... I have absolutely no interest however in Electrostars, Turbostars, Desiros etc. but like you I don’t see how any progress has been made over the last 20 years or so, and indeed one could argue things have gone backwards. The FLIRTs actually seem decent but they’re the outlier IMO. Other fleets (e.g. the 700s as much I detest them) are compromised due the routes on which they operate. Others however, including the 195s, appear to have been specified simply as the cheapest way to get some new trains on the network and it shows. Being better than pacers is akin to being the best swimmer out of the non-swimmers…
So where do we start in terms of progress? We have more efficient, more powerful engines. We have (arguably) one of the most effective brake systems fitted to a unit on the 195s. Air con (that reliably works) throughout, lighter bodies and bogies reducing damage to the track and associated maintenance requirements. The list is far, far longer when comparing to even Turbostars, but simply, just because you don't notice a better ride quality, doesn't mean there isn't substantial progress elsewhere.
Whether or not they're branded as Connect, those services aren't really the best use of 195s which are more suited to all-stations stoppers. However as a result of the Connect idea they were specified with an interior layout more suited to "regional express" type services. With hindsight the 195s should have been closer to 172s inside, with 158s and 170s on the semi-fasts.
The 170s don't have the acceleration (or indeed the numbers) to be effective (eg: on Calder valley). The 158s are, after refurb, really very similar (aside from the never worked from Day 1 aircon). I'd rather take a 195 to Blackpool than a 158.
1. The cycle space. Yet again a TOC has made the mistake of having fold down seats in the cycle space area, which creates unnecessary conflict when you board the train with your bike and someone is already sitting there and refusing to move even when there are other free seats on the train. I've said it many times on here but if you want to maximise space on trains then vertical cycle hooks are the way forward, as Northern have had for many years on their class 333 trains between Leeds and Skipton/Ilkley.
2. The information screens. If they just showed information that passengers need to know that would be okay but on recent trips I've found they're constantly flashing in bright garish colours warnings about health and safety and sexual harrassment which are not just irrelevant but incredibly distracting.
1. Why should a bike that isn't on the train be able to occupy a space that could be used for seats? I hear what you're saying but I think it a little unreasonable to expect a big area to be ruled out of use to everyone other than a cyclist. Surely you can just ask staff to intervene/ mediate if there is conflict?
2. I really think the PIS is one of the best on any units nationally. It's just a shame it's not been used to it's full function. I agree with with It's sentiment entirely, but that's more down to how its being used.
It's not the same though. The trains aren't designed for guard release, and it shows. There's a notable delay before the door release propogates along the train. And the local door sounds the hustle alarm before closing
The only time I've ever had a 5 second release is where the guard hasn't done the checks properly. When done properly it takes at least 10-15 seconds or so.
The trains are theoretically supposed to do 30 second dwells but there's not a cat's chance in hell of that, unless nobody boards or alights. It's only the excellent acceleration that masks it.
Simply untrue, as pointed out by "Neptune". The doors on the 195s are very rapid, generally speaking. The only time there is a delay is when either, a. ASDO is being overridden at a terminus, or b. The guard is otherwise delayed, as could be the case on any unit.
195s have never been as quick as 185s. In fact 195s are generally not even as quick as they were last year - the majority of them have TCMS faults relating to the engines ('diesel engine anomaly' is the usual message) - when digging deeper you find that air filters are clogged and radiators are clogged with greenfly/pollen/dandelion seeds/dry leaves - pick one depending on season.
As for acceleration performance of 195s vs 185s, having been left for dust more than once despite the 195s I've been on being in 'super power' mode and wide open, and even without engine niggles, it's pretty plain that the bigger Cummins QSK-19 and Voith setup gives a lot more power at rail than the 195's Daimler 6H 1800 R85L and ZF Ecolife.
Interesting, because I have always found them to be atleast as quick, if not quicker. The engine issues are something that literally every DMU encounters and there is a procedure for fixing - do you "book it" so it can be resolved?
