Chiltern 68 operations as of April 2021
7 Apr 2021
I am spotting on the Chiltern Main Line soon and I am wondering whether the 68 diagrams are still the same as Pre-Covid workings or are they currently altered, Thank You
Freightmaster
Verified Rep
7 Jul 2009
Still just the one diagram (currently 1H22/1R23/1H47/1R51) at the moment and unfortunately not expected
to increase beyond four trains a day after next Monday despite Chiltern expanding their timetable somewhat.
MARK
STEVIEBOY1
31 Jul 2010
Thank you for asking that question, I too, was thinking about having an awayday on the 68s from Marylebone to B'rum soon, but don't think it will happen for a while. Infact I could only see one of the above mentioned workings on the Chiltern Diagrams in this forum, the 1H22. I would normally go on the 1010 or 1110 from MYB, coming back from Moor Street at 1255, 1355 or 1555, Mon-Fri, but it does not look like these will run for the time being?
OliverH68
31 Oct 2019
Warwick, UK
From next Monday, weekdays only:
D1
1H22 07.16 Stourbridge Jnc - Marylebone
1R25 11.10 Marylebone - Moor St
1H48 13.55 Moor St - Marylebone
D2
1K50 17.14 Marylebone - Kidderminster
Nothing at weekends.
are the rest booked to be units?
That is certainly what would be implied if there is only one hauled diagram.
The only reason to use the hauled sets in normal times is for capacity. I'd imagine that the only reason to use them at the moment is to maintain traincrew competency.
sufian123
1 May 2017
thanks appreciate it
STEVIEBOY1
31 Jul 2010
D1
D2
Thank you for that, it looks like I could then get the 11.10 from MYB, have about an hour in Brum, just enough time to get a sarnie and come back on the 13.55. 68 both ways.
Chiltern006
3 Oct 2018
these are diagrams from last summer, but have generally stayed the same. these may be incorrect after may TT change
CH Cl.68 LHCS Diagrams
Class 68 + Mk3 TSO + Mk3 TSO + Mk3 TSO + Mk3 TSO + Mk3a RFM + Mk3 DVT (4 sets)
Six Class 68 locomotives are leased by Chiltern Railways from DRS. These are 68010 - 15 (XHCE) and painted in Chiltern Silver livery, although other DRS 68s are used (68008/009), as and when needed. **DMU substitutions can occur at any time!**
Monday to Friday
Diagram 1
1H15 06:09 Kidderminster - London Marylebone
1R33 13:10 London Marylebone - Birmingham Moor Street
1H62 15:55 Birmingham Moor Street - Marylebone
1K54 18:15 Marylebone - Kidderminster
Diagram 2
1H17 06:41 Stourbridge Junction - London Marylebone
1R21 10:10 London Marylebone - Birmingham Moor Street
1H45 12:55 Birmingham Moor Street - London Marylebone
1K50 17:14 London Marylebone - Kidderminster
Diagram 3
1H22 07:10 Kidderminster - London Marylebone
1R25 11:10 London Marylebone - Birmingham Moor Street
1H48 13:55 Birmingham Moor Street - London Marylebone
1K45 16:15 London Marylebone - Kidderminster
Saturday
Diagram 1
1H10 07:12 Kidderminster - London Marylebone
1K49 16:46 London Marylebone - Kidderminster
Sunday
Diagram 1
1H23 10:55 Birmingham Moor Street - London Marylebone
1K53 18:00 London Marylebone - Birmingham Moor Street
sufian123
1 May 2017
Monday to Friday
Diagram 1
Diagram 2
Diagram 3
Saturday
Diagram 1
Sunday
Diagram 1
chiltern diagram have changed usually it’s one loco hauled at the min. Likely to continue to May.
Diagram 1
is a unit.
Diagram 2
is running
Diagram 3
not running
no weekends as far I know might be wrong
CW2
7 May 2020
Crewe
Perhaps worth mentioning that diagram 2 runs off to Wembley depot between 1H45 and 1K50, and sets are often swapped at that time, so maybe Diagram 2 should read 2A and 2B.
PHILIPE
14 Nov 2011
Caerphilly
Still only one diagram. A diagram is the programme of a days planned work so in this case 2 x units may be allocated at different times through the day but still only one diagram
CW2
7 May 2020
Crewe
The day's programmed work might well be split into two separate diagrams, i.e.
1) 1H17 / 1R21 / 1H45 / 5H45 / Maintenance.
2) Maintenance / 5K50 / 1K50.
You would need to see the original paperwork to be sure.
PHILIPE
14 Nov 2011
Caerphilly
You can't split a days work into 2 diagrams. 1 Diagram per day.
1H17
1R21
1H45
5H45
MTCE
5K50
1K50
HamworthyGoods
15 Jan 2019
1H17
1R21
1H45
5H45
MTCE
5K50
1K50
You miss understand how the railway diagrams rolling stock (and traincrew), a ‘diagram’ is how a block of work is allocated to either traincrew or rolling stock. Many operations have diagrams where that block of work doesn’t complete a full day.
Whilst diagrams can be stepped up in this case there are two booked loco hauled diagrams on Chiltern, one covers 3 trips and one covers 1 trip but they are still two separate diagrams. In the same way multiple drivers will cover those services - there is more than one traincrew diagram for example covering those 4 services.
CW2
7 May 2020
Crewe
There isn't sufficient time to carry out the necessary maintenance between 5H45 and 5K50 on a diagrammed basis, so the maintenance periods of the 2 diagrams overlaps.
PHILIPE
14 Nov 2011
Caerphilly
You miss understand how the railway diagrams rolling stock, a ‘diagram’ is how a block of work is allocated to either traincrew or rolling stock. Many operations have diagrams where that block of work doesn’t complete a full day.
I have been a diagrammer myself, diagramming both units and crews.
HamworthyGoods
15 Jan 2019
In which case you will understand cyclical diagramming requires a certain amount of time on depot for maintenance windows (which on some stock like IETs may be a specified amount of time on depot), that needs to be diagrammed as a block of work in the same way that passenger trains need to be diagrammed.
In the Chiltern case the diagrams are 3 trips then maintenance, with another diagram being maintenance then a single trip. There is insufficient time for the maintenance activity to occur between the 3rd and 4th passenger trip. That is why it is two diagrams and you will see different loco and stock covering the evening departure from Marylebone.
Whilst in many cases planned maintenance is carried out overnight that is not always the case.
PHILIPE
14 Nov 2011
Caerphilly
I know. I think there is just a matter of interpretation. We can split the OPs post details into two separate diagrams instead of A & B
diagrams
HamworthyGoods
15 Jan 2019
diagrams
It’s rarely a problem as the majority of stock usually cycles via its Home Depot, just with the reduced service the sets have to be somewhat forced to go onto Wembley!
STEVIEBOY1
31 Jul 2010
Thank you for this, I am still planning a trip from London to Brum using the 68/loco hauled service, I shall wait until after 17 May and see how things are working out. (Can't wait to get on a proper train again.)
