Wigan-Bolton electrification. Construction updates only please
LDECRexile
30 Jan 2014
Southport, UK
Wrinkley and I did a railtour Wigan Wallgate to Stalybridge via Bolton and back today.
Contrary to the report in RAIL magazine Crow Nest to Lostock Bridge 7 was not replaced over the weekend as planned, perhaps due to the storms. A wholly new, very stout looking concrete support for the bridge-to-be has been built, replacing the slim metal one as posted here recently. Orangemen were working and lots of plant in evidence.
Buckingham have set up a workbase a short distance on the Wigan side of Hindley Station.
Some evidence of vegetation clearance here and there.
At least two Class 769s working. Wrinkley's unaudited view is that they are appearing more frequently now.
Foggycorner
16 Nov 2016
bolton
On a trip to Wigan from Bolton this morning I noted that the bridge deck of the new bridge 7 at chew moor had been put in over the weekend I do hope that the local nimbys like the new bridge
The Large crane I saw being put into place on saturday had gone this morning
wrinkley
6 Feb 2015
I arrived at bridge 7 at 11am on Sunday to find that all the bridge beams were in place, the work had started as soon as the line closed on Saturday night. I was told that Murphys will be on site until May, although Bolton MBC say that the footpath will be open by end March. Buckinghams are doing all the electrification work and currently drilling for soil samples where the masts will be. Couldn't find out which bridge is to be worked on next.
Nicholas Lewis
9 Aug 2019
Roger Fords Informed sources has this snippet for April issue
According to the press release announcing the scheme, ‘The upgrade project will provide 450 new overhead line equipment stanchions, and modifications to 17 bridges and two-level crossings’.
But, as we learned at the PWI Seminar, significant strides have been made in reducing electrical clearances at structures. According to Informed Sources, application of this engineering activity has resulted in a substantial reduction in the cost of electrification-related work in the Wigan-Bolton scheme. Without the reported 150% overhead on the actual project costs, the physical work on site, including those ‘modifications to 17 bridges’, came to around £30million.
Application of the new approaches to clearances, means that only one bridge will now require reconstruction for electrical clearance. Two more will need to be reconstructed because of condition. At a stroke, this has reduced the cost to under £15million, or around the £750,000/stkm, which the RIA study thought should be achievable on simple schemes
This is good to hear and lets hope NR are recycling this knowledge back into future estimates so they can demonstrate real cost savings to entice the DofT to approve more schemes.
John R
1 Jul 2013
Great news, although given it’s 7 years since the bridge east of Cardiff Central was done, it seems to take an awfully long time for these things to move from a one-off to making a difference. (I’m making the bold assumption that the technique used there is at least part of the solution now proposed to be adopted.)
WAO
10 Mar 2019
If this works out, NR will have shown that an actual project required to be costed at 2.5 times its given estimate can come in at 0.5 (50%) times that estimate.
Only a successful out-turn will prove this finally.
WAO
wrinkley
6 Feb 2015
I have been told by contractors that one of the other bridges to be rebuilt is the one leading to Westhoughton golf course. This bridge currently has an approximately one metre high wooden palisade fence as a parapet above the line. I was also told that the bridge at Crow Nest is to be raised.
GRALISTAIR
11 Apr 2012
Dalton GA USA & Preston Lancs
Crow Nest is surely the more difficult one of the two iirc? Here is the golf club bridge with LDECRExile making a cameo appearance. And here is our Graham with a quick reminder WHGC 2.jpgWHGC 1.jpgWHGC 3.jpgWHGC 4.jpgWHGC 5.jpg
And here is Crow Nest
wrinkley
6 Feb 2015
It's only a personal opinion, but the bridge at Chulsey Gate Lane in Chew Moor needs some attention, it's a wide bridge as it also covered the entrance to the old sidings at Lostock. The bridge is in three sections supported by two sets of steel columns similar to the one supporting the old bridge 7. The suface of the roadway over the bridge has several 6 inch deep potholes in it.
Gricer99
21 Jun 2020
Hindley
I understand that the two bridges in Hindley will need to be replaces too. It will be a shame to lose the locally iconic ”Iron Bridge”.
GRALISTAIR
11 Apr 2012
I have now had time to read the latest Modern railways Informed Sources. There is a whole article on this electrification scheme. A really good read which I thoroughly recommend. It really does have some very promising news regarding costs.
The exile
31 Mar 2010
Somerset
Presumably the cost of rebuilding bridges “because of condition” isn’t/ needn’t be included in electrification cost estimates as it would have to be done anyway…
Nottingham59
10 Dec 2019
Roger Fords Informed sources has this snippet for April issue ....
Would it be a fair summary to say that after introducing new standards for OHLE clearances, which cost several £billions in GWEP, MML etc. etc., they have now gone back to more or less the original clearances which had been found to be adequate for decades previously?
(Though obviously, with a bit of insulating paint on the underside of bridges, and maybe surge arrestors where lightning-induced over-voltages could be a problem.)
GRALISTAIR
11 Apr 2012
Well I am not sure - but on my read it basically says:
Dft/treasury - prove you have your costs under control with this scheme and MML and TPU with what has been approved. If you get it right then we may approve more. Long story short PROVE IT.
superkev
1 Mar 2015
west yorkshire
As Roger Ford pointed out in this month Modern railways this is a catch 22 situation in that to reduce costs you need to authorise long term work but drip feeding money limits supplier confidence in investment and increases costs.
K
John R
1 Jul 2013
K
Though the bridge changes being discussed and the more realistic foundation depths that also happened following the GWML debacle are improvements that are not related to the benefits of a continuity of work.
Class 170101
1 Mar 2014
Would be interested to know what the fallback plan is if its not possible, especially as I doubt the politicans have realistic ambitions / expectations.
Greybeard33
18 Feb 2012
Greater Manchester
507020
23 May 2021
Southport
How is Lostock Junction on the Bolton to Manchester corridor? It’s north of Bolton!
It’s not the worst mistake given it is the first junction on the continuation of that corridor 3 miles dead west (not north) of Bolton station and it is still in what you would otherwise call Bolton though.
WAO
10 Mar 2019
NR's NW route director would be well advised to issue statements in good, objective English without tabloid newspaper hyperbole and public relations overstatement.
Electrifying 6.5 miles of railway is not a "major way" of achieving anything, nor can projects be "targeted to complete", suggesting that they complete themselves rather than are completed by the skill and artifice of the design and construction groups.
Clear (and accurate) English is a result of clear thinking, necessary for electrification schemes.
WAO
themiller
4 Dec 2011
Cumbria, UK
Although it does say that they are continuing to look at "innovative solutions" to reduce cost.
Build it cheap, build it twice. The costs of projects on the railways are inflated by the cost of work to bring the infrastructure to where it should have been in the first place. Reducing cost normally means stripping out scope which will need to be done in the future. For example, WCML electrification didn’t allow for increased gauge clearance which is needed for what is now needed. I know it’s because of the successive holders of the purse strings but frustrating nevertheless!
Howardh
17 May 2011
There's a report in the local paper about a campaign to install platforms on the Wigan branch at Lostock. Would make sense to do that at the same time as electrification, but I don't suppose it's in the plans?
