaks.
  • Malakhit_RWE_Preset.zip
Jacob Didcote
27 Mar 2019
Barry
A few screenies of a recent drive. Only an AP scenario but at least it was something to do!
More South Wales thrash!
  • Screenshot_South Wales Coastal - Bristol to Swansea_51.50964--2.56117_10-08-58.jpg
  • Screenshot_South Wales Coastal - Bristol to Swansea_51.58439--2.77661_09-56-51.jpg
  • Screenshot_South Wales Coastal - Bristol to Swansea_51.58327--2.95175_09-50-07.jpg
  • Screenshot_South Wales Coastal - Bristol to Swansea_51.50123--3.12667_09-35-29.jpg
  • Screenshot_South Wales Coastal - Bristol to Swansea_51.47679--3.17315_09-31-58.jpg
  • Screenshot_South Wales Coastal - Bristol to Swansea_51.47551--3.18185_14-06-18.jpg
  • Screenshot_South Wales Coastal - Bristol to Swansea_51.47554--3.18153_14-05-55.jpg
  • Screenshot_South Wales Coastal - Bristol to Swansea_51.47639--3.17424_14-03-00.jpg
  • Screenshot_South Wales Coastal - Bristol to Swansea_51.47644--3.17406_14-02-49.jpg
  • Screenshot_South Wales Coastal - Bristol to Swansea_51.56960--3.00724_13-53-12.jpg
  • Screenshot_South Wales Coastal - Bristol to Swansea_51.58932--2.99928_13-50-47.jpg
  • Screenshot_South Wales Coastal - Bristol to Swansea_51.58308--2.79860_13-43-11.jpg
XAM2175
8 Jun 2016
Looks very nice!
Oh wow, these are in incredible. What are the US routes?
Malakhit
22 Sep 2022
From memory... the CSX one is B&O Mountain Subdivision: Cumberland - Grafton, and the Santa Fe/Burlington Northern one is the Montana Hi-Line route.
Jacob Didcote
27 Mar 2019
Barry
Some Tamper Drives!
XAM2175
8 Jun 2016
Cheers. Are those the included locomotives or aftermarket?
Malakhit
22 Sep 2022
Jacob Didcote
27 Mar 2019
Barry
Taking the 158 for a spin. ASYNCKeys is fun! The hour run from SWA-CDF took a whole 15-20 mins! :lol:
  • Screenshot_South Wales + Welsh Marches Line - Shrewsbury to Bristol + Swansea 2016_51.66173--3...jpg
  • Screenshot_South Wales + Welsh Marches Line - Shrewsbury to Bristol + Swansea 2016_51.63724--3...jpg
  • Screenshot_South Wales + Welsh Marches Line - Shrewsbury to Bristol + Swansea 2016_51.59147--3...jpg
  • Screenshot_South Wales + Welsh Marches Line - Shrewsbury to Bristol + Swansea 2016_51.52532--3...jpg
  • Screenshot_South Wales + Welsh Marches Line - Shrewsbury to Bristol + Swansea 2016_51.52548--3...jpg
  • Screenshot_South Wales + Welsh Marches Line - Shrewsbury to Bristol + Swansea 2016_51.52440--3...jpg
  • Screenshot_South Wales + Welsh Marches Line - Shrewsbury to Bristol + Swansea 2016_51.47685--3...jpg
  • Screenshot_South Wales + Welsh Marches Line - Shrewsbury to Bristol + Swansea 2016_51.47576--3...jpg
  • Screenshot_South Wales + Welsh Marches Line - Shrewsbury to Bristol + Swansea 2016_51.47582--3...jpg
  • Screenshot_South Wales + Welsh Marches Line - Shrewsbury to Bristol + Swansea 2016_51.50410--3...jpg
Jacob Didcote
27 Mar 2019
Barry
Little teaser of the route building!
Not perfect but gives the sense of depth and realism. The before and after of the triangle located next to Cardiff Canton. The triangle is from Radyr Branch Junction, Penarth South Curve Junction and Penarth Curve North Junction. A complete revamp of the unrealistic DTG take on the route.
  • Screenshot_SWC - Bristol to Swansea + Valley Lines_51.46724--3.18946_11-19-38.jpg
  • Screenshot_SWC - Bristol to Swansea + Valley Lines_51.46734--3.18965_11-13-49.jpg
  • Screenshot_SWC - Bristol to Swansea + Valley Lines_51.47444--3.19218_11-21-47.jpg
  • Screenshot_SWC - Bristol to Swansea + Valley Lines_51.47393--3.19278_11-21-31.jpg
  • Screenshot_SWC - Bristol to Swansea + Valley Lines_51.47407--3.19310_11-00-16.jpg
  • Screenshot_SWC - Bristol to Swansea + Valley Lines_51.47413--3.19269_11-00-03.jpg
  • Screenshot_South Wales Coastal - Bristol to Swansea_51.47431--3.19230_12-03-09.jpg
  • Screenshot_SWC - Bristol to Swansea + Valley Lines_51.47437--3.19225_11-00-26.jpg
10 Jan 2018
21 years ago, we had Microsoft Train Simulator (MSTS)...
...and now here we are with Train Simulator Classic (formally RailWorks)
and Train Sim World (shown here). 21 Years and Still Driving!
Jacob Didcote
27 Mar 2019
Barry
A few drives from the last couple days
