Halish Railway
I'm guessing that the risk of leaving un-energised wires is mitigated by the security measures in place by nature of the track being used as sidings.
Can confirm this is indeed the case. As with Colton Jn - Church Fenton, Siemens' SICAT SA range of cantilevers is being used, and has indeed been installed over the Down line, from a point beyond of all the crossings SW of Rose Lane (but before where the line crosses the A162 at Barkers Ash), up to the construction compound near Huddlestone Grange.Surprised no one has really updated this part of the TRU.
I have been reliably informed by a friend from York that there are now full OHLE hangers in place on the masts between Micklefield and Church Fenton(Provided... only on the down line). This also includes the drums, which hold the wires at the start of overlap sections (in his own words). I'm pretty sure this was already mentioned but he was quite excited to report to me (and a few friends) that "it's not series 1 or 2 but a design very similar to that in use on the ECML".
It’s used for the bay platform at Stevenage and some replacement cantilevers on the Hertford Loop line. There is also an older variant (I believe) of the SICAT design used between Glasgow and Paisley and on the Larkhall branch.Where else has SICAT been used, didn't think there were any electrification projects in Eastern region recently (except maybe the test track at Newton Aycliffe). Also what does the SA stand for?
Correct on all counts. There are a handful of SICAT SA cantilevers used at Carstairs as well, mixed in with Series 1 & Series 2 equipment.It’s used for the bay platform at Stevenage and some replacement cantilevers on the Hertford Loop line. There is also an older variant (I believe) of the SICAT design used between Glasgow and Paisley and on the Larkhall branch.
I’m not sure what SA stands for in this context but it is used to distinguish different variants of the SICAT design. I believe SX is the variant used on new schemes in Denmark for example.
Yes - SICAT cantilevers use aluminium as opposed to steel. Picture them as a lighter version of the ECML Mk3b cantilevers.For the uninitiated amongst us, is that maybe a lighter weight design that moves us away from the heavy steelwork versions that look (at least to me) rather ugly?
I believe it was chosen due to its similarity with the existing variants of the MK3 cantilever used on Network Rail’s East Coast and North East region. There are some benefits of the design such as increased distances between cantilevers, however, it does seem that these regions don’t expect to achieve maintenance economies of scale associated with a different design as there unfortunately might not be much electrification around there after TRU.For the uninitiated amongst us, is that maybe a lighter weight design that moves us away from the heavy steelwork versions that look (at least to me) rather ugly?
Also, the sidings are for a light maintenance facility for NorthernWhat are these for and going to be a while before anything electric uses it.
Thanks. That's good to hear!Yes - SICAT cantilevers use aluminium as opposed to steel. Picture them as a lighter version of the ECML Mk3b cantilevers.
Recall sitting behind the driver and going over the orbital motorway construction and thinking at the time the single bridge was going to be inadequate if ever there was an upturn in traffic. But we are where we are. At least they didn't use it as an excuse to close the line completely.Yes, the "main line" was LNWR to Stockport and beyond, including through trains from Euston. The LNWR Manchester-Leeds trains had to use L&Y metals between Stalybridge and Manchester Exchange.
By the 1970s the Stockport-Stalybridge shuttle was the only surviving remnant (running about hourly I think). I can just about remember sitting behind the driver and wondering at the amount of ironmongery above and below when passing through Guide Bridge.
but what will be the purpose of the new crossover at the Uppermill end of Saddleworth Viaduct?
IIRC the Diggle loop is being decommissioned as part of the upgrade, don't know if it's already beyond use but your description suggests it might be. In which case, an alternative facility will be needed while Standedge is blocked.
It's odd to spend so much four tracking a 7 mile stretch east of Huddersfield, but to remove a loop near midway the longest remaining double track part. Westbound still has Marsden, even if the Standedge to Huddersfield improvements are deferred.Diggle signal box is being closed. I’m presuming the loop and crossover going too. I don‘t know why. There must be more reason that it isn’t being recontrolled from elsewhere.
The developing plans for Slaithwaite & Marsden stations are based on three tracks, though I have always understood that there would only be two tracks (plus a third track to the Penistone line only) through Springwood and Gledholt Tunnels. There's a plan of the current proposals for Marsden station within the "Marsden Blueprint" consultation https://www.marsdenmechanics.co.uk/events/marsden-blueprint-come-and-have-your-say/, but it appears the only way to see the actual plan is to go to that site and scan a QR code.Or from Huddersfield to Marsden. 3 tracks all the way has been mentioned before. As a massive loop.
Possibly getting a bit off-topic, but did the Manchester to Marsden tunnel thing ever develop into anything more than a Grant Shapps press release so that, on the day he cancelled HS2 to Leeds, he could go on BBC Look North and say that high speed rail was still coming to Yorkshire?Also the imaginary Manchester to Marsden (HS ??) super tunnel. No point having a little loop if there's a 5 miles one right next to it.
https://indd.adobe.com/view/c0ae8136-c8ba-4d55-863b-0ddafadb4b3b is the page you eventually get to if you follow the series of complex actions and accessibility traps. Even then its a naff online document viewer with no way to view it as a normal web page or PDF. Why the NR consultation people hate usability so much is anybody's guess.The developing plans for Slaithwaite & Marsden stations are based on three tracks, though I have always understood that there would only be two tracks (plus a third track to the Penistone line only) through Springwood and Gledholt Tunnels. There's a plan of the current proposals for Marsden station within the "Marsden Blueprint" consultation https://www.marsdenmechanics.co.uk/events/marsden-blueprint-come-and-have-your-say/, but it appears the only way to see the actual plan is to go to that site and scan a QR code.
Probably to avoid being held to account when visualisations and promises made in consultations are not realised when the project is actually delivered.Why the NR consultation people hate usability so much is anybody's guess.
This isn't Network Rail's consultation, which hasn't happened yet. This is from consultants commissioned by Marsden Community Trust and Kirklees Council.Why the NR consultation people hate usability so much is anybody's guess.
That's not a Network Rail consultation. It's a local consultation for local people (though someone presumably signed it off), using the poster they've developed as an image on a webpage. Ick.https://indd.adobe.com/view/c0ae8136-c8ba-4d55-863b-0ddafadb4b3b is the page you eventually get to if you follow the series of complex actions and accessibility traps. Even then its a naff online document viewer with no way to view it as a normal web page or PDF. Why the NR consultation people hate usability so much is anybody's guess.
Good Marsden reference therelocal consultation for local people
Current P1 closing. Proposal is for three tracks and three platform faces so current P3 retained.More relevantly, I hadn't twigged that the former P3 would be brought back into use as the new P2, with the current P2 becoming P1 (and the current P1 closing, I suppose), so that you only need one accessible entry/exit constructing. But, their diagram also shows the existing P3 in place - I thought that that was going?
I'd hope it (and both platforms at Slaithwaite) would get replaced with a more substantial structure than the current "MFI Wardrobe" thing. Pretty much every wooden platform between Huddersfield and Leeds is being replaced one way or another.Good Marsden reference there
That would be all three platforms at Slaithwaite.I'd hope it (and both platforms at Slaithwaite) would get replaced with a more substantial structure than the current "MFI Wardrobe" thing.
Do you mean that's what's planned? Because SWT only has two platforms at present.That would be all three platforms at Slaithwaite.
