Wellglade Group
38291018
31 Oct 2024
England
Then I remembered Versa 820 was parked in the same spot in A garage last time I was there.
Assume that's just helping langley mill with maintenance however apparently 813 and 816 versas are sat at back of langley mill according to bustimes because of euro 6 so im assuming langley mill is retrofitting euro 6 parts to the engines for sheffield unless any other wellglade subsidy is taking them
Trainman40083
29 Jan 2024
Derby
Probably to replace older Solos at Trentbarton.
38291018
31 Oct 2024
England
That's interesting as along with 8 volvos which will become spare from keyworth and current x38 making 10 buses currently with the 2 versas which I assume the other will join making 13, they can replace (bus per bus) every solo/solo sr (except 2 braded rushcliffe villager, 2 branded harlequin, 2 new red livery solos) which I'm sure TM (which are complient if any) and notts derby would hoover up
Trainman40083
29 Jan 2024
Derby
Best get rid of Solos 491/492, although they have been working hard on the Sixes this week. I heard Optare Versa 823 has gone for painting into Notts and Derby livery. Maybe they want more.
Teapot42
12 Jan 2022
I'm pretty sure Euro 6 retrofits are no longer permitted. There have been a few studies showing they don't work and in some cases can make things worse.
YX73OUB
24 Jul 2024
East Midlands
Alfreton has so many different operators. Stagecoach, Notts and Derby, Hulleys too. But for the most part, you could say the same about Class Cross. The roundabout at Little Eaton is bad enough in a car, even more so if the vehicle in front of you moves slower than a donkey. You can't even assume traffic will stop on a red light
Agreed but the demand must be there for comet to go in Alfreton Bus Station. We definitely have customers jump on/off the nines and change to comet in Alfreton.
That made me think as well.
How similar is the Volvo B8RLE to the B7RLE?
youd be surprised how different the two Volvo models are.
Regarding the nines there was/is a project going on looking at the service as a whole but things have been really difficult over the last 24 months with prolonged roadworks.
cnjb8
26 Feb 2019
All the London Solo's that joined TM's fleet were retrofitted to Euro 6 when with CT Plus, so retrofits should be allowed. Besides most of First's and Stagecoach's compliant fleet will also be Euro 6 retrofitted
psmith2023
23 Jul 2024
Mansfield
Suprized Trent Barton has tryed a comet style route from Mansfield to derby run it same way as the 9 to alfreton then comet way to derby as can it done with 3 bus like the comet
YX73OUB
24 Jul 2024
East Midlands
Like a rapid 9 you mean? It's all well and good until the A38 turns into a car park or something happens on the M1. It's a risky move in uncertain times.
Interesting. Major changes on the way?
Not sure where the project is at the minute but there needs to be time to let things settle following prolonged and several sets of roadworks on the routes causing mayhem over the last two years.
psmith2023
23 Jul 2024
Mansfield
Do the nine what's via south normanton the same to alfreton then the comet route after alfreton to derby I mean pvr can be saved
Teapot42
12 Jan 2022
My understanding is that retrofits after September last year are no longer accredited. So ones already done (whether effective or not) still qualify as Euro VI, but no new ones can be done in a way they'll qualify for CAZs.
YX73OUB
24 Jul 2024
East Midlands
It's been dried before & didn't work.
As the nines has a very heavy demand between Alfreton & Ripley and then towards Kilburn & in the village it would need to stand alone and need a lot of resource to make it viable. Especially in the current climate.
Cesarcollie
5 Jun 2016
Those already does remain compliant only if they transmit live data on emission levels in a specified format.
Trainman40083
29 Jan 2024
Derby
Effectively lots of passengers travelling short distances, between local places, rather than over longer distance. I can't imagine many people wanting to go Derby to Mansfield.
YX73OUB
24 Jul 2024
East Midlands
Pretty much, but more than you might think. If not Mansfield then definitely a lot between Mansfield and Sutton for Derby for particular industrial estates especially.
Mugby
25 Nov 2012
Derby
Exactly. Most people from Mansfield or Sutton want to go to the big city i.e. Nottingham. Nobody would want to go to Derby (unless it was for work) it has nothing to offer.
The Nines are very much services of two halves, Derby to Alfreton and Alfreton to Mansfield which is what they were in pre-deregulation days, in fact probably the only reason they were joined together was for operational expediency rather than public demand. Buses from either direction usually empty out and reload at Alfreton, a few workers from the Mansfield end travel to Somercotes/Leabrooks/Ripley but not a large number.
YX73OUB
24 Jul 2024
East Midlands
Although there are several commuters that work at East Midlands designer outlet & commute from Ripley & Kilburn respectively.
Davidsb3
16 Apr 2019
Derby, UK
We get some some from Chesterfield, claycross and shirland (who change at alfreton) As they want to get to the outlet after they figure out the 55 dosent go there anymore.
The way the Comet is the main traffic is Alfreton - Chesterfield anything south of Alfreton after swanwick it goes a bit more quiet due to the nines higher freqency.
Np13
22 Dec 2019
712 has returned to service today, albeit with the older style vinyls as it did before, not the newer style ones as seen on the likes of 740 etc
ChrisC
7 Oct 2018
Nottinghamshire
A bit off topic but I do wonder how the Stagecoach X1, which was introduced just before the Covid lockdowns would now be doing if it hadn‘t been so quickly withdrawn. For those who have forgotten it ran Chesterfield-Clay Cross-Alfreton-East Midlands Designer Outlet-Nottingham. It ran down the M1 from the Designer Outlet, was slightly quicker than the Pronto between Chesterfield and Nottingham, provided a direct link to the Designer Outlet from both Chesterfield and Nottingham. It was also quicker than Trent Barton from Alfreton to Nottingham and it provided a direct bus from the South Normanton area.
tram21
29 Dec 2022
I personally think it would be doing great, long distance buses seem to be doing well after COVID, especially in the leisure market which this would generally cater for.
Trainman40083
29 Jan 2024
Derby
I don't recall it carrying that many fare paying passengers when it ran.
Maybe most make the journey by train, in less time.
Teapot42
12 Jan 2022
Is there that much time saving? Yes the train is 37-38 minutes, but neither station is that close to the centre.
Plus, at £18 for an off-peak day return, the train is considerably more expensive.
ChrisC
7 Oct 2018
Nottinghamshire
It wasn’t really given much of a chance to build up usage. I think it only began in October 2019 and was withdrawn early during Covid lockdown soon after March 2020. Whilst there probably would never be a huge number of passengers doing the whole route it provided lots of direct journey opportunities which are not otherwise available.
