Autumn refresh for GWR Class 165/166 Turbos
Towers
30 Aug 2021
At last the end of those ghastly bright pink grab poles and handles. To be fair, the First Group refurb of 15-odd years ago was mostly OK, and has lasted quite well, but the pink was just awful.
I was a always a fan of the late-FGW era identity, but I appreciate it was a bit 'Marmite'. I do, however, wonder what visually impared users make of having the internal grab rails now painted black.
DelW
15 Jan 2015
The Reading 2 cars are being done at the moment; and infact are nearly finished. I see no reason why the 3 cars won’t follow on after.
Thanks, it's almost always 3-cars I use (on the North Downs), so I'll look forward to the refurbs hopefully starting to appear there before too long.
Unless of course the 769s arrive first o_O.
jackot
1 Aug 2021
38,000ft
This has probably been mentioned before, but will the 165s keep their first class for routes like the North Downs?
HamworthyGoods
15 Jan 2019
Is there a list of completed unit I could look at please? Preferably split into Reading and Bristol :D
The 2-car 165s are all allocated to Bristol these days, Reading solely looking after running exams. You are just as likely to see a low numbered unit in the West as you are in the Thames Valley.
43 302
25 Oct 2019
Well that's completely and utterly incorrect. 165101 - 165117 are the 3 car units and are all LTV allocated.* 165118 - 165127 are 2 car units LTV allocated, and 165128 - 165137 are 2 car units allocated to PM. The units occasionally swap over via 2E77, an early morning Oxford to Worcester Shrub Hill diagram.
*Until a few weeks ago when 165101 transferred over to PM, becoming the only 3 car 165 allocated to the west.
Edit: also 165115 was scrapped after being involved in the Ladbroke Grove crash.
HamworthyGoods
15 Jan 2019
The units swap over daily Monday to Fridays between West and LTV at Worcester.
The incoming working from Gloucester works to Worcester Foregate Street and returns to Didcot Parkway.
The incoming working from Oxford terminates at Shrub Hill and works back towards Gloucester.
The timetable with one service at Foregate Street and one at Shrub Hill does not allow for the 2 cars turbos not to swap over. Looking at the week just gone the units swapped between West and LTV and v.v. Swapped over every day except Monday (when there was planned engineering work with buses to Moreton in Marsh)
JN114
28 Jun 2005
Perhaps on paper; but in practice 118-127 are still “LTV” units and 128-137 are still “West” units; and treated separately by operations - the former being used on the RG2xx diagrams, and the latter on the PM2xx diagrams.
There is one “West” unit diagrammed on LTV work per day (over 2 days technically) - which works Gloucester - Worcester - Oxford - Reading; stables between peaks and then comes back out for PM Peak Didcot-Oxford work finishing Oxford then works Oxford - Worcester - Bristol the following morning.
Woe betide the controller who puts an LTV unit on the PMxxx diagram…
TT-ONR-NRN
30 Dec 2016
Salford Quays, Manchester
165120 is on CDF PMH today.
43 302
25 Oct 2019
Makes my turbo commute around Bristol all the more interesting though! I had 165120 up the Severn Beach this morning :D
JN114
28 Jun 2005
It escaped last week at some point after the West unit was misbehaving.
To slightly correct your previous post - 165101 is currently “officially” West from the 3 car fleet.
From May TT change there is expected to be greater degree of inter-working of the West/LTV fleets; including 3 cars. However as it stands no instruction to the ops department that the current status quo of unit “ownership” between Reading and SPM is changing.
We’re digressing more into unit allocations than refurb details though, so perhaps we leave it there.
As it stands to my knowledge these are the Reading 2 cars currently refurbished:-
165118
165119
165120
165121
165122
165123
165124
165126
I can’t speak for which West units were done but it’s at least 2 or 4
FGW_DID
23 Jun 2011
81E
12 done / in progress (8 RG / 4 SPM)
In order of work carried out:
LTV (RG): 122,123,126, 118, 119, 121, 120, 124 (current Wolverton set)
West (SPM): 130, 129, 132, 128 (current Wolverton set)
They won’t be working North Downs when the 769s finally get their act together.
Now there’s an optimist! :lol::lol:
fgwrich
15 Apr 2009
Hampshire
Good point, the 769s are taking so long I almost forgot about them :lol:
I cant see the First Class compartment being removed on the 3 cars (already removed on the 2 cars), 769s do also have First Class but it'll still be a while it seems before we see that (same moquette, different seats, bit of carpet but no internal divider).
Dougal2345
29 Oct 2009
The one I travelled in yesterday needed scrapping not refreshing. In addition to the pictures, an internal door was sticking, and the noise inside was like sitting with a malfunctioning vacuum cleaner next to your head.
To add insult to injury, on arrival at Portsmouth Harbour I had to queue up next to it in full cry (and full stink) for 15 minutes in the queue for Wight link. My tinnitus is still bad this morning.
Did we used to poke fun at the state of Albanian trains?
fgwrich
15 Apr 2009
Hampshire
I’m not sure what causes it, but I can’t stand that whining fan in the FC Compartment ends. On some units, it used to be so bad that it would give you a headache - not so good when you’ve just come off a block of night shifts and you just want to get some sleep.
That table and arm rest isn’t the worst I’ve seen them though, you could often tell which units had been out late into the night when they were pushed out onto some of the early turn services.
387star
Wait in till you hear compressor speed up...
Parallel
9 Dec 2013
Dare I say it, that’s a good example from the pictures you’ve shared!
I was on a 166 a couple of weeks ago that had one of the four tables missing out of the ex-first class section!
There are still plenty of blue 3car sets passing through Bradford-on-Avon, complete with First logos
Not sure when GWR introduced the green livery (seems like years ago), but must be quite lowish priority to repaint and refurbish them as not yet all in green livery, but as there are regular short formations currently presumably they cannot be spared to do the work.
nw12398
19 Dec 2021
Devon, United Kingdom
There doesn't seem to be any 165/166s running from Exeter throughout the day today and more 158's than usual - all Barnstaple services (not too rare) and 2 running on Exmouth-Paignton services (one 3 car and one 2 car coupled to a 150) - any idea why?
Edit: moved to a more appropriate thread.
CR165022
12 Nov 2019
Buckinghamshire
the blue ones were repainted just before the livery was changed to green, therefore meaning that they didnt need to be repainted again, they will get repainted into green when they go for interior work
387star
Dare I say it, that’s a good example from the picture’s you’ve shared!
Been like that for years
TT-ONR-NRN
30 Dec 2016
The 165/1s seem to have all of the cup holder/mini tables removed, and those sections are actually still used as First Class! Having said that, they were all falling off anyway. The lights overhead also generally do not work.
