Trivia: Coast-to-coast services in the UK
Peter0124
20 Nov 2016
Without putting too much thought in and no doubt breaching the criteria.
Lancaster to Edinburgh. Runs generally South to North but from West to East coast. (The Lune is tidal under the railway bridge at Lancaster which is the last bridging point)
Glasgow to Plymouth? Glasgow probably doesn’t meet the criteria due to the Erskine bridge further down the Clyde but this would link West, East, West again at Bristol and South Coasts.
Dumfries to Newcastle. Again, Dumfries is inland and Newcastle not quite coastal but you certainly see the sea on the west coast on the journey then go what most would deem across the entire country.
In times past there was a Sunderland to Whitehaven.
Plymouth station is also pretty much directly south of Glasgow Central (A bearing of 0.6) as the crow flies so it makes the route an interesting one, like an inverse C shape.
GrimsbyPacer
13 Oct 2014
Grimsby
Firstly I think coasts are best defined from a land perspective (Durham Coast, Yorkshire Coast, Lincolnshire Coast etc), as it's very hard to define where the North Sea suddenly turns into the English Channel, or where that turns into the Atlantic Ocean (Celtic Sea is a modern creation rarely used so I'd discount that one).
Secondly, on bridging points, does this include places such as the Solway where bridges used to exist but no longer do?
14 Apr 2014
I'm pretty sure the Blackpool- York trains used to run to Scarborough which would make it coast to coast
Yes it was Scarborough to Blackpool North, it was originally a Transpennine express service but was usually a WYPTE liveried 158
NorthOxonian
Buses & Coaches
5 Jul 2018
Oxford/Newcastle
The difficulty with that first point is it leads to some odd services being classed as coast to coast. Newcastle to Whitby via Hartlepool would qualify - with all stations from Sunderland to Seaton Carew inclusive on the Durham coast and Whitby on the Yorkshire coast. However, it's very hard to come up with a more satisfactory definition!
Gloster
4 Sep 2020
Up the creek
The English Channel runs from its meeting with the North Sea at Leathercoat Point on St Margaret’s Bay in Kent (near Martin Mill) to Lands End. According to the International Hydrographic Organisation (via Wikipedia.)
NorthOxonian
Buses & Coaches
5 Jul 2018
Oxford/Newcastle
Mention of the English Channel made me realise a rather technical example of a coast to coast service. This is a UK thread, not a Great Britain thread - so you could argue that the Island Line counts. Ryde is on the north coast of the Isle of Wight, while Sandown and Shanklin are on the east coast. I would argue Bembridge fairly clearly separates the two coastlines (if the line still continued to Ventnor, that separation would be even more obvious).
And if we're defining coast very liberally, perhaps even the Portsmouth Direct Line would count? Hilsea is on the northern coast of Portsea Island (even if there's only a short stretch of water between that coast and Great Britain), while Portsmouth Harbour is on the south/west coast.
Alex365Dash
2 Jul 2019
Brighton
Whilst I agree it would count, services have to both start and terminate on the coast.
Unfortunately, the only service that starts or ends at Hilsea is 2P92 06:40 to London Waterloo, weekdays only. And of course, London is not on the coast.
Brighton - Bristol Parkway might be a shout, depending on whether Bristol Parkway counts as coast.
If former ones are of interest too, then the late 90s/early 00s Virgin Cross Country network provided a Portsmouth Harbour to Blackpool North on a mix of 2 car 158, 47 or HST haulage.
On the subject of former coast-to-coast services, depending on what we’re counting as seperate coasts, SWR prior to COVID ran a single Portsmouth - Poole peak service. (They also run Portsmouth - Southampton on the regular, but I think that’s taking the biscuit a bit.)
southern442
20 May 2013
There are daily Brighton to Bristol Temple Meads services (unless these now run to Parkway I am not sure), although, controversial as this may be, I don't consider Bristol to be on the coast. None of the city proper is anywhere near it, although parts of the county are on the coast. Just think about whether you would consider it to be a 'coastal town' or not, i would suggest not.
johnnychips
19 Nov 2011
See post number 1.
Good to see so many answers, some of which have surprised me.
Why does Liverpool count but not Bristol?
You can cross the Mersey downstream of Lime Street by the Kingsway Tunnel, just as you can cross the Avon by several bridges downstream of Temple Meads. Avonmouth and its station are in the City of Bristol.
As I said in the original post, I took the last bridging point as an arbitrary measure. I never considered tunnels.. But surely “Liverpool” extends beyond the tunnels to the north? There are no right and wrong answers.
kermit
2 May 2011
Quite a few suggestions involving Edinburgh - Waverley Station is at least a mile from the sea, probably a bit more......
daodao
6 Feb 2016
Dunham/Bowdon
LondonDerry to Belfast, but may be not for very much longer, and I'm not suggesting that the line is closed.
The exile
31 Mar 2010
Somerset
But the City of Edinburgh has several (definitely coastal) beaches. As far as Bristol is concerned, whether or not the city counts is moot, but Bristol Parkway is not in Bristol and there are miles of green fields between Stoke Gifford and the Severn Estuary / Bristol Channel.
bishdunster
9 Oct 2012
Dunster
Not sure if it still runs, but there used to be a through service from Bournemouth to Liverpool.
RPI
6 Dec 2010
St Ives to Penzance, though I think there's only one journey a day now direct.
There's a summer Saturday only Plymouth to Paignton at the moment too.
EbbwJunction1
25 Mar 2010
I'm sure that some of the Cardiff to Portsmouth Harbour and return services used to be extended to Brighton.
Dai Corner
20 Jul 2015
The Brighton's are currently diverted to Bristol Parkway due to the engineering works at Temple Meads.
The City and County of Bristol are one and the same, and even include a big chunk of sea. The built up area extends to Avonmouth which is downstream of the lowest crossing point of the Severn so would count as 'coast' for this thread.
NorthOxonian
Buses & Coaches
5 Jul 2018
Oxford/Newcastle
Mildly off topic, but how did that work? Did they call at Portsmouth and Southsea or Fratton twice? Were they set down only southbound and pick up only northbound?
Nonsense
20 Oct 2009
The only one I can think of connects Morecambe to Heysham.
Although was a Morecambe to Narrow in Furness service that ran a while ago.
a_c_skinner
21 Jun 2013
I have to say coast to coast to me means east coast to west coast and coast means somewhere that you can go for a paddle when you get there.
Dai Corner
20 Jul 2015
My knowledge of Irish geography is limited, but how about one or more of Belfast-Bangor/Larne/Portrush/[London]derry?
Factotum
10 Jun 2021
Stockport
There are five seas bounding Great Britain: The North Sea in the east; The Atlantic Ocean in the north and north-west; The Irish Sea in the east; The Celtic Sea in the south-west; and the English Channel in the south.
A coast to coast service is one which links tow of these seas
Does Scarborough to York return count?
Gloster
4 Sep 2020
Up the creek
As the north-western limit of the North Sea is Dunnet Head (International Hydrographic Organisation via Wikipedia again), Thurso-Wick is also a coast to coast journey. However, it is quite some years since trains made this journey alone.
