Wigan-Bolton electrification. Construction updates only please
thealexweb
5 Jan 2014
Much point wiring it all the way if there not going to changeover at Ince
I think it's because the Southport trains don't generally call at Ince at present. Would a whole new recast be needed to add the extra stop?
And about 5% of trains terminate at North Western currently so they will be pan up the whole way.
Starmill
18 May 2012
Bolton
As @pokemonsuper9 says the call at Ince has been inserted to cater for this. If you take a look at the journey planner or open data site of your choice for a random day after 18 May you'll see the calls.
A Wigan based Northern conductor I asked said he’d been told they power changeover is being moved to Hindley soon.
It's possible this could happen for services prior to 19 May which as noted below almost all aren't booked to stop at Ince.
pokemonsuper9
20 Dec 2022
Greater Manchester
Hindley will (presumably) need Pan up and pan down signs for to/from the Atherton line as well (Salford Crescent has similar ones), so having them the other way around will presumably work fine.
I believe all 769 changovers are done at changover signs at the moment, not sure if they're 'required' as such.
Starmill
18 May 2012
Bolton
I find it rather odd how they’ve increased the service at Ince from 1 tph to 3 considering it’s not much of a well used station?
I guess they may as well call for passengers if they've no choice but to stop to change mode anyway.
GRALISTAIR
11 Apr 2012
Dalton GA USA & Preston Lancs
Gone a bit quiet.
Any word of test trains?
Absolutely none, but it sounds like they aren't going to change the timetable to December 2026.
Suppose you are a politician. Would you authorise more electrification if the infrastructure did not get used? I understand there is a system but when money is spent the assets should get used as soon as is practical in my opinion.
pokemonsuper9
20 Dec 2022
Greater Manchester
So, what does this mean for this newly electrified line?
The 769s will use it once avaliable, as mentioned before, all Southport services will stop at Ince from the timetable change, this means that once tested and approved, 769s will be able to operate in Electric from/to Ince (a saving of ~8.6 miles each way).
(Data taken from Realtime trains, in Miles)
Oxford Road - 10.56 -> 19.375 of 37.8375 (from 28% to 51%)
Stalybridge - 18.4 -> 27.075 of 45.43 (from 41% to 60%)
Quite a significant increase.
Starmill
18 May 2012
Bolton
It will be used by 769s.
geoffk
4 Aug 2010
OK. I read somewhere that Northern didn't want to pay for the use of Avanti dispatchers at WNW, also that only Wallgate had ticket gates (but as both stations have them now that's no longer an issue).
pokemonsuper9
20 Dec 2022
Greater Manchester
Previously the Leeds - Wigan services went into Northwestern instead of Wallgate, but switching to Wallgate has been (From a passenger perspective) mostly positive, it used to often be delayed waiting to go towards Ince.
Starmill
18 May 2012
Bolton
Currently, no 769s run on Sundays!
Indeed. They're not really needed. And certainly wouldn't be for Sundays either when a 323 could be used anyway.
Oh, the Atherton line? Yes they could do, but there are no wires via Atherton.
5 Aug 2015
Norfolk
Anyone heard of any plans for the Atherton line? It's now an island and not that long in length. Would there be any complicated clearences or structure rebuilds?
Mag_seven
1 Sep 2014
here to eternity
If anyone wants to discuss the probable service level after electrification the please use this thread.
In the meantime if anyone wants to provide us with actual construction updates than please report this post and we will allow the update to be posted.
