Wigan-Bolton electrification. Construction updates only please
td97
26 Jul 2017
That would be correct, also confirmed by SPL
On the Wigan to Bolton #Electrification Project SPL POWERLINES UK have hit a huge milestone on Saturday night 7th December whereby we installed the final Contact/Catenary Wire.
The fantastic Wiring Team braved Storm Darragh to safely install SW06 on Up Hindley in CU09. During the shift we also successfully installed the final Surge Arrestors and RSC Cable on the route along continuation of the Registration and In Span. The POS Reps continually measured the wind speeds throughout the night to ensure we stayed below the threshold.
Mark Cowgill - I'm extremely proud of the team who have continued to demonstrate resilience with the challenges which have been thrown upon us. All eyes are on Wk40 #Energisation now.
DJH1971
10 Jun 2012
St Helens, Merseyside
So when is the first test train likely?
Gricer99
21 Jun 2020
Hindley
Northern released its Winter Timetable for the line this week. The timetable goes from December 15th to 17th May. 95% of the trains still run to Wallgate and of those that don't, some are on the Leeds route via Atherton.
From this, I think we can conclude that we will get the electrified passenger service with 323s from May 17th.
On another note, the Deep Pit Bridge has now been lowered onto its new concrete blocks. They still have to build the ramps on both sides and remove the cradles. I'll be surprised if its re-opened in February.
Some guy
6 Feb 2022
Preston
It would be interesting to see if TPE will run 397s and 802s down that section as an emergency diversion
Bristol
It should be possible to see test trains before that and then Pendolinos on diversion
Pendos are already cleared on the Chat Moss and via Chorley, how often do they divert via Bolton? You'd need the WCML south of Warrington blocked simultaneously with the other 2 routes, which is rather a small option.
I can see clearance being asked for but then being used for an average of less than 1 service a year.
For example will MENTOR be passing over the route?
It will at some point, although it's probable other route proving trains will run first.
They might get clearance for it just in case but see point above.
td97
26 Jul 2017
This project does include Class 390 route clearance.
507020
23 May 2021
Southport
Which is why I mentioned it. They might as well since they’re doing the work anyway.
The WCML blocked anywhere between Golborne Junction and Crewe means using Chat Moss, which is preferred so they can use EPS 125mph to Golborne Junction and serve Wigan North Western, vs 75mph the whole way via Bolton, but you only need Wigan - Golborne Junction to be blocked for that to be impossible, so Bolton it is.
In reality it’s more likely that if the route north of Golborne Junction is blocked, it will be blocked all the way to Euxton Junction and Pendolinos wouldn’t be able to call at Wigan because there’s only access to platform 1, which isn’t long enough.
But this electrification does make it possible to schedule engineering works between Euxton Junction and Lostock Junction as well as Wigan and Golborne Junction simultaneously.
In reality it would be more useful for TPE 397s and 802s which are MU and calling at Bolton anyway, but I don’t know if they’re getting clearance.
Paul Cobbe
13 Dec 2018
Wigan
I noticed where the uverhead neutral section is between Wigan and Lostock today. The OHNS is at Ince by the Hitchins food factory.
pokemonsuper9
20 Dec 2022
Greater Manchester
There are now overhead live wire warning signs at both ends of Hindley's platforms, and at the exit side of Ince station (the platform extension is very much in progress there).
There's a 390 ECS each way every night between Longsight and Preston/Lancaster.
It presently runs via Chat Moss, but in the past has used the Chorley route.
I can't think Avanti wants another option.
Geeves
6 Jan 2009
Rochdale
There's a whole raft of works planned on the Warrington BQ to Preston section in the future so who knows, it might well get used in the end with some weird and wonderful diversions / ECS work.
david l
27 Dec 2016
Drove past Ince yesterday with entrance still blocked off. Didn't clock the notice fully but seemed to say re-opening was now Dec 22. This is a Sunday so would suggest Monday 23 might be the case.
pokemonsuper9
20 Dec 2022
Greater Manchester
Ince's platform (not the extension, that's still just dirt) is looking pretty much ready for reopening, they've resurfaced the whole platform.
-- below Monday 23/12/2024 - 8:11 --
Every Leeds-Wigan train is part cancelled today (not stopping at Ince) due to "engineering works not being finished on time."
Looks like Ince's work has overrun.
Gricer99
21 Jun 2020
Hindley
There was plenty of work on tfe Deep Pit Bridge West of Hindley Station in the evenings last week.
I clocked the daily freight going through this afternoon.
NorthWestRover
24 Aug 2018
Just stopped there. 15.49 Wigan to Leeds.
GhostManDN91
2 Oct 2022
Wigan
Yep station open as normal now. There's a notice for train crew to check when stopping there aswell before doing door release on a 4 car 158/156 sets I noticed at Wallgate.
td97
26 Jul 2017
£100k of cabling has been nicked by low life scum.
Unfortunately an obvious target given NR widely publicise that these cables are not energised until a specific date. I recall a similar occurrence on NWEP Manchester- Preston.
There's an emergency possession to fix it tomorrow 29 December, aiming to retain the energisation date of 1 January (and hopefully that should put a stop to any further cable theft attempts!)
tumbledown
5 Nov 2024
Ah, OLE. NationalRail is still saying signalling cable. Which I thought was odd as services are running normally.
pokemonsuper9
20 Dec 2022
Greater Manchester
Shame there couldn't've been a low power (but still a nasty suprise) running through the wires.
Lets hope they can repair it all tomorrow (do they have insurance for theft like this?)
Winthorpe
18 May 2019
It beggars belief that the energisation date is advertised so publicly.
Say nothing, or say it is energised from day one.
Elecman
31 Dec 2013
Lancashire
Sadly the construction earth leads at the earthing points tend to give the game away that the OLE is deenergised
wrinkley
6 Feb 2015
I am confused, the immplication on the forum is that 25kv cable has been stoien between Lostock and Wigan. However, Network Rail are saying that it is signaling cable between Bolton and Chorley. If this is the case, trains on the Preston line seemed to be running normally at Lostock yesterday.
5 Aug 2015
Norfolk
Yeh i think it was just a mistake by communications people.
I've also heard it was feeding cables rather than OLE. Is there a feeder station on this line or would this refer to a track sectioning cabin?
Elecman
31 Dec 2013
Lancashire
Lostock Auto Transformer Sectioning cabin located at the bottom of Lostock station car park
5 Aug 2015
Norfolk
Oh so is Lostock-Wigan using an autotransformer system? If not how do AT systems deal with feeding a branch that is not using ATF. Is it that the branch to Wigan will only be fed by the Autotransformer at Lostock SATS and therefore not carry a -25kv wire because there are no more autotransformers (sectioning, midpoint or standalone) on the way to Wigan?
