32.5 mins, assuming a 1.5 min stop at Oxford Rd. But yes, it's unlikely to be substantially slower.Compares to 33.5 mins from Piccadilly to Preston now with a clean path, calling Oxford Rd only.
That’s right. Piccadilly to the junction at Rostherne is ‘only’ 230km/h max; Were there a junction to head north, that would most likely be the same, and there is then only 5k at 320km/h before the 230 / 210 / 200 limits to the end of the line at Bamfurlong. Including the stop at the airport, Piccadilly to Bamfurlong would be in the region of 17 minutes. The current time from Bamfurlong to Preston is 15 minutes including the Wigan stop, so 32 minute Piccadilly to Preston. Compares to 33.5 mins from Piccadilly to Preston now with a clean path, calling Oxford Rd only.
230km/h would seem to be the ideal target ruling speed for NPR new construction, then, much like a German/Austrian ABS route.
I am being pedantic here - still would like to point out that 230 km/h in Austria are almost exclusively on new lines, not ABS (it might seem the other way because some major projects were sold as four-tracking, but it is really newly built.) Design speed mostly 250 BTW, albeit not used at the moment230km/h would seem to be the ideal target ruling speed for NPR new construction, then, much like a German/Austrian ABS route.
Hopefully above 200kmh at least in some stretches...I can’t see it being any higher than that. Possibly lower.
What about capacity between Rostherne and Manchester Picc? What about Rostherne to Fiddler's Ferry, which will already be fast at the Rostherne end? We already purchase 140mph stock for 125mph lines, and the 395s seem pretty fit for purpose over their short stretch on HS1.Well, the issue here is that the distance between stops is relatively small, and therefore the opportunity to reach speeds over 200kmh equally small. As mentioned on other threads, the benefit of, say, 225km/h over 200km/h is 2 seconds a km. A train leaving Piccadilly, next stop Huddersfield, will have at most 20km where it could be above 200km/h, allowing for acceleration and braking for the line speed where it rejoins the existing line at Marsden. So even if that stretch of new line has an alignment suitable for above 200km/h, the gain would be about 40 seconds. If there is an extra cost for buying a train that is cable of speeds above 200km/h, that might be seen as being profligate.
More Hitachi 80x based at a depot on the old Fiddler's Ferry Power Station site maybe?230km/h would seem to be the ideal target ruling speed for NPR new construction, then, much like a German/Austrian ABS route.
We might need an NPR train depot and route maintenance site too, if Crewe and Stone are considered too far.
Indeed. There was a northern junction in the plans very early on, but that was for trains from Manchester to access the depot, which was going to be at Golborne until moved to north of Crewe.
I did some very early work on the idea of Manchester to Scotland trains, and it seemed the journey time going nearly three quarters of the way round Manchester, even on high speed, wasn't much different from going via Bolton.
As far as I am ware there are no Northbound junctions to allow HS2/NPR services to run from Manchester or Liverpool to Glasgow or Edinburgh. Only Birmingham with the delta junction.
You may have been talking about that, but someone else raised the point about whether it could be used for Manchester trains as well.Erm, I (we) were talking about a hypothetical extension to HS2 from north to Scotland which would bring the London-Glasgow/Edinburgh journey times down to 2hrs 30 min. See post #50. I was not discussing any of the existing HS2/NPR schemes.
Posts by @Bald Rick and me suggested that there would be no significant time saving between Manchester and Preston, or a very small one if the HS infrastructure went all the way to Preston. That would be the same whether the line beyond was high speed or conventional.Yes that was me! But given we are talking about something that is only slightly beyond the crayon stage it doesn’t seem like rocket science to suggest that it could be used by Manchester/Liverpool trains with the addition of a relatively small junction or two somewhere!
Fair points, understood. Given the products on offer from manufacturers I'd be very surprised if a 230km/h product is any more expensive.Capacity won’t be an issue - it’s just over 28 km from the junction to the bufferstops at Piccadilly, at a linespeed of 220/230 with the airport roughly halfway. A train limited to 200km/h will lose perhaps 30 seconds compared to a train operating at linespeed. Essentially it will use the same path.
At the Rostherne end it will be 230km/h - that is the top speed of the entire Manchester branch.
Yes, we already have bought 140mph stock for 125mph lines, albeit that was based on the expectation of sustained running at the higher speeds on those routes at some point. That wouldn’t be the case on NPR routes. I agree that it would seem sensible to do so here, but only if the cost of that extra speed (that would be used relatively little) is a minor increment.
Although capacity would be released for local services on the Styal line, the Bolton line and through the Castlefield corridor. And there would be a substantial time saving between Manchester Airport and Preston....Posts by @Bald Rick and me suggested that there would be no significant time saving between Manchester and Preston, or a very small one if the HS infrastructure went all the way to Preston. That would be the same whether the line beyond was high speed or conventional.
Concerning bridge or tunnel, see the separate document
This can be summarised as it is, just about, technically feasible to build a fixed link (at about £335bn for a bridge and about £209bn for a rail-only tunnel). The report does not address economic viability. It concludes:
Well, it's a long time yet before NPR trains are needed, and TPE's 140mph-capable Nova 1 stock is practically new.More Hitachi 80x based at a depot on the old Fiddler's Ferry Power Station site maybe?
We'll soon know what stock HS2 will get, which might be a pointer (and dictate depot arrangements).
Either way, I'm sure any new trains required will go out to tender.
