Why is Southern's Redhill to Tonbridge service crewed by Southeastern?
paul1609
28 Jan 2006
Wittersham Kent
There was a thread here a while ago about Tonbridge crews working dmus from Ashford to Hastings in the 1980s, with photos
TRIVIA: Southern Region services worked by DMMUs | RailUK Forums (railforums.co.uk)
It was a diversion route when the direct Hastings line through Battle was not available, either through closures or because the stock was out of gauge for the narrow tunnels.
The Ashford to Hastings line was of course the original line to Charing Cross. Prior to electrification all the relief services seaside specials and services from other regions generally were routed via Ashford as there was more capacity on that line to run non stop trains and as you have said it avoided the gauge restrictions. Until the 1960s the Marshlink line also still had an up "businessmens" peak service through to Canon Street.
Hastings is one of those stations where up/ down changes at the station. The platform repeaters are OFF WSQ or OFF ORE to avoid confusion
Sm5
21 Oct 2016
Today was
5Y77/5Y78/5Y79/5Y80
which is the most usual combination.
One wonders why the crew cannot just drive one of the Southern regular service units, or if that's not possible either, just ride along in the cab.
The former would be an option, but would necessitate intertwining the two company's operations more than they (or the DfT) would like.
The latter was the solution that was adopted across many depots and little used routes pre-Covid, but has been kyboshed by the response to Covid.
Sm5
21 Oct 2016
Please delete ^
New message:
Thanks, that explains things.
None of these headcodes bring up anything in RTT... It is half 10 on Tuesday in the UK right now, right?
best way to find then in RTT is to look up “SE“ services at “Redhill”, “all day”.
Here was Tuesdays…
and wednesdays..
and todays..
then plan from there.
They use the slow lines up to East Croydon (Via Merstham, South Coulsdon, Purley etc).
You can rely on it going, They do run most days.
You can usually bag a northbound stone working or two between 12-1pm as well..
