What I do not understand is how TPE continue to get away with cancelling large numbers of services on an already reduced timetable. Back in May 2018 when it all went badly wrong both Northern and TPE suffered a complete meltdown. Since then both operations have brought new rolling stock into service and negotiated Covid. Northern while not perfect are now performing to the point where you can plan a journey with the expectation that on most occasions you will arrive at your destination close to the advertised time, having travelled on a train which might be busy but you were probably able to get a seat. TPE seem to be still in same place as they were 4 years ago.
It is time that TPE were replaced, they have had the same opportunities as Northern to improve their operation but seem incapable of running even a reduced timetable. Reading the responses to this thread it is obvious that internal decisions such as working crews over part of a journey with multiple crew changes between for example Liverpool and Newcastle and loss of route knowledge are contributing to the situation, so why cannot the DfT who are accused of micromanaging, start demanding changes which result in a better service.
TPE are responsible for important regional services across the North and into Scotland. If the railways are to continue as a viable travel option then these services need to turn up according to the published timetable, with enough carriages that on most occasions you get a seat. TPE are not doing that, and seem to be blaming everyone but themselves, instead of saying "what do we need to do to run the best service with the resources at our disposal". This is not a one off issue caused by weather or infrastructure failure, its an ongoing daily situation.
