DanNCL
That doesn't actually look as bad as I thought it might; though that might be down to the shape of the cab. I'm sure it would look much worse on a 150 with a flat frontIf you had to try and shoehorn either of the WMTrains liveries (a key feature of which being the fully coloured front with only the gangway door painted yellow) onto a class 139, you could use the central windscreen to define that yellow patch, the gist of which is shown by this quick and dirty mockup. That said, it's moved on a fair way from 172/0s which prompted the discussion (for which the technique I've described would be more difficult, given the lack of a single, central, windscreen)
